Question about Canon Office Equipment & Supplies
I have canon Pixma mp780. The scanner does not give me the option where I want to scan. When I press scan only OMNIPage appears to work. I can't have access to the other modes of scanning. What is the problem and how can I fix it? Thanks Nas
  • 1,814 Answers
You need to change the default program that is called when you press the Start button. Right now it is set for OmniPage. Go to this link, and in the Search window in the center of the page type "scan using the buttons". Click the Search button, then click on the "How do I scan using the buttons" link. You will get step-by-step instructions for changing the default program. Select Scan Gear Starter or MP Navigator for most purposes.
Posted on Jul 21, 2008
Own windows 7and no scan with canon prixma MP780
Your MP780 should be able to scan with Windows 7. I presume you can print ok.
Look in your programs for a program called MP Navigator. This is the scanning software Canon use on most of the printer/scanners. If you do not have it then you can download it free from Canons website. Its very simple to use and hopefully that should solve your problem.
Aug 07, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I want to scan a paper and i want to save it as word so that i modify it. How can i do it?
It depends on if you have the full software installed. The MP160 documentation indicates it came wth ScanSoft OmniPage SE. Open MP Navigator and choose this program, you can output the scan as a text file. If you did a custom install, you may or may not have installed the program. If you omitted the program, do a new custom install.
OmniPage is an OCR program and will output to a number of formats (you will choose File, Save as) after scanning. Word can import RTF and most other choices as well as .doc files.
If you don't have the software disc, the software can be obtained from this URL:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Alternatively, there is a free OCR program (simpleOCR.com) that will do the same thing. However it doesn't handle text in columns (newspaper or magazines) very well.
I hope this helps.
Feb 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
How to scan and edit text document
You must use an OCR (Optical Character Recognition) program
Run the "ScanSoft OmniPage" software that came with your printer.
Load the document into the scanner and "acquire" the document through OmniPage.
The pictures will not show up and the text may not be 100% accurate.
Run the resulting document into your wordprocessor (MS Word? or Works?), and run spellcheck.
Oct 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
When i scan on my Canon Pixma MP780 printer i get a red line down
This is what the service manual says:
(1) Clean the Document glass.
(2) Check the connection
between the contact sensor
and SPCNT board (JCCD1).
(3) Replace the SCANNER
unit.
(4) Replace the SPCNT board
***’y.
Jun 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer pixma 780
Press MENU SCAN COPY than SCAN
Cycle throught options until #7 PRINTER
Pres OK
Cycle throught options untill #5 INK ABS CAP
Press OK
Display SUCTION
Enter 0
Press OK
Turn Printer off
Pause
Turn Printer back on
Feb 21, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How do I scan an image from canon pixma mp150
Acquire Text The following instructions will give you the basic instructions to acquire text from a scanned document in Office Word 2007 using OmniPage SE.
  1. Ensure the Canon scanner driver and OmniPage SE are installed and that your scanner has been setup.
    Note: If OmniPage SE is not installed, the required Add-in for Office Word 2007 will not be installed
  2. Place the document(s) to scan on the platen or on the Automatic Document Feeder (ADF) (if applicable).
  3. Open Office Word 2007.
  4. From the ribbon menu, select the 'Add-Ins' tab.
  5. In the Add-Ins tab, click 'OmniPage' and then select 'Acquire Text Settings (OmniPage SE)'.
    The Options window will open.
  6. On the Direct OCR tab, click the 'Image Source' drop-down to select 'Scan'.
  7. Confirm 'Scan' is shown in Image Source section and then click 'OK'.
    The Options window will close and you'll return to Office Word 2007.
  8. Click 'OmniPage' and select 'Acquire Text (OmniPage SE)' to scan your document.
  9. After the document(s) is scanned, make corrections to the text items as appropriate.
I hope it helps!!!
Dec 01, 2008 | Canon imageCLASS MF7480 Laser Printer
How to scan using canon pixma mp150
I hoe it helps!!!
Scanner problem
I presume your new laptop came with Vista and your old one had XP. Either convert your new laptop to XP (complicated but I wish I'd done it when I got my new computer rather than soldiering on with the indescribable rubbish system that is Vista), or install all the latest drivers, and MP Navigator. loads of the other stuff on the canon installation disk just won't work with Vista. If you have Omnipage SE installed, you will have to get an email link from Canon, whose support website leaves a lot to be desired.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=10444
Or go to canon europe whose site is not as good (weird to see Canon not going for the simple idea of global support)
I just bought a new full version of Omnipage, but it does annoy me that so soon after buying the MP780 I had to go to all that trouble.
Nov 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-in-One Printer, etc.
Is this scanner installed onto a Vista computer?
In some cases the scan button may not operate without a memory resident program installed.
It will work by selecting my computer and selecting the scanner on the window. By double clicking on it, it will scan whatever is on the glass.
Aug 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon MP780 wont scan
Download and reinstall scanner software and scan driver
Nov 01, 2007 | Canon PIXMA MP780 All-In-One InkJet...
98 people viewed this question
old marine
old marine
Corne Viljoen
