Question about Panasonic PT-51G36 51" Rear Projection Television
How do I adjust the convergence? - Panasonic PT-51G36 51" Rear Projection Television
  • Panasonic Master
  • 3,459 Answers
How do I adjust the convergence? - 3_24_2012_6_00_06_am.jpg This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Posted on Mar 24, 2012
My projector tv shut off by itseft and no picture and sound
Posted on Feb 18, 2012
  • Panasonic Master
  • 8,457 Answers
Tries auto convergence or manual convergence like line up - + to matches up.If u can't do this the tv have a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Posted on Feb 03, 2011
SOURCE:
Can build up of dust cause the convergence not to adjust properly
Dust will not be a issue with convergence.
Not knowing brand and model and if adjustments were "saved" you could also have a problem in the convergence circuit--chips or other parts.
Brand and model are needed first.
Dec 11, 2012 | Televison & Video
How to fix the convergence on a toshiba TP55D81 tv using the remote control
The convergence is adjusted with the remote by entering a tech menu and adjusting there====if convergence is really bad adjustments are not going to fix it.
The set should have in customer menu a limited convergence adjustment with up to nine points where you can adjust---if it will not adjust there in some way----convergence circuit needs repair.
Mar 16, 2012 | Toshiba TP55F80/81 55" Rear Projection...
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
Tried to auto adjust the guns, will not come within range
Hi Tod,
If colors do not align correctly, most likely you have a convergence failure. This requires replacement of the 2 STK ICs and possibly some low ohm resistors.
Some Toshiba have a Horizontal oscillator/Drive IC failure that results in a small or shrunk picture (2-3" border on all sides). The 3 colors do not align properly because of the reduced Hor drive signal. The convergence adjust controls will work but not allow good adjustment. Convergence is ok, Hor Drive signal is incorrect.
Many do-it-yourselfers mistake the Hor Drive problem in Toshiba RPTV with convergence failure. Too much adjustment of the convergence controls may cause the saved data to be really messed up and require more difficult alignment in the service mode.
If minor or simple adjustments in the customer convergence adjust menu do not fix your problem, there is a fault. Stop adjusting until fault is repaired
Convergence failure can be accurately identified with the Convergence Gallery on our website. Service in Toronto, Ottawa, Calgary, Edmonton and other Canada cities.
easyab
Apr 21, 2010 | Toshiba 42H81 42" Rear Projection...
Adjust Convergence on Zenith B27A11Z
You don't adjust convergence through a service mode on one of these sets. With a conventional CRT, convergence is done by physically adjusting the convergence rings on the neck of the tube, and the position of the deflection yoke near the bell. You would also need a crosshatch generator to provide the required test pattern for adjustment.
Feb 09, 2009 | Zenith B27A11Z 27" TV
Convergence Problem and Contrast Adjustment
Have you checked all of the resistors inthe convergence circuit as well? If not, check them for the correct impedance.. Remember, you have to pull one side of the resistor out of circuit to measure it correctly.
If all of the resistors are good, then you have to do a coarse convergence adjustment on the set through the service menu.. if you need the service manual for the convergence directions, I have one uploaded in the technicians corner of techlore.com
Dec 25, 2008 | Televison & Video
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence off
The convergence board is bad. If the convergence board were still good, then the convergence menu would allow you to adjust the crosshairs.
Mar 03, 2008 | Philips 51PW9303 51" Rear Projection...
Convergence problem
This convergence boar should be available from ptscorp.com. Go to the website, look up the telephone number, and call them and see what a new convergence amp board cost. Good Luck
Jun 15, 2007 | Samsung HCM653W 65" Rear Projection...
Panasonic PT-51G36 51" Rear Projection Television Logo
855 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
