My desktop access is declined. i dont know why. i cant even create a folder or paste a folder in desktop. I am using windows xp service pack 2 genuine version.
  • 64 Answers
Try running a check disk by clicking on Start-->Run then typing in chkdsk /f and clicking OK. Once it's completed, try creating a folder.
Posted on Jul 21, 2008
Networking please guyz how can i share files, printer and scaner between two PC runing window xp (service pack 2) using lan protocol
Turn on File and Print sharing. You will see a hand sharing icon on printers. You then need to create shares for individual folders you want to share by right clicking on folder. Then use the share name to access. Example: \\computer_name\share_name
Oct 24, 2012 | Computers & Internet
Everytime i start my computer.. there is always a window on the upper left that says: personalizing settings setting up personalized settings for: C:\WINDOWS\system32\Wndiir\WinLoad.exe restart i can't...
If you haven't done it already, load Service Pack 3 along with the Windows updates. That will stop that.
SP3 is no longer available from Microsoft as it does not support XP anymore. Beware of where you download SP3 from, make sure you have a proper anti virus programme installed!
Jan 01, 2011 | HP Computers & Internet
Hi, I have two pc running with windows xp operating system. From User 1 i need to access user 2 windows folder and program files folder otherway around also but I can't how? Even if I shared windows folder...
First thing Windows XP Home Edition will give you numerous problems when sharing files, you should consider using windows XP Pro for that sort of operations.
Assuming you have Windows XP Pro installed in both computers:
1 - Create the same user on both computers ( same account name, same password ) blank passwords are not allow between file sharing as per windows xp group policy.
2 - Create a resource to share ( example: C:\)
3 - Disable simple file sharing
* go to control panel
* click on folder options
* click the VIEW tab
* unckeck the use sharing wizard
4 - Make sure that the user that will be used for authenticating between computers have the proper NTFS permissions and the proper access to the shared sources.
5 - Try to connect to the shared sources when asked for username and password type the credentials of the newly created user.
Now you should be able to connect to the shared sources both ways.
Oct 18, 2010 | Computers & Internet
How i can make a bootable Windows CD for my personal use
Create a temporary working folder at the root (top) of the C: drive called "XPSETUP" (without the quotes). Actually, you can name it anything you want and put it anywhere you like, but for ease of explanation, the remainder of the steps below will assume that you have created the XPSETUP folder in the root of drive C:. This C:\XPSETUP folder will be where you will create the CDROM directory structure for your bootable Windows CD.
Copy the entire C:\I386 to C:\XPSETUP. When you have finished, you will have C:\XPSETUP\I386. Notice that I said "copy", not "move". Do NOT drag and drop the I386 folder into the XPSETUP directory. If you do so, you may end up moving it into the XPSETUP folder (depending on where you created the XPSETUP folder). It is important to work from a copy of the I386 directory so that if you make mistakes, you can simply go back and start all over again. If you move the directory or drag and drop it, and you make a mistake, your mistake will be permanent. So once again, COPY the entire I386 folder to XPSETUP. It may take a while for the copy operation to complete, but it's safer this way.
If you're not sure how to copy, follow the following procedure: Highlight the I386 folder using Windows Explorer. Right-click the folder and select "Copy". Then open the XPSETUP folder. The folder should be empty at the moment. Right click the empty space in the window and click "Paste". A very lengthy copy procedure will take place.
To verify that you have copied the folder and not moved it, return to the top of C: and check that the I386 folder is still there and that the original files in that folder are still there.
Create an ASCII text file with only the word "Windows " (without the quotes and including the final space after the word "Windows") in it, followed by a new line. To do this, open up Notepad. Notepad can be found in your Start menu -> Programs -> Accessories -> Notepad. Type the word "Windows" without the quotes and following my case exactly (that is, "W" is a capital letter and the rest are in small letters). Then type one additional space. Finally, hit the ENTER key. Do not add anything else to this file. Do not change anything - for example, do not type everything in capital letters or anything like that. The contents of the file must be exactly as I said, or Windows setup will issue an error message.
