Header file use
  1. sir my first question what is header file in programming,what are the header files are available in c
  • 79 Answers
Hi
briefly defining header files are those files which contains the declearations of all the pre-defined functions you use in a C program, like printf,scanf, and all that.
Various header files in C are:
stdio.h
conio.h
math.h
and many more.
to get a detailed information go to the following link: http://en.wikipedia.org/wiki/Header_files
Posted on Jul 22, 2008
Is it possible to Repair DBF file?
If the file needs to be repaired, it is already damaged. To make things worse not only keeps a spare copy. And so - foxfix very powerful tool for recovery. Or a hex editor to see what is written in the tail of the file if the garbage - it cut before the "normal" data (aligned along the border post), to calculate the size and the size of the .dbf header records how many there really are, and to correct the record count in the header. Also there is a file header, which is similar to can (and should) rule in heh mode.
here you can see this topic. Here is the link to the forum
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/593-foxpro-behavior-when-opening-dbf
and even try to program DBF Recovery Kit
http://www.all-recovery-inc.com/#!/foxprorecovery
Dec 02, 2014 | Microsoft Visual FoxPro Professional...
How do I read a VCF vcard
Microsoft Outlook reads VCF files directly. Thunderbird, Windows Live Mail and other email programs will import a VCF file into the address book. For Thunderbird, if the vCard is an email attachment, just click on the vCard in the preview and add it to the address book. Double-clicking should automatically import the vCard. Any text editor (Notepad, Word) will open the VCF file with the headers visible.
However if the vcf file has multiple contact entries, you would be better off using Outlook or Live Mail to export the entries as .CSV (comma delimited text file) and then importing from that. Alternatively, edit the file with a text editor to add tabs or commas and save the file as a .CSV file. (Use the Open With command in Windows.)
There are VCF viewers available. There is one here: http://www.softpedia.com/get/Office-tools/Other-Office-Tools/VCF-Viewer.shtml . It can't edit or search the file though.
I hope this helps.
Oct 08, 2014 | Cell Phones
Sir i have been working to c++ but before sum days i have run endless loop program by mistake something got deleted from iostream.h file after that it is showing linker error pass2
iostream.h file input output header file for c++ by which we can use input/output data.
So you must reinstall the c++ to your system and after that linker error would not go on.
Aug 26, 2011 | Borland Turbo C++ 3.0 Full Version...
Compatability issue
How to install an XP/Vista program on Windows 7
First of all locate the setup or installer file, this will be either in the contents of a CD/DVD (you have to explore the contents of the CD/DVD) under the name "setup" or a downloaded .exe (executable) file.
Right click on the setup file and select "Properties" from the sub menu.
A Properties windows will appear on screen, click on the "Compatibility" tab.
At the bottom of the tab you will see the header "Privilege Level".
Check the box that says "Run this program as an administrator"
Also at the top of the Compatibility tab you will see "Run this program in compatibility mode for:"
Check that box and if you have the option select Windows XP (service pack 3).
Click Apply and then OK and install your program.
NOTE: if you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
How to run an installed program on Windows 7
Some programs will install but they won't run on Windows 7. Again this down to compatibility but unlike Vista, Windows 7 has the compatibility mode working down to a tee.
Locate the desktop icon or the program in "All Programs" from the Start Menu or Orb as it's affectionately known today.
Just as in my tip about installing a program it is just the same.
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngRight click on the icon or file and select "Properties" from the sub menu.
Click apply and then OK and run the program.
NOTE: If you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
Regards.
Jul 09, 2010 | Broderbund American Greetings Creatacard...
I want to prepare a letter head on plain paper, how I put my company logo & name, as well address on it, What I mean is how to put header & footer on paper?
Letter head on Plain Paper
Step1: Open a Microsoft Word Document File
Usually word creates a new document when the program is opened.
Step 2: Inserting Header and Footer in Word Document
Click on view and then Header and Footer.
Step 3: In a Microsoft Word document, choose Insert > Picture > From File… After selecting file, it will give you a browse file option, where you have to specify the location of the logo file you have created with desired resolution and size.
Step 5: Control-click on the placed image and choose Format Picture from the pop-up menu.
Step 6: Inserting text into the Header and Footer
To insert text into your letterhead, simply select the font style and size of the text you require, then enter the text into the header and footer box.
May 18, 2010 | Microsoft Computers & Internet
When i click on my JPEG pics they wont open
such jpg files need the original software when they were modified into a jpg format. like an adobe jpg or a corel draw jpg wont open in paint until the respective software is installed.
secondly jpg file has a header file and check sum , if the header file is missing or destroyed by a virus or already there is a virus on ones system the jpg files have to be isolated and treated for antivirus which reapirs the file and seperates the virus from the header maintaining the integrity of the file.try to isolate one jpg file and run a scan for virus on another computer, if the file gets repaired use the antivirus to repair your files
Sep 19, 2009 | Computers & Internet
When i back up on any desktop pc i get error message ''windows was unable to complete file transfer ACCDATAE/HEADER/DTA.file this could be a computer hardware or network fault the date will be los'' If i...
Do you use Sage financial software? The only instance I could find about a similar-named file was ACCDATA\HEADER.DTA in Sage.
If so, be sure that the Sage product is shut down first. The program probably has the file opened for exclusive use, meaning no other program (such as your backup program) can read it. Backing up the file to another hard drive probably allows the file to be closed temporarily, allowing it to be read.
Aug 19, 2009 | Computers & Internet
Error occur during compiling,unable to open a header file
The compiler is attempting to access the iostream header file and it either cannot find the file (not in the default location or it has been told to look in another location where it doesn't exist), or the file security is set so the current user does not have read access to the file.
Apr 15, 2009 | Computers & Internet
How to use window.h in c++
use windows.h header file and play the .wav file using PlaySound function as  e.g: PlaySound("C:\\SOUNDS\\BELLS.WAV", NULL, SND_ASYNC);
Thanks!
Apr 01, 2009 | Microsoft Computers & Internet
Gud eve, can you provide me the functions of header file in visaul c++ ?? please ! i just couldn't fix my problem regarding on our lab exercise
header files contain instruction sets tht u want to be recognised as executable functions in ur program. just as when u ask time u expect the 2'nd person to resolve hour minute and second , think as the person as a computer with a heade3r file which has the function for resolving the reading of hours minutes and seconds from the display . adn due to that header file u wount have to teach tht guy how to read time everytime u ask him "wat is the time?"
Nov 27, 2008 | Computers & Internet
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
