Question about Microsoft Windows Vista Ultimate Edition
Software is there any software which help in vista , all the dos programes run in full screen?
  • 21 Answers
You could try using DOSBox.
DOSBox is located on the Web at : http://www.dosbox.com/
You can download DOSBox at: http://www.dosbox.com/download.php?main=1
Hope this helps. Thanks!
Sincere-One
Posted on Jul 21, 2008
Need to change video display in Autocad running in DOS
Hit the "Alt" and "Enter" keys at the same time while in the full screen window. This will change the full screen to a window.
Right click the blue bar at the top of the window. Choose "Properties." Click on the "Options" tab. Make sure the setting is on "Window" rather than "Full Screen."
Click "OK." When you are prompted with save options, choose "Save Properties for Future Windows with Same Title."
Change the properties for the general command prompt. Click the "Start" button. Click "Programs" and "Accessories." Right click the "Command Prompt" icon.
Navigate to "Properties." Choose the "Options" tab. Check the button next to "Window" instead of "Full Screen." Click "Apply," then "OK."
Use the mouse to right click on a DOS program's shortcut. Choose "Properties." Select "Options." Under "Display Options," select "Window." Click "Apply" and "OK."
Open the command prompt or your DOS shortcut. Right click on the blue bar. Click "Properties" and go to the "Layout" tab. Under "Window Size," use the arrows to increase the height and width of the window. Click "OK," click "Modify Shortcut That Started This Window" and click "OK."
Custom Car Parts
Jun 06, 2012 | Autodesk Computers & Internet
How to Run Turbo Pascal Full Screen mode on Windows 7
Now that's a program I've not worked with in a while ;-) I haven't used it since my early high school days in the 1990s. Turbo is a really old application that has been around for ages- unfortunately, being as such, it is only capable of developing 16-bit DOS applications, which has, for better or worse, gone the way of the dinosaur. In the x64-bit versions of Windows Vista and 7, all 16-bit native support has actually gone out the window in favor of 32-bit and 64-bit application development. This is why DosBox was invented- it is a true 16-bit DOS environment (much like command.com and CMD.exe used to be) that is capable of running all the older DOS programs that are no longer compatible with Windows.
When you run Turbo from the DOSbox program, press ALT-ENTER and it will fullscreen whatever you're working with.
Hope this helps,
- Vern
Mar 24, 2012 | Computers & Internet
Turbo c is not working in full screen in windows 7. Please let me know if you know the Soluation.
Vista and upwards do not support full screen for DOS applications. If you need to use it in full screen mode, use DOS BOX. But it will crash if you perform pointer or memory based operations.
Oct 02, 2009 | Dell Inspiron 1501 Notebook
How to run turboc in full screen in windows vista ultimate
Windows Vista And above doest not support full screen command window.. In order to run dos programs in full screen mode u can you use dosbox emulator which will be more convenient. Note that if you use pointers in your program it may not wok under vista directly.. If u run under the dosbox emulation it will work fine.. You can download dosbox from http://www.softpedia.com/get/Programming/Other-Programming-Files/DOSBox.shtml
Sep 22, 2009 | Microsoft Windows Vista Ultimate Edition
C language is not running in full screen mode
Windows Vista takes away a lot of support and convenience for the sheer attractive of flashy user interface. One major feature is the ability of open full screen window for command prompt shell in Windows Vista. When you attempt open or run DOS .com applications, .bat batch scripts or games that relies on command prompt, and including cmd.exe itself, you will encounter the following error message:
This system does not support fullscreen mode. Choose “Close” to terminate the application.
The lack of support for full screen DOS command prompt in Windows Vista is a big annoyance especially for those who still playing games for DOS and Windows 3.1/9x era, use legacy software such as WPDOS or programmers who frequently switch to command prompt to use DOS based programming language such as PASCAL.
There is no simple solution to this no support for full screen window in Windows Vista. In almost all possible workarounds, you are almost guaranteed that your Vista will be broken in some way, at least on the part on Windows Aero. You will lose the nice Aero Glass interface if you attempt any of these trick, plus other unknown side effects.
Workaround to Run or Open Full Screen Window Mode
Workaround 1: Use XDDM driver instead of WDDM driver for video graphics adapter
In another word, install the Windows XP video card driver for use in Vista. If the video graphics card hardware supports Windows XP driver, you can download the Windows XP driver for your video hardware and install it under Vista. However, be warned that using XP driver on display adapter may crash your Vista system randomly, so save your works before proceeding and use with care.
Note: This solution has been recommended by Microsoft in KB926657.
To install a Windows XP video driver under Vista, just follow the procedure listed in the guide below. The steps should work for both NVIDIA and ATI video graphics accelerator card.
Download the Windows XP driver installer for your graphics card from NVIDIA or ATI. Run the installation setup program just downloaded. Confirm any User Account Control permission warning when prompted. The installer will first extract and unpack the files required by installation to proceed to a folder/directory. Note down the path to the folder. For ATI, the folder for these installation files usually located in a directory with a name that resembles C:\ATI\SUPPORT\7-5_xp_dd_46743\Driver or C:\ATI\SUPPORT\7-5_xp_dd_ccc_wdm_46743\Driver, with the only different been the number to indicate the version and build number of the driver
Jul 31, 2009 | Computers & Internet
How to run turbo c in full screen in vista?
run it in the safe mode access usind dos prompt commands
Jul 18, 2009 | Sony Computers & Internet
Turbo-c++ is not installed in full screen
Hi sagar,
Turbo C++ 3.0 is made for MS DOS 6.22 environment. In windows also we can run Turbo C because windows environment provides all native services of DOS. But in Windows VISTA some of the services are revoked. So to enable them either Vista is to be reconfigured or some add-ins are to me installed.
Other versions those can work in Vista are BOROLAND C++ 4.5, VISUAL C++ 6.0, and Visual Studio 2008. But in all these the graphics header file <graphics.h> will not work. Try to find an appropriate graphics header file or copy graphics.h in the cource directory and use #include "graphics.h" command in your C Program.
Please revert to me if having problems.
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Jan 31, 2009 | Microsoft Windows Vista Ultimate Edition
Graphics devlopment
sorry vishu Micro Soft Vista is not going to support full screen DOS mode in any mean.
Thanks
Iqbal
Mar 30, 2008 | Microsoft Windows Vista Ultimate Edition
Looking for a vista compatible c/c++ compiler
As 32 bit vista does not support full screen 16 bit plarforms(like c/c++) nd not at all suportable by 64 bit vista. to install u have to install the display drivers of XP, that can be found at the site of the manufacturer of ur Laptop/PC(in some cases graphics card manufacturer). All the best...., further having any query , pLz fell free 2 ask
Mar 05, 2008 | Microsoft Windows Vista Ultimate Edition
Software compatibility
Hi san, many of vista's problems can be resloved by useing there combatilty mode, its in the properties if you right click on the programe. Make sure to click "Run this program in XP SP2" and "run as administaror" are checked. Good Luck
CoDoc
Dec 11, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
123 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
