Plasma TV Reception
Our TV works at one end of our house but not the other end. We have a TV antenna. We even had another antenna put up but still can't get reception.
Jackandy
  • 161 Answers
Bro the reception in that area of the house must be poor, as you've said. The walls in that area of the house must be too thick, or some part of the house is blocking the signal that the attena emits. You should consider getting an antenna that can be placed outside the house, like on the roof top. Make sure it isn't being blocked by anything, like trees with large branches or whatever.
Posted on Jul 22, 2008
TV will not pick up the antenna
the input have to be set to the proper setting for an antenna to get reception .
May 11, 2016 | LG 50PG20 50 in. Plasma HDTV
Is Clear-Cast TV micro antenna device legitimate?
From a basic standpoint, yes it is legitimate and it will work. How well it will work really depends on a number of things. it depends on where in your house you place it, how far you are from the transmitters and what your house is made from. The structure can interfere with reception.
As a general rule, outside is better than inside for over the air digital reception. Higher is also better, so place any antenna as far up on your house as you can outside, next go to the attic space if you can;t mount it outside. And even if you are in a condo or HOA , they have to allow you to mount a TV antenna on your house outside under FCC regulations.
Nov 08, 2014 | Televison & Video
All of a sudden we can't pick up not one channel
Perhaps your tuner is bad. Have you tried reprogramming after you bought new antenna?
Feb 25, 2013 | Channel Master 3020 Large UHFVHF Antenna
Why can't I get reception on my TruTech tv model DW19TT even after plugging in a Phillips digital indoor tv antenna
If the antenna is working and you are not receiving a signal, then you could have a bad tuner, use a tuner from a VCR , connect the ant to the VCR and go from the VCR with Video cables and go to the Video input on the TV and put your TV in Video mode. That will work.
Nov 26, 2011 | Televison & Video
Hi, ihave a plasma TV, sometime ago and it has only been since we moved houses, our TV goes pixelated and then we get No signal on 1-2 channels, and now we have no signal full stop, i have a booster...
You have antenna issues. Try raising the antenna some more or relocating to another spot where the signal strength is greater. Pixelation is a sign of a weak signal -
Jul 02, 2017 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Can my Panasonic TC-P42X1 receive digital channels without an antenna connected? It sounds like a stupid question considering its a high-def TV, but I'm having troubles getting the TV to pick up...
No.Tv can't pick up any reception or receive any free AIR broadcasting tv channels at all if tv have no antena hook up to a tv.Buy a better antena design to used like a Digital atenna,will solved this problems.
Aug 21, 2011 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Just bought a house and moved in. I have plug the TV into the wall antenna socket and the TV comes up with the message 'weak or no signal' what could be the problem?
Hi, congratulation on your new house!
The problem is obviously from your antenna. The TV is not recieving any reception from the antenna and that is why it is displaying 'weak or no signal'.
Cross check your antenna connection and make sure the antenna wire is intact.
Also, most antenna's come with a booster. The booster makes reception from the antenna very strong and the TV would be clear.
Lastly, is this a new antenna or were you using it in your old house?
Please give me a feed back.
Yours sincerely.
Elect_Comp.
May 12, 2011 | Televison & Video
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Jun 15, 2009 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
