Question about Ovens
Basic elec oven indicator light tripped electrics??
When I put the power back on the oven seems to workd fine but is it? will it over heat, is it connected to the thermostat???
Cannot offord to fix, very worried to use
Please help, thankyou very much
  • gwathome1000 Jul 21, 2008
    Hi, sorry,
    Thankyou for comeing back so quickly.
    I was cooking a meal and the oven blew the fuse box, when I turned everything back on the little red indicator light wasnt working so I dont know if the over will overheat? is the indicator light important will the thermostat still work? **** just a single oven with four top plates electric, Teba E50W.
    I just need to know if it is safe to use and it wont overheat??
    Thank you very much for your help.
    Georgina
  • douglas smith May 11, 2010
    please can you explain your problem a bit clearer - can't see what you are worried about.
  • 95 Answers
Should be safe to use, but it sounds as if a number of things are going on. First the breaker tripping is a sign that too much of a strain on power is happening. If all oven elements are on and the oven at say 450 is tripping the breaker, make sure that grease has not gotten into the elements, and that they are in good shape. The breaker or chord or outlet may be going bad. You need to visually inspect all
Posted on Jul 21, 2008
The oven was on and working..then the electric tripped and all power went off...after putting the switch back up on the fuse box everything on the oven started working but it does not get...
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please How to Video Tutorials on Domestic Appliances
Mar 04, 2011 | Zanussi ZBF260 Electric Single Oven
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Oven will not heat when turned on
Hi. Check to make sure the electrical breaker is not tripped. Find the breaker box and inside you will find several black switched called "breakers" and you possibly may have one that is in the center position, indicating it has been "tripped". To resolve this, flip the switch to the "OFF" position then back to on. See if your oven heats now. If not heating, unplag the stove, wait 5 minutesm then plug it back in and see if it heats. If still no heat, most likely the power came back on with a slight "surge" and may have damaged the control board for the oven. If that is the case, you will need to have the oven serviced. Thanks and hope this helps!
Apr 26, 2010 | Verona BIG24 Gas Single Oven
Fan not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 12, 2010 | Zanussi ZBQ665 Electric Single Oven
Electric warming drawer will not heat
Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
Feb 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Smeg oven problem
The pop would usually mean a busted fuse. Turn off the oven, disconnect completely from the power supply and then take it apart. See if you can find any toasted fuse or roasted wires. Also the reason for tripping the mains off is due to the fact that the oven is draining more power than it should. I would recommend a thorough inspection of the oven by an electrician..
Jun 18, 2008 | Smeg SE399X/5 Stainless Steel Electric...
SA999X wont turn off & smells
suspect your electrician wired it up wrong
Feb 20, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
Hotpoint BU62 bouble oven
sounds like the bott oven element has gone, or faulty thermostat.
Dec 09, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Oven not heating up properly
You could very well have an electrical problem. You may not be getting the full 220 volts needed to make the oven function correctly. Call a local appliance technician or electrician for service.
Dec 28, 2006 | GE Profile JTP56 Electric Double Oven
Ovens Logo
124 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
