Question about Toshiba Satellite A135-S2276 Notebook
Connecting lcd and an external tv box
I have an acer 15" lcd when i am connecting an external tv box the sound comes out but the picture doe not show what is the problem?
  • 129 Answers
You need to press F5 to switch where you are viewing on.
Posted on Jul 21, 2008
I have a proscan model # 32LB30QD it was manufactured in 2008-10-11. I can watch picture just fine but audio only comes out trough the yellow red white chords. not directly from the tv itself. Sad that i...
Without getting too technical, it sounds like you may have an internal connection issue. Have you tried using external speakers with it? That might be ab easy fix.
Nov 28, 2013 | Proscan 32LB30QD 32 in. LCD TV
My flat screen tv/dvd combo has sound but no picture... but when we put a dvd in there, it does show a picture! What could be wrong??? Help!
If u able to have picture watching a dvd,than it not ur tv is the problems.Ur tv connected to a cable,satalite or a Telicom boxes?Unplug,replug these boxes about an hour later,let it reset it self,upgrade it software.Ur tv should have it picture back.
May 21, 2010 | RCA L42WD22 42 in. LCD Television
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
When i press the power button it makes noise and the screen does not show anything
NOise coming from?? Screen do not show anything is Possible problem of LCD, LCD BULB, INVERTER, CPU, MEMORY, OR GRAPHIC CARD. Issue. Try external for make sure if you get picture Your GRAPHIC CARD, MEMORY, CPU is fine.
If sound is coming from FAN system, That is need to be clean(or Change), Or HDD makes sound that is Coming to DUE.
JMC
Aug 15, 2009 | Acer TravelMate 2355 Notebook
I Just connect My pc via 15 pin RGB cable to LG 32R50xx lcd tv,it show the picture but no sound. Than i connect the audio cable to the tv use 3.5mm j. it only has sound when I use input and select AV3 but...
You probably need a audio cable that runs from the pc audio out to the TV audio in. Radio shack has them so do a lot of hardware store and best buy.
Aug 08, 2009 | LG 42LG30 42 in. LCD HDTV
TV is not coming on
If I understand your problem correctly, it sounds like the unit is not coming on... If this is correct, then replace the 3 capacitors on the output side of the power supply. There are 2@1000uF @25V and 1 smaller one which is 220uF@25V.
I think the part number on the board is marked as WX-15/19/20Power-01...
This worked on a 19 curtis LCDVD191
Hope this helps...
Feb 11, 2009 | Curtis LCDVD151A 15 in. HDTV LCD TV TV/DVD...
SHARP 37HV6U No picture until long warmup
Alas, it sounds like something could be quite wrong, or it could be as simple as needing a reset. Unplug the unit, wait a minute then replug it and see what happens.
Aug 28, 2008 | LG 42LC2D 42 in. LCD HDTV
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice mr.reghu@yahoo.com
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Toshiba Satellite A135-S2276 Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
