Question about Graco Bedside Bassinet 5840 Crib
One of short side top rails won't click into rigid position. Also now the other sides having clicked rigid won't unclick for folding up. Series 9045,9046
This was a Series 9045, 9046 Pack n Play Bassinet and the solution was to print off the PDF document available on the web and then collapse and reopen the unit carefully following all of the instructions - especially the note about ensuring that both arms are free at each clip.
Posted on Jul 22, 2008
Top short rail won't collapse
Here is a link to the instruction manual for the Pet Pen. i hope it helps you to work out the problem. If that still doesnt' help, you should go back to the place that you bought it and ask them for help
http://www.petgearinc.com/Instructions/33/Product%20Series-PG4200%20PG4400.pdf
Oct 08, 2012 | PetGear Home N Go Pet Pen - Large
How do you lock an Avalon on the move series playpen? Where do I get instructions?
  • These playpens have a safety feature.
  1. First thing is to make sure the center of the playpen is up in the air.
  2. First lock the short side rails. They will click into place.
  3. Now lift up and lock the long set of rails.
  4. Now you want to push the center piece (floor) down all the way.
  5. Now your playpen is set up.
  6. When you go to put it up you will pull the floor up first and then release the side rails.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 17, 2011 | Baby Gear
Cant lock the end rails of the porta-cot, the two side ones lock in fine but the end ones just fold back down. Its a Jeep Sahara Limited XT playland.
Before you lock the bottom of the playard, you need to pull all the way up on the two side rails, they will form a slight arch, and the button will click into place. Then push down on the bottom rails.
Feb 06, 2011 | Kolcraft Jeep Sahara Limited Xt Playard
I have an "07 GMC Denali with manual fold out/
Is this a question? If so, it doesn't ask very much.
Sep 15, 2017 | 2007 GMC Yukon Denali
How do i align head on printer
Hi Good day!! To Align read this
1. Raise the input tray, which you may fold over the top for compact storage. Lower the output tray at the bottom.
2. Slide the "paper-width guide" on the input tray to the left. This is the small, adjustable tab situated where you will place the stack of paper.
3. Load a small stack of paper into the input tray. Make sure short side is forward and the print side is up. For some paper, it makes no difference which side is up. Slide the stack down until it stops.
4. Slide the paper-width guide to the right, snug up against the stack of paper to ensure proper alignment.
Method 2:
1. click start
2. click printer and faxes
3. right click your installed printer and then properties
4. click printing preferences
5. click maintenance tab
there you should see alignment option click it
Thank you for using FixYa
Nov 19, 2010 | Canon PIXMA MP180 All-In-One InkJet...
I can't fold up my Cosco Play Yard 05028. Specifically I get all the sides unlocked but they won't fold up into their upright position (i.e., compact enough to get back into the carry bag.
Hi You have to remove the floorboard and pull up on the strap in the center of the floor before you do anything else, then you unlock the long rails followed by the short rails. If the lock won't release pull center strap higher and try again. Hope that helps!
Oct 06, 2010 | Toys
Can't get sides to stay up (lock) on our Century fold n go lullaby center
I had the same problem until I found the manual and practiced a bit, When opening, it's important for the middle to still be in a high unlocked position - then they click right in place very easily. The sides won't go up if the center column is down too far first because the middle locks in place automatically and prevents movement of the sides.
When folding it, the floor lock has to be twisted fully in the unlock position and the center column back up in a high position for the sides to fold in (each side as 2 joints to disengage). Unlocking turns the center support column so that all the support tubing underneath can move. If the center column won't come up high, you don't have it unlocked yet.
Here's a Century Fold N Go instruction manual.
http://www.gracobaby.com/Instruction%20Manuals/archive/10765.pdf'
To look for different models
http://www.gracobaby.com/customerservice/productinstructions/Pages/default.aspx
Jul 28, 2009 | Baby Gear
How do the side rails of a eddie bauer play yard stay up?
I have this the Eddie Bauer Pack & Play too. The directions says it doesn't matter which sides you pull up first but it does... you have to first pull up the 2 short sides, then you can pull up the long sides and push the button on the bottom to get the whole thing secure.
Hope this helps!
Jaime
Nov 17, 2008 | Baby Gear
Folding up Cosco play yard
you also need to hold one of the middle indicator tabs on the longer side..because if you don't do that it will not shut... and make sure the 2 legs go inside with the center of the play pen
Dec 03, 2007 | Cosco Beatrix Potter Playard Crib
Graco Bedside Bassinet 5840 Crib Logo
370 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
