Question about Philips 46PP9302 46" Rear Projection Television
PHILIPS 46 IN REAR PROJECTION ---- no picture, chirping
Tv is approximately 6-8 years old. had a Sears wty that we had to keep purchasing because the tv broke down every year. we cancelled our wty last year. always breaks down around january or march. united radio has always come to work on it. have replace boards. last time this happened i asked why the same board would go again and they said it was a different board this time, which we felt was odd. TV picture goes - black, no sound other than a chirping noise. is this something we can fix ourselves - we've spent more in service contracts over the years than we did for the tv!!!!!! Same problem on my 46 as well.
I believe the chirping to be coming from a Diode #6304 on the Large Signal Board, but i'm not sure what to replace. I could replace Cap # 2313, but not sure. Anybody fixed one yet??
Cheers,
Greg
  • 4 more comments
  • greglamont Jul 21, 2008
    Just to clarify, my set is a 46PP862/79 (Australian Model) - a DPTV325 Chassis.
    I already have the Service Manual, but need a little more guidance on where and what to look at next. Power supply is good.
    Cheers,
    Greg
    Any more details somebody can share with me?
    Replacing the Large Signal Board is an option. I'll contact Philips Australia to get a quote on price, but guessing it could be a little scary!! This seems to be a common fault with this model. Has anybody worked on and fixed this fault??
    Yes VOTIT, I do have the complete Service Manual with schematics.
    "jithinantony" just posted "try to check the circuit board". There's an interesting thought!!
    Thanks Dan,
    VOTIT just suggested the HOT as well. I have been over the board looking for bad resistors and solder joints, touched up a few but still nothing.
    I have uploaded the service manual to :
    http://www.server382.com/download/Philip...
    Will leave it there for a few days.
    Thanks again for your help.
    Cheers,
    Greg
  • Philips Master
  • 3,459 Answers
Its the HVG - AKA Flyback. You can get a new one for around 130.00
Posted on Nov 28, 2008
  • 4,234 Answers
The "chirping" is usually a sign that the power supply is attempting to startup and is failing. This can be cause by a number of things. Check the common failure items first:
1) Horizontal Output Transistor. This is mounted onto a heatsink and is located close to the flyback transformer (part with large red wire out the top).
2) Check for cold solder joints - Look at the modules and resolder any joints that appear grainy or have rings.
3) Check the area of the convergence ICs for Pico fuses or low valued resistors. If the fuses are blown or the resistors appear to be burned, that is an indication that the convergence ICs are bad and could be drawing down the power supply.
I don't have access to Austrailian models, so I can't give you any more details. If the service manual is available electronically, I'd be happy to look at it and give you more specifics.
Dan
Posted on Jul 21, 2008
  • ABRsvcs Jul 21, 2008
    I'll look over the manual tonight and update this in the AM.
    Dan
  • 105 Answers
Try to check the circuit board
  • 38 Answers
I would suggest replacing the whole Large Signal Board.  It is very hard to identify exactly where the problem is and would probably waste more of your time and money
  • 2,071 Answers
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is,and it is caused of chirping sound....
  • 2 more comments
  • LORETO LACARON
    LORETO LACARON Jul 21, 2008
    is your manual like this have a schematic diagram so i know the voltage out at the last page of this manual has a schematic...
    Training Toshiba PLASMA TV PDP 42WP37
  • LORETO LACARON
    Somehow I can't help but think that
    you have a shorted Horizontal Output Transistor (H.O.T.). It's easily
    replaceable if you can identify which transistor is the H.O.T. (BTW, it's
    usually installed with a heatsink if you care to look). If you decide to
    replace it yourself then DO NOT USE A GENERIC REPLACEMENT!!!!!! Using some
    cheap knockoff is likely to not do the job and you'll just be wasting money.
    Insist on using only the genuine Magnavox part number.
    Click below for the picture of (
    HOT) transistor of PHILIPS magnavox….
  • LORETO LACARON
    i forgot to paste the (HOT) transistor,find this transistor with heat sink...
    Phillips F8 chassis
  • LORETO LACARON
    LORETO LACARON Sep 02, 2008
Have phillips 60 in. rear projection tv have power no picture no sound just green light
If its chirping contantly when powered on take a look at the chirping tv repair kit on the site www.TvRepairKits.com
If its not chirping the next most common failure is the flyback
Apr 14, 2013 | Philips Magnavox 9P6034C 60" Rear...
Problem with picture on wide sreen TV
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Philips 46PP9302 has no picture and is making a chirping sound within the case.
I had this exact same issue after I attempted to replace the convergence chips on my Philips 51PP9303H/17. It turns out my solder was not complete around all the pins, like I had missed a few spots. Once I corrected that and made sure each pin was completely soldered around the pin, my issue with the no picture and chirping sound went away. So if you were working on the TV's circuit board prior to this happening, I would say to double and triple check your soldering. If it just happened on its own, then it seems the solder cracked somewhere on the circuit board resulting in one of the components to loose its full connection and functionality. I hope this helps...
Jan 06, 2010 | Philips 46PP9302 46" Rear Projection...
Tv turns on then right back off
Does if make a chirp sound? If so see below...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
Jan 04, 2010 | Philips 46PP9302 46" Rear Projection...
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My philips 46pp9302 makes a chirping sound when i power it on and nothing comes on the screen.
sounds like a common problem that a kit is available from a place that has tv repair kits, you can Google it and look it up .
larry dillon
Aug 01, 2009 | Philips 46PP9302 46" Rear Projection...
Turn on TV no sound or picture just chirps
Get the chirping TV repair kit from www.TvRepairKits.com to fix this problem
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Beeping noise when I turn on my TV
www.TvRepairKits.com just added a kit for the "chirping set" problem.
Hope this helps,
Dec 03, 2008 | Philips 46PP9302 46" Rear Projection...
My Philips 46PP9302 46 in is making a chirping sound
A cheaper way is a DIY but it seems like this failure is not a DIY.
I would say that for a 5 years old TV that has been fixed twice and requires a repair again, I would save the $500.00 to buy a new TV instead of fixing this one.
Good luck.
Jul 29, 2008 | Televison & Video
Philips 46PP9302 46" Rear Projection Television Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