Save the file with the filename "WIN51" (include the quotes so that Notepad will not add a ".txt" extension behind your back) in C:\XPSETUP. Again, the filename's spelling and case must be exactly like mine.
If your PC or laptop originally came with XP Home, make a copy of the file you just created and call it "WIN51IC". If you are using XP Home Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IC" and "WIN51IC.SP1". If you are using XP Home Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IC", "WIN51IC.SP1" and "WIN51IC.SP2". All the copies of the files should be in C:\XPSETUP.
If your PC or laptop originally came with XP Professional, make a copy of the file you just created and call it "WIN51IP". If you are using XP Professional Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IP" and "WIN51IP.SP1". If you are using XP Professional Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IP", "WIN51IP.SP1" and "WIN51IP.SP2". All the copies of the files should be in C:\XPSETUP.
Note carefully what I said above. You may be running XP SP 2 now, but if your PC came with XP SP 1, you should create the files for XP SP 1. There is an exception to this. If your PC or laptop came with XP or XP SP 1, but you want your Windows install CD to install XP SP 2, create the WIN51 files needed for SP 2 and follow the procedure for slipstreaming Windows service pack 2 (SP 2) into the Windows setup CDROM given in the next step.
If your PC or laptop came originally with XP or XP SP 1 (service pack 1) but you want your Windows setup disk to install XP SP 2, do the following. Otherwise, skip to the next step.
Note that even if you have since updated your computer to SP 2, you will still need to do this step if you want your setup CD to install Windows XP Service Pack 2. The reason is that updating your running Windows system does not automatically update the I386 directory. Your I386 directory still contains the Windows setup files belonging to whatever version of Windows you had when you first bought your PC/laptop.
Download Windows XP service pack 2 from http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en Save it anywhere you like except in the C:\XPSETUP folder. For the purpose of this tutorial, I will assume you saved it as C:\XPSP2.EXE, that is, in the root folder with the filename "XPSP2.EXE".
Important: if you did not configure Windows to show you the full filename you should probably do so before changing the name of the file. Otherwise, you may be inadvertently saving the file as "XPSP2.EXE.EXE" without your knowing. (That is, you see the filename as "XPSP2.EXE" in Windows Explorer but it's actually "XPSP2.EXE.EXE".)
You will need to update the C:\XPSETUP\I386 folder to contain the updated SP 2 files. As a side benefit, the service pack 2 updater will also create a few files (including setup.exe) in the C:\XPSETUP folder. This process of integrating the service pack files into the original XP or XP SP 1 is known as "slipstreaming".
To slipstream SP 2, first open up a command prompt. To do this, click the Start menu, select the Run menu item, and enter the words "cmd". Click the OK button. A black command prompt window will open.
Enter the following line into the window and press the ENTER key.
C:\XPSP2.EXE /integrate:C:\XPSETUP
After the program finishes, you can close the command prompt window. If you look into your XPSETUP folder, you will notice a few new files there.
At this point, the C:\XPSETUP directory contains all the files that will be copied to your Windows Setup CDROM. Don't worry if the directory does not contain files like "setup.exe" which you see on the retail CDROMs. You won't need it for a fresh install from the bootable CDROM. Note: You will only have "setup.exe" if you had to slipstream Service Pack 2 as mentioned earlier. The Service Pack 2 slipstreamer creates setup.exe for you.
Now open the wxp10.zip file that you downloaded earlier. Simply doubleclicking it in Windows explorer should do the trick. Go into the cds directory and into wxphome (or wxppro; it doesn't matter which) directory, followed by the files directory. Drag the "w2ksect.bin" file into C:\ (the root directory/folder of drive C:). Don't get creative and place it in some other directory. If you do that, ImgBurn will not be able to find c:\w2ksect.bin later.
