Question about Vector 20 Million Power Series Spotlight
Problem with my spotlight
I have change battery few time and it still not working
please help
  • rHirsh Nov 07, 2008
    After one charge the light would not charge anymore.
  • happi75 Jan 10, 2009
    I plug in the charger and the red light on the side of the spotlight, flashes, and it wont charge. anyone know WHY??? the red light on the side would flash?
I HAVE TO 20,000,000 SPORT SPOT AND NEED TO KNOW HOW TO REMOVE THE LENS COVER TO CHANGE THE LIGHT BULB
Posted on Oct 29, 2008
    New Friend:
    Problem Solver:
  • 7 Answers
You must replace a new one and you can find some good ones in b2cled.com
Posted on Apr 08, 2013
FULL CHARGE LAST 5MIN. MAX
My guess is the batteries are probably no good. All batteries will only last so long and it also depends how often they are keep charged and discharged. Basically all batteries require some kind of maintenance (recharging / discharging).
Jan 23, 2013 | SPOT SL5W09 Spot Light
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
My Vector Flash light is not working, I have tried to fix localy in Santa Barbara, but was unable, there is a place to send them to be fixed, my model is Sport Spot 3 million, thanks
Baccus just bought Vector from Black & Decker (Sept. 2010)
Looks like flashlight model # VEC 139BW but a different color. (Mine is White w/blue trim.) There is a battery in the top & one in the bottom, replace them at the same time. If I can find several battery stores in Buffalo you should be able to find a local battery store there.
Baccus- 877-571-2391 for main beam, area light no longer available. Try to find local distributor & save shipping charges.
Sep 23, 2010 | Vector 3 Million Candlepower Rechargeable...
I have a 80 series landcruiser done the spotlights but thay keep blowing my head light fuse the wires are 2 times bigger than the ipf kit
The fuse has a lower AMP that is why it is blown every time you switch on the spotlights. In order for the fuse not to be blown, my suggestion is try the direct connection on the spotlights. Connect the spotlight directly to the battery. Just put a switch on it. If you want to use the spotlights, just press the switch.
Jun 26, 2010 | Cars & Trucks
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
Need replacement battery for spotlight
You can purchase a battery from Black and Decker, they purchased Vectorlite in 2006, here is the link, you will need to enter the model #
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Jun 10, 2010 | Vector 1 Million Rechargeable Spotlight
Coleman Spotlight PML8000 lasts only a few minutes when charged
your battery is gone. chk with coleman for replacement
Dec 13, 2009 | Cars & Trucks
Will not hold a charge...Looking for a replacement battery? Any Ideas?
http://cgi.ebay.com/VECTOR-1-MILLION-CANDLE-POWER-SPOTLIGHT-FLUORESCENT-NEW_W0QQitemZ220469526499QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item335501ffe3&_trksid=p3286.c0.m14
Aug 31, 2009 | Vector 1 Million Rechargeable Spotlight
Spot light is unable to recharge with the wall
While it could be the battery, it could also be the internal charger in the spotlight. When you plug it in, it bypasses the charger and uses the connected power. However, it is likely just a bad battery. The batteries only last 3 years in an ideal setting and since these lights are typically only used certain times of the year, the batteries discharge and go bad. New batteries can be found at: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Jul 18, 2009 | Vector 3 Million Candlepower Rechargeable...
Vector 20 Million Power Series Spotlight Logo
627 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
