Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
Screen problems I'm about to get a new MacBook Pro and would like to sell my PBG4. But the screen is acting up - sometimes completely black, but more often just the bottom 2/3 will either be black or keep the previous image frozen. The top third is usually okay, and with a little squeezing, the whole screen comes back to working condition. I don't want to sell my PB like this and would like to have a dealer fix the problem, but I don't have a lot of confidence in their getting it right at a reasonable cost - (about $100-$150). Otherwise, it's not worth selling - I don't think I can get more that $5-600 for it, right? Any ideas about how to advise the service dept. of the Apple dealer - they already told me "never heard of that problem", which didn't inspire a lot of confidence... Or is there a possibility of checking for a fix myself?
  • 2 more comments
  • Hillel Weintraub Jul 21, 2008
    expert Kevin said - video card is bad. If this is the case, why does the screen work well 95% of the time with a little squeezing. Isn't it more likely that some connections is loose?
    But if he's right, does anyone have an idea about how much a new video card will cost?
    thanks for the various comments. I wonder if what I've described is a common problem with laptops that are moved around a lot. (not dropped though!)
    and if anyone has any other ideas about how I can approach a service department to avoid being overcharged.
    I did check the site recommended by one expert - www.MONISERV.com - but couldn't locate any advice for do-it-yourself repairs
  • Hillel Weintraub Jul 22, 2008
    this is such a wide area - so many causes and finding things out is not an easy thing unless you're really comfortable working on the inside of your mac. But there are people who have done it and were kind enought to document their work on the web.
  • Apple Master
  • 13,433 Answers
If it is a loose connector and it would seem like it, you can open up the book and inspect the cables between the lcd and the motherboard. the vga itself is most likely not replaceable wihtout replaceing the motherboard.
Posted on Jul 21, 2008
    Genius:
  • 1,447 Answers
Hi-
Hi try calling this number instead for an estimation and repair.
818-876-2589Hope this helps
    Guru:
  • 1,342 Answers
If you're not afraid to tinker Here's How one guy took his apart.
Lots more good info at Power Book Medic
Once inside make sure all cables and connections are secure. These things seem to sometimes wiggle loose over time depending on how the laptop was used or handled.
Good Luck
  • Apple Master
  • 19,396 Answers
Does not look a software fault , rather an hardware problem.
This is either a faulty video adapter, or a bad lcd ribbon cable, you do not get any job of this kind done on a laptop for less than $100. It takes $50 only to diagnose the problem, probably repair will be around $200.
    President:
  • 2,712 Answers
As Abrsvcs pointed out, the graphics card is built into the motherboard. Most likely a cracked solder or faulty connector ribbon, that is best left to professionals to replace and diagnose. I do not think it is an LCD fault, or else you would just have a black screen.. My guess is a faulty ribbon connector. This shouldnt cost too much to replace, but I wouldnt recommend you doing this yourself..
  • Swilin Sampson
    Swilin Sampson Jul 21, 2008
    You could try the link at the right that says Repair Service. Just
    enter your Zip code in the box, and you will get a list of nearby
    service centers. Mention that you were referred by Fixya, and you might
    get a discount, but do shop around..:)
  • 2,071 Answers
Click this site they give an instructional guide or do-it-yourself in how to replace the LCD or the inverter;
www.MONISERV.com
hope this may help;
  • 1,879 Answers
Greetings,
Video Card or LCD that's causing it. It's a hardware problem.
Problem with Mac's is all parts are proprietary.
You can have it repaired and get small amount from it or sell it very low price. Don't take the risk of getting it repaired cause you might end-up spending a fortune.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
  • 4,234 Answers
If pressure returns the screen to full function, there is a connection problem. The issue is whether or not this can be fixed without replacing the panel. If you ned to replace the panel, the cost will be close to $300. There is no way to determine if the fix requries the panel without opening up the case and examining the ribbon cables and the panel connectors. It is possible that one of the cables has a hairline crack in it.
If you feel confident enough to open up the case, do so and examine all of the connections carefully under magnification. Be extremely careful when opening up the top that you don't rip the cable by accident as these cables are often taped to the panel.
