Question about HP LaserJet P3005n Printer
Impression lente Impression tr?s tr?s lente sur une imprimante HP 3005 , si nous utilisons l'imprimante en r?seau, elle se plante!
bunnydawg
  • 5158 Answers
SOURCE: Bonjour, je vient de m'acheter
Vous devez retourner à l'emplacement de puissances en chevaux et télécharger les conducteurs aussi bien que l'autre logiciel encore. réinstallez-les… remise à zéro et voyez comment elle disparaît Robert
Posted on Aug 29, 2008
Democritus
  • 120 Answers
SOURCE: je voudrais instaler une imprimante
Installez le logiciel, puis branchez l'imprimante au poste de travail.
Posted on Nov 07, 2008
SOURCE: BONJOUR MONSIEUR :JAI DES PROBLEMES AVEC MON IMPRIMANTE HP500PS
MY DESIGNJET 500 HAVE THE 79:04 ERROR IT WAS JUST CUTTING THE PAPER WHEN THIS OCURR
Posted on Jun 13, 2009
  • 100 Answers
SOURCE: Bonsoir, Description du pb : "Echec système
En anglais - c'est trop longtemps que je parle francais...
The code you mentioned sounds like an Ink System Failure code. My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers. acca299.jpg
Posted on Dec 28, 2010
fanaudi
  • 1381 Answers
SOURCE: bonjour je viens d aquerir
Bonjour , latasca09
L' imprimante est sans doute bloqu?e par un objet ( morceau de papier ) coinc? dans les rouleaux . Je ne suis pas familiaris? avec ce mod?le mais il faudrait enlever le couvercle pour acc?der aux rouleaux et voir ce qui se passe . Un simple bout de papier ( souvent du collant ) suffit ? provoquer la panne .
La m?canique doit ?tre impeccablement propre .
Il faut aussi v?rifier si le pilote correct a ?t? valablement install? , notamment en fonction du syst?me d'exploitation .
Je d?brancherais l' imprimante pour commencer et desinstallerais le logiciel/pilote . Faire ensuite un red?marrage de l' ordi . R?installer le logiciel / pilote et rebrancher l' imprimante apr?s installation .
Attendre confirmation que le pilote a ?t? install? correctement .
Verifier aussi dans le gestionnaire des p?riph?riques s' il n' y pas un probl?me de pilote .
J' esp?re que ceci pourra t' aider .
Cordialement ,
fanaudi .
Posted on Mar 20, 2011
Error code 0xb814728e
Bon je fais mon feedback aussi pour ceux qui ne comprennent pas l'anglais. J'ai ouvert par inadvertance ma HP photosmart a fond, je parle pas du petit couvercle de scan, mais de la grosse ouverture la ou on met les cartouches... et MERDE ! elle voulait plus se refermer ! Surtout ne pas forcer, mais bon en general ca donne l'impression de quelque chose qui bloque, donc une personne normale ne va pas forcer. La solution (que j'ai trouvee sur ce site, merci) c'est de se procurer du WD40, ce lubrifiant bien connu, et d'en arroser les charnieres. En manipulant doucement votre imprimante, vous allez voir, elle va se refermer gentiment au bout de dix minutes. Quel soulagement !
Aug 29, 2013 | HP Photosmart 3310 Printer
BONJOUR JE POSSEDE UNE IMPRIMANTE LASER COULEUR SAMSUNG ELLE NE FONCTIONNE PLUS ET AFFICHE UN MESSAGE D ERREUR SYSTEM ERROR CYCLE POWER QUE PUIS JE FAIRE
Bonjour cevale358 ,
Il n' y a malheureusement pas d' autre solution que de rentrer l' imprimante chez Samsung pour r?paration . Il s' agirait malheureusement d' une panne assez courante sur ce mod?le qui concerne le fusible et l' unit? d' alimantation .. Voici quelques pr?cisions si tu comprends l' anglais ... http://www.fixyourownprinter.com/forums/printer/66821
Cordialement ,
fanaudi .
Aug 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Bonjour je viens d aquerir une imprimante ricoh gx 3000sf sur une vente aux enchere et le probleme que j ai actuellement c que quand j allume mon imprimante elle se met en securite et m indique sur l ecran...
Bonjour , latasca09
Cordialement ,
fanaudi .
