Question about SanDisk Sansa Clip MP3 Player
Sansa 2Gb MP3 player won't play
I pluggged into AUX on my stereo after which the player will not play. Only initializes then displays product name.
This is the second unit identical unit to fail.
Tried holding buttons down reststrtint etc but no joy.
Please help
  • lostnsoundwa
    lostnsoundwa May 11, 2010
    Did the player ever play when connected to the AUX? Also, after the product name was displayed, was there nothing shown on the screen at all?
  • 8,596 Answers
Did you connect it to an AUX in? An AUX Out could easily ruin the player's hardware.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
How can I hook my Sandisk Sansa Clip+ up to my stereo system if the stereo doesn't have a USB port?
Connect a audio from the headphone socket on the player and plug it into the AUX input on the stereo system. Set the stereo to AUX, turn on the player and adjust the volume level on the stereo.
Nov 28, 2012 | SanDisk Sansa Clip MP3 Player
Sansa e250 mp3 player won't recogize micro card
Make sure the card is a microSD card, not a microSDHC card. The e250 only works with microSD cards, 2GB and smaller.
Mar 19, 2012 | SanDisk Sansa e250 MP3 Player
Sansa c250 will not show music on memory card
First, make sure it's a microSD card and not a microSDHC card. If your card is larger than 2GB then it won't work in the c250.
Second, make sure all your music in a folder named "MUSIC" at the root of your card. You can have subfolders in that folder, but the top folder must have that name.
Feb 12, 2012 | SanDisk Sansa c250 (2 GB) MP3 Player...
Can I connect my mp3 player to my stereo
yes, if your stereo and mp3 both are compatible with each other. good luck!
Oct 14, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze mp3 player wont play on my jvc kd-dv 7402 car stereo
you can only plug this type of mp3 player through the headphone jack to your aux in jack on the front. the usb port is for memory sticks and cards your unit will automatically play the tracks off of one of these
Jan 28, 2009 | Car Audio & Video
SanDisk Sansa Clip 2GB stuck on refresh after charging
download the firmware update!
I had same prob- gone after update
here is link to update:
http://www.sansa.com/support/sansa_clip/faqs
good luck
Joe
Jan 26, 2009 | SanDisk Sansa Clip MP3 Player
Added 2gb micro card
The player can read the card, but it is not going to add more memory space to the player. The function of the card reader is to enable your player to play songs that you otherwise couldn't play because the hard drive is full.
-Tha Mp3 Doctor
Dec 27, 2008 | SanDisk Sansa e250 MP3 Player
Where can i find the driver for sansa clip mp3 2gb? where i can find the driver for sansa clip mp3 2gb
Go to sandisk.com. Click on downloads. Select sansa clip from the product list, then your operating system. You can get the updated driver and user manual.
Dec 10, 2008 | SanDisk Sansa Clip MP3 Player
How to fix my mp3 player...????
See my problem posting and do not be frightened.
Santapede
Jan 11, 2008 | SanDisk Sansa c150 MP3 Player
Home stereo hookup
Make sure that you are using a headphone to A/V (red and white RCA) (1-to-2) adapter. Then select source on your home theater until it says AUX or wherever you have the A/V (red and white RCA) cable plugged into. If you give me themanufacturer and model number of your home theater system, I can tell you EXACTLY what to do.
Some HTS's come with docking stations - they are probably not designed for Sansa players.
-Tha Mp3 Doctor
Jan 02, 2008 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
62 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
