Question about Fuji FinePix S7000 Digital Camera
When the camera is on it's base and plugged in you can view a slide show. when it is not plugged in you can not switch it on to view anything or take any pictures but the green light still works when you try to switch on. It happened on holiday recently when a bit of sea water hit the camera lens. The camera was very hot and kept on saying battery is low. so when i got back to London i bought a new battery for it but nothing still works.
My camera got slightly wet by ocean water and will not work. It sometimes starts to turn on (once even taking a picture with no LCD screen), but mostly is dead. Could this just be a battery problem? Can a battery get ruined by a little saltwater without hurting the camera? Thanks,
Posted on Nov 10, 2008
  • 21 Answers
The camera's charge-couple device (CCD) within the camera must have suffered a short-circuit due to the sea water, rendering the imaging device damaged. As a result, the battery would drain pretty quick while its switched on.
Please take the camera to the nearest service center to have it repaired.
Thanks!
Sincere-One
Posted on Jul 21, 2008
I want to see the pics from my camera. It is plugged in and camera is on. I have a Sony Cyber-shot
You should be able to view these on the LCD screen by using your thumb toggle switch on the camera for review. The other way is to hook your camera to a computer with the supplied cable and upload them to your computer picture viewer. Then you can do a slide show and thumbnail as well as minor editing.
Nov 29, 2015 | Sony Cameras
Card locked shows of view finder, cannot take a picture it shows a't picture but won't take a picture
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 06, 2012 | Canon PowerShot S2 IS Digital Camera
Nikon d80 won't turn off. Stayed on after viewing slide show on TV. Operates properly with switch in "off" or "on" position. Tried:1. removing battery. it restarts with switch...
It may be as simple as a broken or worn out on/off switch. If the switch shorts out, the camera will always be on or always be off. The problem could also be the switching circuitry. If you need service, you should call Nikon's Service Department at 1-800-NIKON-US (1-800-645-6687)9AM-8PM EST, Monday to Friday.
Sep 20, 2011 | Nikon D80 Digital Camera with 18-200mm...
Screen and view finder not showing anything
Just covering the bases...
Make sure the lens cap is removed
Turn the ON/OFF switch to Favorite mode
Press EVF/LCD does it toggle
Look to see if the battery level ICON shows better then half
Battery combination sometimes will show a strong icon level
It may be strong in the other modes which draws less power then the picture taking mode.
My guess would be New Battery replacement.
Some tests were done that may be of value to your solution
http://reviews.cnet.com/digital-cameras/kodak-easyshare-z740/4505-6501_7-31294317.html
Jun 13, 2010 | Kodak EasyShare Z740 Digital Camera
My memory card on my camera say it is protected
you look on the memory card, there will be a lock slider thing,it might be on lock , check it,
Aug 17, 2009 | Nikon Coolpix S210 Digital Camera
Camera problem
u mean when u slide ur sliding cover over ur camera then it remain in normal view and camera screen not appears on ur display...then t,it can be problem with ur camera switch or with ur sliding cover ,,, but if u have the warranty just return back it to nokia its is the best option for u caz they deal in best..to do so..
ok
Apr 15, 2008 | Nokia N73 Cellular Phone
How do I rotate my vertical photos back to horizontal?
I don't think your camera has that facility[to rotate image]. As for a slide show you will have to upload the images into a computer to make a slide show- which requires new software-your computer may have some all ready on board- Then will have to be burned to a disk if you want to view it off computer- the camera is out of this equation now. Come back if you would like recommendation for slide show software
Aug 16, 2007 | Nikon Coolpix P2 Digital Camera
Lens will not come out of camera
There is a workaround for this problem, when the lens cover is open press down on the area of the lens cover on the "s" of Olympus. This can operate the switch that opens the lens etc. The long term fix is to remove the lens cover by removing the 2 screws at the base of the lens cover, take the lens cover off and gently clean around the switch which is behind the "s" of Olympus when the cover is on. I found that the grease/oil Olympus had used on the switch attracted dust etc and by cleaning this off the camera began working. Be careful when taking the lens cover off, there is also a very small metal plate that separates from the lens cover - don't lose it.
Nov 12, 2006 | Olympus MJU 300 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
218 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