Mar 20, 2011 | Ricoh GX3000sf InkJet Printer
Dando erro de SERVICE FUSOR ERROR
S'il vous plaît essayez d'éteindre l'imprimante pendant au moins 30 secondes.
Assurez-vous que l'imprimante est connectée à la prise d'alimentation correcte. Vérifier l'étiquette énergie sur le dos de l'imprimante pour voir si elle fonctionne sur une source 110 ou 220 volts. Vérifiez que la prise d'alimentation correspond à sa tension nominale de travail
Pour plus d'assistance s'il vous plaît contactez le support technique de Lexmark.
Jan 06, 2011 | Lexmark X642e All-In-One Laser Printer
Bonjour, mon problème c'est avec une
j'aurai besoin d'un peu plus d'info sur model de camera,et ce que vous tenter de faire
si la camera est debrancher de l'ordi ,et si l'ordi demarre normalement sans la camera,
vous pouver me contacter par email (aselectronique1@gmail.com.
ainsi on pourra peut-etre trouver une solution je ne comprend pas les #232, 233
merci sicerement alain.
Jan 01, 2011 | Canon Video Cameras
Pas de contacte entre mon ordinateur
Je suis d?sol?, veux-tu dire que l'ordinateur ne peut pas d?tecter l'imprimante?
1. Assurez-vous que vos pilotes d'imprimante sont install?s.
2. Cliquez sur D?marrer-> Panneau de configuration, et d'ouvrir le Gestionnaire de p?riph?riques Syst?me->.
3. Assurez-vous que l'imprimante est connect?e ? l'ordinateur, et qu'il est branch? sur une prise murale qui fonctionne. Allumez-le.
4. Gestionnaire de p?riph?riques Watch, pour voir si elle change / ajoute votre nouvelle imprimante. Si c'est le cas, faites attention ? l'indicateur de p?riph?riques (si l'?l?ment est un code de couleur jaune), et un clic droit sur elle-> choisissez Propri?t?s pour v?rifier l'?tat du p?riph?rique. Il devrait vous donner de plus amples informations s'il ya des probl?mes.
5. Si le Gestionnaire de p?riph?riques ne d?tecte pas l'imprimante, essayez un autre c?ble USB. Si ce c?ble ne fonctionne pas, vous devrez contacter le fabricant de votre imprimante pour le service, que l'imprimante peut ?tre bris?e.
Dec 28, 2010 | Dell 926 All-In-One InkJet Printer
Bonjour, j'ai un problème avec ma MP600. Elle n'imprime plus en noir. Pourtant lorsque je lance une impression noir et blanc elle fonctionne comme si elle imprimait, mais à la sortie, la feuille...
English to French translation bonjour il se pourrait que votre t?te sur votre imprimante est bloqu? aller ? la maintenance de votre imprimante et faire le nettoyage de vos t?tes dans la partie maintenance de votre imprimante, il vous dira everthing comment le faire
Oct 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
On me propose d acheter d occasion une imprimante lexmark x 11500 au prix de 50euro. pouvez vous me dire en fran?ais si c est bien et se ce mod?le va s adapter a mon ordinateur qui est tout simple, de...
D'occasion a mon avis ( j'en ai un ) c'est cher ! mieux vaut en acheter un neuf pour quelques euros de plus - au moins il y a une garantie -
Je vous avertis a l' avance que l'encre est SUPER chere ! mais tout depend de vos besoins - le mien marche bien, pratique, mais finalement pour une copie par exemple, a mon avis, mieux vaut aller a la boutique du coin ! (parce que l' encre est si chere !) - mais ca depanne quand on est presse -
Le scanner marche bien - par contre je ne sais toujours pas comment imprimer les photos sur papier photos... Lexmark ne semble pas avoir d'encre speciale photo - je n'ai pas essaye l'encre normale sur papier photo avec cette imprimante, parce que mes essais avec une autre n'ont pas marche ....
J'espere que ca vus donne une idee ....
Mar 07, 2009 | Lexmark X1150 All-In-One InkJet Printer
Bonjour, je vient de m'acheter une imprimante C4280 et lorsque je l'installe (avec les drivers du site HP) une erreur se produit. Sa me dit qu'il manque 2 clés de registre : slbcsp.dll et sccbase.dll
Aug 27, 2008 | HP Office Equipment & Supplies
HP LaserJet P3005n Printer Logo
237 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
