Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
Miele dishwasher machine running & doesn't stop when prog selector knob is turned to off, start/stop button doesn't stop it. Stops only using on/off button. Seems to be emptying as pumps out water when poured in manually. May be G646 SC
  • BridieWillie Douglas Feb 11, 2009
    i have miele dishwasher,model G 660-2 premier,and it will not start when switched on, however sometimes a motor seems to be running,but that is all that happens.
    has anybody had this problem,if so what is the problem ??
    a solution will be appreciated .
My O/H found a considerable amount of gunge in the inlet pipe; that seems to have solved it! Thanks for your interest.
Enid
Posted on Jul 21, 2008
How do I turn the Miele oven on? Model is H6260BP
To turn on the oven, press the recessed On/Off button on the left below the rotary selector knob. Make sure that the system lock is off. (The display will show S 1 if it is on.) Press and release the function selector and rotary selector knobs if they are retracted. Rotate the function selector to the desired function icon (line up the dot). Then turn the selector knob to select the oven temperature. Press OK to start cooking.
Miele has the manual for the H 6260 BP oven on the product site on the Downloads tab: https://www.miele.com.au/domestic/ovens-1451.htm?mat=09514470&name=H_6260_BP . The direct link to the manual is https://www.miele.com.au/pmedia/ZGA/TX3587/10108150-000-01_10108150-01.pdf . See page 21 for a picture of the oven controls.
I hope this helps.
Oct 04, 2016 | Miele Ovens
Ifb dishwasher showing an error of 19h
How to reset / resolve Error 19H display IFB neptune DX
Follow following steps
1 power on the machine
2 push start / pause button
3 use + or - buttons to bring it to 0H
4 rotate cycle selector / circular knob to reset position
5 Display will change to 1.
6 again push the start/pause button to complete 1 min cycle.
7 after the display shows 0 . rotate cycle selector / circular knob to choose you preferred cycle.
Sep 05, 2016 | Dishwashers
Won't drain all the water, the machine stops and the red light flashes
I have just had the same problem. Dishwasher on as normal, no water going in-EEEEk, did everything the manual said to clean drain pump and non return value, no change. Then I read answer above from wcredentino and low and behold, dishwasher immediately started and no call to service man tomorrow- yay, thanks 'wcredtino' However, for me, holding both buttons at once didn't work, reset occurred when I held the on/off switch down for 5 seconds- when I held it down with the start/stop button the problem persisted.
Thankyou!
May 13, 2012 | Miele Dishwashers
Dishwasher runs and never stops
hi,
Sounds like you would need a new timer which can be purchased from Miele directly or through a authorzised service agent
Jun 30, 2010 | Miele 24 in. G870 Built-in Dishwasher
All cycle lights flash and then the machine stops. I tried turning of and unplugging, tried the switch on/off circuit. Pretty much tried everything. How do I reset my Miele G2140 dishwasher?
Well first of all you can check that the stopcock is opened fully or whether the water inlet hose is kinked. Check that the water inlet filter is not clogged and clean it, if necessary, as described in the operating instructions. Check that the drain pump is not clogged.
Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again.
Good Luck!!
Thanks
Mar 04, 2010 | Dishwashers
I have a Miele G641 dishwasher and it wont drain and it is coming up with red lights saying inlet/outlet, salt intake
One thing these guys did not point out is to turn the knob to STOP before starting this procedure (otherwise you will be ignored) Once done this works fine.
-- from the manual ----------------
Before rectifying the problem you must:
- Turn the programme selector to the "Stop" position.
- Switch the dishwasher off using the "On/Off" button.
Nov 15, 2009 | Miele 24 in. Novotronic G641 Plus Built-In...
Miele G868 built-in dishwasher water inlet problem
Pull of the program knob. Then you should find a water-intake-time-selector to the right of the axis. Take a screwdriver and turn it slightly counter clockwise one click to increase the time and vice versa.
Here's the manual:
http://www.miele.com/manuals_pdf/Residential/Dishwashers/English_manuals/Operating_Instructions/G870_us.pdf
Feb 12, 2009 | Miele 24 in. G870 Built-in Dishwasher
Where can I buy Miele coffee system instruction book?
You have to buy descaling tablets from miele.  You turn the knob to program mode and keep pushing the enter button until you get to descaling.  You put two descaling tablets into your water reservoir and replace into unit.  Put containers under the steam valve and the hot water wand. Press enter.  Turn steam valve al the way on.  Keep an eye on the containers.  The process takes about 30 to 40 minutes.  The message will appear 'Descaling finished." Turn steam selector to O and press enter.  Display will read "rinse machine, fill watertank.  Fill tank and return to machine.  Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely.  When process is finished, display will read "Rinsing Finished."  Turn steam selector to O and press enter  Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use.  Turn program selector to on.
Jul 24, 2008 | Miele Coffee System
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
MIELE DISHWASHER NEEDS A NEW KNOB
give me a couple of days and ill get back to you on that one.
do you need a part number for the knob?
Feb 18, 2008 | Dishwashers
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
537 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
