Question about LG Washing Machines
Lg washer wd1433rd combo washer/dryer won't dry clothes element,thermostat & safety fuse ok.thanks cliff
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Posted on Aug 21, 2009
SOURCE: LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
http://www.motusconnect.com/blog/2009/1/5/lg-washer-dryer-drama-%E2%80%93-diy-fix
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
  1. draining the water.
  2. laying the washer on it's back.
  3. removing the hose clamp on the rubber bellows that connects the drum to the condensing unit (right hand side of machine).
  4. digging the lint wads out with your fingers and a small screwdriver.
Happy drying!
Posted on Feb 01, 2010
Nordmende washer dryer not drying
Check that the heating element is functioning. Check thermostatic cut-out
May 11, 2014 | Equator EZ 3612 CEE Front Load...
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at http://www.lg.com/us/appliances/washer-dryer-combos/LG-WM3431HW.jsp and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
We have a wm3677hw LG washer/dryer combo. it goes into the dry cycle and keeps adding water. what is the problem. we have cleaned all the internal tubes. checked the lower heating element and it is not...
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Dryer not drying cloths even though it does the full cycle? hotpoint wd63
There are several reasons for this to happen.
  1. Heater element faulty.
  2. Thermostat faulty.
  3. Heater relay faulty.
  4. Blocked condenser.
  5. No cold water going in on drying cycle.
You really need a meter to test the components with, to get the bottom of the problem.
Please rate my solution.
Thanks.
Nov 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Dryer will not Dry!
Aug 21, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Smeg wdf1 washer dryer not drying clothes. Wash cycle fine but no heat produced when drying- any idea where to find/check the fuses/elements?
Hi, Take the top cover off and click the little red button on the thermostat/overload (small black box). Then try again. Sometimes these trip out as a safety precaution.
Jun 13, 2009 | Smeg WDF16BAX Front Load Washer / Dryer
Haier Not Drying
most likly to be thermostat if you remove the lid you should see 2 little round thermostats on top somewhere some stats have a reset button on 1 of the thermostats if there is press it if it clicks try it on a dry to see if it works
Sep 21, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Washing Machines Logo
63 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
