Question about Samsung SRP 270C Matrix Printer
Printing area calibration problem
We are using Samsung Bixolon SRP-270 printer with auto cutter and with pre- printed header and footer on slips. the problem we are facing is that at 6 th print after installing a new pre-printed paper roll , printer starts cutting the footer of Pre printed slips, and after 10th print whole footer is gone from the slip and paper alignment get out of order. Is there any way, we can define the length of slip and printer automatically cuts at that length.
  • 3 Answers
It is just impact printer which does not have calibration function. If you have preprinted header and footer, it should be controlled by software program exactly where to cut. It seems your s/w does not calculate line feed exactly as you needed.
Again contact your s/w company.
Posted on Jan 02, 2009
Mising my driver cd
Posted on Jul 28, 2008
My bixolon SRP 350PLUSII is double printing one receipt, please help me how to solve it
There is no option that I know of, on the printer to do this. I suspect this is an option in the pos software that you are using. If you are using windows try doing a test print to the srp350ii from the printers in control panel and see if it prints once. I am pretty sure it will and that will prove that it is something in the software itself.
Oct 25, 2012 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I have bixolon srp 350 for my restarant when i give print command from register it always comes in queue with showing error. i done all softaware re installation and self test for printer everything works...
hello, im trying to send a print to my BIXOLON SRP350 Thermal printer by java codes. but java can't use the all the page width, what should i do to use all of the page width ?
Feb 20, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I have replaced a posiflex receipt printer with a Problem with the POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer I have replaced a posiflex receipt printer with a bixolon...
If the print test works, then that rules out cables, etc. Definitely sounds like a comm setting issue. The most common problem with swapping serial printers is incorrect baud rate. Is that winpos from quest in Aus? I think they might use 9600 baud. You change the printer baud rate using the dipswitches under the panel on the bottom of the printer.
Jan 03, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
My Printer Bixolon SRP-270 USB/Parallel stop working after few minutes. We are using the USB port but the printer comes with a converter parallel usb
I'm sure it is the converter cable that is casuing this issue. Definitely try to change the interface on the printer to the native communication type. So if you have a parallel printer and you dont have a parallel port, you'll want to change the interface on the printer to usb. Bixolon printers have this ability. it'll cost around 30-40 bucks probaably with shipping
Mar 30, 2010 | Samsung SRP 270C Matrix Printer
First you'll need to make sure your system has a COM (serial) port. Looks for a port on the pC that has 9 pins (5 on top, 4 on bottom). Get a Null modem DB25-DB9 cable and connect the printer to the PC. That'll take care of the hardware connection. Youll need to know what kind of driver you want to use. POS printers like the Samsung SRP printers either has a windows or OPOS driver. You should have a software you intend to use to print to the printer, so check with the software vendor what kind of driver you need to print. Install that driver, make sure the baud rate on the printer and the driver is matched and your good to go.
Apr 10, 2009 | Samsung SRP 270D Matrix Printer
Hi Anabel,
I've heard of this kinds of issue in cases where an adaptor cable (usb-serial, usb-parallel) causes this. But if this isnt you perhaps you can try reloading the printer's newest driver.
Jan 21, 2009 | Samsung SRP 350 Thermal Printer
SRP 270 feed 10 cm of paper before printing
Does this happen with all applications? This may be due to the header/footer and margin settings in y our application. You can try opening notepad (Start -> Run -> Accessories -> Notepad) and entering a bunch of text into it. Then print it up and see if there is still all the extra space. If it prints normally, then adjust the margins in your other applications. If it is still not operating correctly, try running the printer diagnostics program to re-calibrate the printer.
Sep 19, 2006 | Samsung SRP 270C Matrix Printer
Samsung SRP 270C Matrix Printer Logo
307 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