You could do all that OR simply download an XP LIVE DVD.. This will  bootup from DVD and work without using/installing to the Hard Drive.
here is the torrent DL link No torrent?  Here > http://www.utorrent.com/
DL and install.. then click on torrent link and it will DL.
http://thepiratebay.org/torrent/3820108/Windows_XP_Live_Edition(Run_Windows_from_CD)
here is a link how to make it.
http://www.intowindows.com/how-to-create-live-usbcddvd-of-vistaxp/
Feb 01, 2010 | Microsoft Windows XP Professional SP2
Service packs not cleaning up properly
(sited from http://www.winxptutor.com/randomfolders.htm)
When you install Windows XP SP1, SP1a or SP2, this temporary folder is created on the volume that has the most free space. The folder name contains random characters, and is not always created on the same volume as the Windows folder. For example, this temporary folder may have the following random names:
9470bb12e8a4f3447657236478e41c5
or similar.
352b81d1c4bf3810e28482d9979
This folder is automatically deleted by Windows XP after you install the service pack. However, if the folder is not automatically deleted by Windows XP, you can safely delete this folder.
Please Note:
In most cases, you will receive an Access denied message while accessing or deleting this folder. First, you'll need to Take Ownership of the folder and then delete it safely.
May 21, 2009 | Microsoft Windows XP Professional With...
Boot DVD
you dont need to slipstream the disc with SP 2 or SP 3 but if you want to you can following this guide :
Guide on how to slipstream windows xp with a service pack of your choice
If you get stuck let me know
But basically you create 2 folders on your C drive or on your desktop call one xp disc and the other one service pack
copy everything from the xp disc into the xp disc folder and then download and install iso buster ( download link )
And extract the img file as per the guide and then follow the burning instructions with regards to adding the img file using nero or a burning application. If you dont have nero and want to know how to use the img to make it bootable post back with what burning software you have and what version it is and I will find and post back with a relevant guide
Apr 08, 2009 | HP LightScribe dvd640i (DVD640I)...
Could not select "show hidden files & folders" in folders option
go to system registry.......click start then run and type regedit then find this key HKEY_ LOCAL_MACHINE software microsoft windows current version explorer advanced folder hidden showall
in your right pane show it DWORD key of CheckedValue delete it.....and create new DWORD key and give the name CheckedValue and enter 1 into value data.......
restart your pc..........
good luck.........
The best earn money site..plz signup free
http://bux.to/?r=jiteshright
(Join now and receive a $0.05 Sign-up Bonus)........click on it........
Jul 30, 2008 | Microsoft Windows XP Professional for PC
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
helo frind
1. Windows Xp installation disk
2. Access to PC with working CD Cd-ROM DVD drive.
3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software
Let's start.
1. Download solution.rar file
2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
3. Put your pendrive ( at least 1GB) into working PC USB port
4. Go to the folder C:\Dos and run HpUSBformat.exe file
- it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
- set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it.
5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
- your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
good_lk
Oct 12, 2007 | Microsoft Windows XP Professional With...
How to create a bootable xp service pack 2 cd
To create bootable disk follow the steps: 1)Enter floppy disk or cd in your dvd/cd drive. 2)You can create boot disk by using Nero CD Burning software or other software with which you burn your cd or dvd. 3) to create with windows xp go to http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=FBE5E4FC-695F-43E5-AF05-719F45C382A4 Or carry out the following steps: Using Windows XP, place a blank floppy in drive A and format the disk. Navigate to the root folder of the system (in most cases this will be C:\) and copy the following files to the floppy disk. Boot.ini NTLDR Ntdetect.com If you can't see the files, click [Tools] and [Folder Options...] in the Menu Bar of Windows Explorer. Click the [View] tab and click the radio button next to [Show Hidden Files and Folders]. Remove the check mark next to [Hide Protected Operating System Files (Recommended)] then click [Apply] and [OK]. The files should now be visible in Windows Explorer. If the files still cannot be copied, right click each file, click [Properties] and remove the checkmark from the Read-Only attributes. Reset whatever attributes were unchecked after the copy procedure is completed. In addition to the files listed above, check the same directory for bootsect.dos and ntbootdd.sys files. If they are present on your system, copy them to the same floppy diskette. The disk is used as any other boot disk, inserting it into the floppy drive (A:\) and initiating a cold boot. Make sure the BIOS is set so that the A:\ drive is first in the boot sequence.
Sep 28, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
