Question about Panasonic DMRE85HEBSM DVD Recorder
DVDRec&HDD The DVD part of the machine is not working properly.IT keeps repeating-SELF CHECK for about 10 minutes before it start to play.
  • brian gibson Sep 17, 2008
    my dmre85h dvd recorder is behaving in the same way.not been able to get it to play dvds for over 6 months now its the same routine over and over i switch on, then goes into self check then instantly cuts off the power then performs this same routine,self check then power off in a continuous never ending cycle. would give anything for a solution before i go stark raving mad staring at a screen going self check,self check,self check.
  • 4 Answers
Are you trying to play DVD+R's? I have the same trouble. It only like DVD-R's and it is picky about which companies DVD's they are also. Don't use generic ones, I guarantee the failure rate will make the money you saved buying them go away quickly.
Posted on Sep 20, 2008
Panasonic dmr xw350
if it uses a SATA hdd it maybe the drive is faulty & is now not booting at all. most will take a normal pc SATA hdd but check what the max size your unit can take as they have there own format & you may make the drive un-usable in a pc again. i would say get a second hand 160 - 250GB drive and try it out. as they are cheap 2nd hand.
Dec 29, 2013 | Televison & Video
Panasonic DMR-E55 doesn't play dvds
if its getting worse, could be the laser is on the way out.get a new one (player)
Oct 03, 2009 | Televison & Video
Self check
Please be a bit more specific if you can. In what way is it repeating itself? And once it comes on does it stay on? It could be a component faulty on the power supply side.
Sep 26, 2008 | Panasonic DMR-E55 DVD Recorder
Cannot start dubbing
I'd guess you are using cable TV-some cable companies put their own copyguard on the cable signal, Comcast, in my area does this. The DVD sees the 'do not copy signal' and won't do it.
Try recording directly to DVD without using the HDD drive. If you get a playable disk, I doubt it is your machine. If you don't get a playable disk, that plays in THAT machine-it is the machine..
Jun 07, 2008 | Televison & Video
DVD player isn't loading and playing properly
Since it will play eventualy, I'd suspect a dirty lens. Open up the unit and carefully clean the lens using a cotton swab and alcohol. Also, try a music CD. If the CD works flawlessly but DVDs still fail occasssionally, the optics are starting to fail and will need to be replaced.
Dan
May 13, 2008 | Samsung HC-P4363W 43 in. TV/DVD Combo
I have a Panasonic EH100 HDD/DVD recorder. Yesterday I left it on for several hours playing a DVD when I realised I switched it off. Shortly afterwards I turned it on to watch a program and it went into a...
Holding certain buttons down at power up can activate unintended test modes. Wrong sequence can lock up processor! Unplug and let sit for 24 hours to re-set processor. Turn set on as normal. If you can, remove DVD before this procedure to avoid reading at start up
Apr 21, 2008 | Televison & Video
DVD Burner will not read disks.
Hi ****,
I've one of these machines too, and you've stumbled upon the one flaw that lets the machine down. In my experience the only way to solve this is to:
1/ Eject the DVD
2/ Turn the machine off (standby mode)
3/ Unplug from the wall for at least a minute or 2
4/ Reconnect the machine, leave it at least a minute in standby mode.
5/ Attempt to play a known 'good' (commercial) DVD
This usually works although I have occasionally had to repeat the process. Hope this helps, regards,
Lone Starr
(Rust Never Sleeps)
Mar 16, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Plays for a minute or two - then just shuts itself off
Mine will intermittently record only the first minute or two of a tv show I have queued up to regularly record. It seems to happen anywhere from every show to every 5-10.
Mar 04, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Troubleshooting with the LG HDD/DVD recorder RH277H
I tried the solution documented at
http://www.ifndef.altervista.org/index_eng.html
3:rd Loader repairing
Takes about 15 minutes and its works.
Mar 02, 2008 | Televison & Video
Hdd error
try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Jan 08, 2008 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Panasonic DMRE85HEBSM DVD Recorder Logo
62 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
