Question about Blaupunkt Car Audio & Video
Dear all, I have a Pegeute 307sw with a Blaupunkt Audio set with Multi stack CD Phone Nav SAT . Apperently the Multi stack cd is not functioning any more and the buttons numbers are flashing. The main CD player does not play neither. Can you please advise, What could be the problem or it is just died. Regards Isaac Itoorgeman@gmail.com London
  • 1 more comment
  • itoorgeman Jul 22, 2008
    How do I disconnect the CD changer power cabel?
    OK I will try it
    I do not know how to actually disconnect the power cable. I probably need to detach the Audio set out of its base. I do not know how to detach it.
    Regards
    Isaac
  • 19,396 Answers
Cd changer is mainly a mechanical unit, most common problems are caused by gears and dirty lens.
Try disconnecting the cd changer power cable and connecting it back, if it reset the changer it will restart working normally, if not you have to replace or take out for repair the cd changer.
Posted on Jul 22, 2008
  • Ginko
    Ginko Jul 22, 2008
    Locate the cd changer unit, remove it from caddy, it will have one or two connectors at the back, unplug them all.
  • Ginko
    Ginko Jul 22, 2008
    To test the whole thing at once, you can unplug the car battery.
    If you doi so, probably you will get a lock code on your car stereo when you connect back, ensure you have unlock code if you decide to unplug battery, or you will add one more problem to the list.
New battery fitted to my ford mondeo 2008 now blaupunkt radio/sat nav fx not working how do I reset, the unit does not power up
Check the fuses! If the fuse box fuses are ok check the one on the back of the radio...needs to be removed!
Jan 08, 2015 | Blaupunkt Car Audio & Video
Radio muted
See if your car is equipped with hands free cell phone interface it may have been activated accidentally
Jul 09, 2009 | 2004 Mercedes-Benz C-Class
Blaupunkt sat nav problem
when insert the adress it doesnt recognized and give wrong direction
Dec 16, 2008 | Blaupunkt CD52 CD Changer
CD Changer Blaupunkt IDC A09
EBK zeewolde can get code out of serial number
coast 25 / 30 euro
i try to get code for cdc on my vistion radio cd
and try to use disconnect l / r output cdc and place mp3
signal to radio input when cdc turns
greets wilco1v @12move.nl
Aug 02, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd changer will not work
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
Jan 09, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Pioneer avicx1
Nope, you have to have the CD in whilst entering a nav route, frustrating as it is...
You have to listen to your CDs via an auto changer.
Dec 22, 2007 | Pioneer GPS AVIC-X1 car radio
Peugeot 406 factory fitted sat nav
If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
Dec 18, 2007 | Car Audio & Video
5 cd incar stereo
Hi in most cases the mod kit will fix the problem. other wise its a new unit as Blaupunkt only supply the mod kit or a new mech...
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
Regards
Mark
Dec 13, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Car Audio & Video Logo
173 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