Keep us posted.
Dan
  • ABRsvcs Jul 21, 2008
    There is no "video card" in the laptop. The video "card" is part of the motherboard. What you have is a connection problem as I stated above. What I can't tell you is exactly where the break is. Follow the steps I outlined above.
    Dan
    Genius:
  • 1,847 Answers
The video card is bad. need to replace it. it will surely work fine.
  • Legin Varghese
    Legin Varghese Jul 21, 2008
    before replaceing the video card just try installing back video driver.
Macbook Pro Black Screen but Keyboard LED On
If you've already tried turning up the brightness of the screen (the "sun" icon), then you may have a problem with the backlight (possibly burnt out, in which case you'd need a new backlight bulb). See this post for more details:
How do fix my Macbook dark screen
May 13, 2014 | Apple MacBook Pro Notebook
Tip
MacBook Pro Display housing coming off
If you don't want to spend a lot fixing your old macbook, this is an easy way to do it!
I hope it can help you.
keywords
MacBook Pro Display housing coming off fix
MacBook Pro display housing partly unattached fix
Macbook pro screen separating from the case fix
MacBook Pro unibody housing fix
Macbook Pro screen separation problem fix
MacBook Pro screen glass coming off fix
Broken MacBook Pro hinge fix
on Jan 29, 2016 | Apple Macbook Pro 13 - Brushed Titanium -...
Macbook
lots of cable problems during that period. Most were covered by recall that was not published like the car recalls ... just handled as they were brought into the Apple Repair spots. Mine was replaced along with new case and new fan.
Feb 16, 2014 | Apple Genuine 13.3" Macbook Pro Unibody...
How do i fix my macbook pro?
Is it plugged in? Is the battery functioning? Try holding down the keys command/option/p/r while turning the power on to your mac. Let it reset a couple of times. You will know it is resseting by hearing the apple chimb several times.
Jun 25, 2013 | Apple MacBook Pro PC Notebook
Have a macbook pro and it has locked up, black screen now and isn't responding to mouse or keyboard
This has also happened to my Macbook Pro - nothing would work, so i basically pressed the power button until it closed down and waited a few minutes and turned it back on. The problem ( touch wood) did not come back again yet. Good luck!
May 18, 2011 | Apple MacBook Pro Notebook
My MacBook Pro display screen is looking very strange....like a color photo negative of what it should be. White backgrounds are black, black letters are white and so on. I heard there was a problem with...
Don't worry you have put on one of the universal access settings if you go to system preferences and then universal access under display change the setting from white on black to black on white. Hope this helps
Dec 03, 2010 | Apple MacBook Pro with 17" Display
Macbook pro screen boots to black. tried rebooting, screen comes on then goes black again. This happened after I unplugged it from a dell projector. Any suggestions???
Try pulling the battery out then holding the power button for 10 seconds. Put the battery back in.
If not search macbook pro recall apple has extended the warranty on some models due to a bad graphics card.
Feb 02, 2010 | Apple MacBook Pro Notebook
Gray splotch on lcd screen on a macbook pro 13-inch
That is most likely a defect in the LCD itself... there was a huge issue with this on the older PowerBook series - like shown in this picture, 3 roughly dime-sized circles to the right of the Apple logo. If you need a place to mail it to, iResQ has done wonders for many of my friends - link is for mail-in, but they sell the screen itself as well if you want to try on your own (but take it from me, it's a bit troublesome and easy to mess up cables - I repair these for a living). Hope this helps!
Nov 01, 2009 | Apple MacBook Pro Laptop Computer with...
Problem with strating macbook pro (screaming voice)
Hello, this certainly has to deal with your RAM memory. have you installed RAM recently? if not, you can try memtest to test your memory, or take our 1 memory after another, Hope this helps
Jun 11, 2009 | Apple MacBook Pro Notebook
MacBook Pro Black screen and shining sleep indicator
is the battery fully charged? try plugging it in then press the power button again.
Jan 10, 2008 | Apple MacBook Pro PC Notebook
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
157 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
