Mecer Notebook Good day, im having seriuos problems with my notebook. i hope you could help me. the dvd rom works perfectly until i insert a particular cd.... mecer recovery... it just does't pick it up. but when i insert the exact same cd in another desktop mecer computer, it reads it in a flash. what could be the problem. socondly my battery shows its charging by as soon as i unplug the ac power the laptops switches off showing no power. i've looked around in the bios but i cant seem to find the problem.
  • venusladyx Jul 21, 2008
    the disk has work previosly on my notebook and the battery is ractically brand new.
I've got a Mecer Expression notebook. My DVD Rom opens and spins, but the notebook doesn't read it, HELP!!
Posted on Sep 07, 2008
  • 149 Answers
Your Battery is probably dead and can't hold any more charge as for the disc, its probably only made for the desktop computer
Posted on Jul 21, 2008
Cannot eject dvd
Good day,
If it's a dvd rom drive of a PC(personal computer), then get a long, strong thin material like a pin, at least of the length of your index finger. Around/beside the eject button on d dvd rom, you will see a small hole, like d size of a dvd rom led light, insert the thin material thru this hole until you "feel like you are pushing something inside the dvd rom". The dvd rom should open a bit, then you can open it completely to get your dvd.
I hope this helps. Thank you for using FixYa!!
Aug 29, 2012 | Dell (0F146) Internal DVD Drive
I have a notebook 4520G and a couple of days ago after finally sorting out the problems with the graphics card I now find that the drive for the CD rom has totally disappeared. When I inset a disc the...
Hello there is no problem with the driver of your CD rom the problem is in your CD rom. Try to clean your cd rom with a piece of clean cotton. Gentle rub the cotton on the lens of your CD rom, then try to insert a cd if the problem is still there clean it again and again. If does not get by cleaning it is good to be checked by a electronic technician because maybe the lens have a problem or may need an adjustment to the lens of your CD ROm. In ejecting your cd rom there is a problem with your cd rom microswitch which is located inside your CD rom or the trigger of the microswitch is miss align. Hope this can help..
Jul 17, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My dvd cd rom cannot read anything at all
Hi s_francis_sb ,
Please follow the below steps :-
  1. Get a lens cleaner from the market and insert it in your DVD ROM driver , this would help remove the dust particles on the lens which could be a reason for the DVDs not being read.
  2. Remove the lens cleaner from the tray and then insert a clean cd free of any dust in the DVD drive , if this works , then you have your problem resolved.
  3. If the above procedure does not work , then you need to get the lens replaced so that you have a working lens which can read your DVDs perfectly.
  4. If you feel that a new lens would cost you much as compared to a new DVD rom , since they are available cheap these days, you can go for a new one...:)
Hope this helps...:)
May 11, 2011 | HP Compaq 6720s Notebook
A dvd was inserted into my toshiba qosmio right before it broke, and is due back to video store, is there a manual way to remove it?
The dvd drives usually have a small hole on the front. Carefully push the end of a paper clip into the hole and the platter should eject.
Jul 29, 2009 | Toshiba Qosmio G25-AV513 Notebook
Dvd rom not reading cds/dvds
I had similar problem on a Toshiba Satellite A30 laptop, I simply had to reconnect DVD drive. It usually loosing it's connection with motherboard and drive is visible in My Computer but it doesn't recognize any discs. If reconnection does not solve your issue you may try to update your DVD firmware and if it won't help replace DVD drive. Good Luck!
Mar 21, 2009 | Compaq Presario C700T Notebook
Cd/dvd rom not reading
It's likely a laser alignment problem inwhich you will need to replace the hardware. However, I had a similar problem once with a notebook and found out that a tiny bread crumb was near the spindal making the cd in the drive off balance. Check liberally for any debris. Good luck!
Mar 21, 2009 | HP Compaq Presario C700T
CD-ROM
try to check this website, support.toshiba.com. try to download the dvd acoustic silencer for this notebook.
i hope this info helps.
Sep 06, 2008 | Toshiba Satellite M45-S169 Notebook
DVD-Rom's problem! Plz help!
* please check dvd rom cable(ide cable) is connected properly
* check powerconnecter is connected tight
jumper settings:
* set ur hdd as master
* dvd rom as slave in ide1
* set master to dvd writer in ide 2
Jun 19, 2008 | Computers & Internet
Sony Vaio pcg-frv37 dvd rom not working
you need a DVD burner in it to play and Burn DVD's
you have a CD Rom in it now.
Dec 17, 2007 | Sony VAIO FRV37 Notebook
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
