Question about Intel Motherboard
Intel Motherboard Problem
My motherboard is intel . when power is ON the the green light indicator is orange, the fan starts,nothing on the monitor, no spanning on the hard disk drive.
  • ezinash Jul 22, 2008
    My hard disk works on other computer i think it is not the problem of hard disk.
Hello ezinash ,
replace ur hard disk with a new one and than try
Posted on Jul 21, 2008
I have a Toshiba satellite L655 - SW5096. went to turn it on but will not start. No fan, no screen. Only the power light indicator and a steady orange light . The orange light goes off if I remove the...
The orange light shows the battery is charging. It will turn green when the battery is fully charged. The white light shows there is power entering the computer.
The usual problem with a computer when there is no response to pressing the power button is that the motherboard has failed requiring the replacement of the motherboard.
If the computer is still under warranty there should be a free motherboard replacement, if not, and you are able to do the replacement, you can find motherboards for sale on various websites. Be aware that motherboard replacement for laptops can be expensive if done by computer repair shops.
Oct 20, 2013 | Intel Motherboard
Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
Apr 23, 2013 | Computers & Internet
Dear sir i have a pc with intel desktop board D865GVHZ.the problem is that when i start the pc its cpu fan is spinning also a green light is glowing bt there is nothing on monitor,this problem also occured...
Most likely the power supply or the motherboard itself is failing, I would start by replacing the power supply. Easy to do and fairly cheap.
How To http://www.hardwaresecrets.com/article/362
Buy http://www.newegg.com/Store/SubCategory.aspx?SubCategory=58&name=Power-Supplies or Buy one in a retail store like Best Buy
Comment back if you need more assistance
Aug 18, 2011 | Intel D865GVHZ Motherboard
A computer with a D101GGC motherboard does not start. There is no beep or monitor singal. The fan is okay. As soon as the power is connected to the computer, the red drive access light comes on, but not...
its a common problem with intel D101GGC motherboard, just open the case and unplug the dvd power cable and data cable, then turn on the PC it will work fine.
Jan 09, 2011 | Intel D101GGC Motherboard
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Green light on monitor flashes
Your operating systems got corrupted. Try re-load option in the setup of windows. Or if you want to you can do a format and a reload
Dec 17, 2009 | Intel Server Board STL2 Motherboard
I have a computer with an Intel D845GEBu2/D845PESV mother board. One day works great, next day no longer powers up. I changed out the PS, all I get is a small green light on the mo bd that lights up...
If all you get is a green light, and no fans, hard drive spin up, nothing on the monitor, well than, it could be that the power supply is the wrong one for your computer. Either that or the motherboard is shot.
double check on the power supply, that is probably the problem.
Aug 05, 2009 | Intel Computers & Internet
Intel Desktop D845PEBT2 could not boot up
i,d suggest that the power cut may have been a surge or spike.
This May have blown your power pack, and caused possible motherboard Damage.
** Did you use the same lead for the PSU** and have you checked the (main fuse in the Plug ? )
If the monitor light remains orange, this is a possible graphics card fault, or driver that is not allowing the monitor to come out of standby mode. You could try installing a different graphics card, or swapping the monitor cable to the on-board graphics card if it has 1.
If none of the above works, assume the motherboard has suffered damage.
Mike @ Compurepair.
Jun 12, 2009 | Intel Desktop Board D845PEBT2 Motherboard
Intel D845EPI Motherboard
I have been asked to clarify my problem, so I'll do that as brief as I can.
The Motherboard CPU Fan starts when the Power Switch pins are shorted together with a screwdriver.
Green lights appear on the Motherboard, but there is NO Screen on the Monitor, No Bios Screen, No Nothing !!!
It stays this way until the Power is removed from the Motherboard.
I hope that this clarifies my problem with this Motherboard for Colliewob. Any suggestions ???
Oct 10, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Monitor will not turn on after booting computer
if you have onboard video try a video card that fits in PCI or AGP slot or try a different video card in place of the one you use
with everything else seeming to be correct this seems like the only thing you have not done
Aug 03, 2008 | Intel Motherboard
Intel Motherboard Logo
29 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
