Question about Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard
Not booting Gday, Everything powers on fine all hard drives and fans but all i get is a flash from the screen power led and then the screen stays blank but all the drives and fans are still on
  • 4 more comments
  • hellocantuc Jul 21, 2008
    Nah its definatly not the monitor as im using it right now on my other pc :)
    tryed with an old crt screen and it does the same :(
    i cant acess windows as the computer does not boot up. no bios screen, no windows loading
    im pretty sure there is no beeper on the motherboard...should i connect a speaker?
  • sicasni Nov 02, 2008
    My computer powers on but remains on a blank screen. Tried removing power supply, RAM, CMOS battery and plugged it back in but to no avail.
  • sicasni May 11, 2010
    Tried using a different monitor, no luck. Could it be the Motherboard? CPU?
  • 51 Answers
Check your monitor,if it is running fine.Switch off your pc and monitor both.Switch on again.If u are not getting any display on screen ,u may need to repair your monitor.in between press on capslock or numsluck key.If keys are giving lights then 100% it is a monitor problem.
Posted on Jul 21, 2008
  • 1 more comment
  • umesh prusty
    umesh prusty Jul 21, 2008
    After switch on with another monitor attached to it, is your pc running fine??
  • umesh prusty
    U can check your screen resolution.If your pc is ok,starting os normally and then the screen is out of display.try opening the os with vga enable mode.Againg if u are able to run os successfully then it may need to set your resolution to normal that is to your monitor capability.
  • umesh prusty
    Then open your cabinet box,bring out the ram,Are u getting any beep(long),if yes then try replacing it with another one.
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
I have an Intel E210882 mother board. Within a week, it was starting to become hard to boot, then I had to boot in F8 mode, and now when I turn on the power switch, the LEDs light turn on and the cpu fan...
If you have another computer that will hook up to the internet, download a copy of any live Linux CD (UBUNTU) and see if the computer will boot with that (you download a image file that burns to a boot able cd). If it will boot with a live CD, then you have a Hard drive / operating system problem. If it will not boot from that, you have a mother board problem. Start removing things from the motherboard, unplug and remove everything then plug hook up things one at a time.
Sep 18, 2010 | Intel Motherboard
Dv55237cl blinking power led no boot
I would need some more explanation on this kind of issue.
It seems u have performed most of the steps to isolate the cause of the issue.
are you getting BIOS ???
if not...I guess there has to be something with the motherbaord.. then u need to check the follwoing recall program from HP. if ur laptop is in that then u can get the discount in repair otherwise u need to really concern the local tech to replace the MB.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Please check with it.. also can u please provide the product code of ur noetbookso tht i can search the MB..
Dreamkam
May 20, 2010 | HP Pavilion dv9000z Notebook
Gateway 503gr has no power, the standby light flashes green when I remove power. Tried new PS and the standby LED stays lit. I then tried both new and old PS disconnected from board and shorted...
Disconnect everything from the motherboard except the power supply connections and cpu fan. Install one stick of RAM and connect your monitor. Then try starting up. See if you get any BIOS boot messages. This will tell you that the board and processor are okay.
With what you say you've tried already, I'm thinking you might have a bad processor. Most every other problem would result in some kind of error like POST beep codes or messages on screen. If the system still doesn't boot with the bare minimum parts installed, replace the processor.
Mar 02, 2010 | Gateway 503GR PC Desktop
HP Pavilion dv6225us won't boot (power not the issue)
Check http://www.fixya.com/support/t3440299-presario_f500_laptop_problem
Nov 16, 2009 | HP Pavilion dv6225us Entertainment -...
D865GVHZ mother board Doesnt boots
If everything was working fine before, and you flashed bios unsuccessfully, then yes, if would be a bios problem.
If you didn't flash the bios you should check the connections on your monitor. If that's okay then check your memory, hard drive and cpu.
Good luck,
Hank
Aug 17, 2009 | Intel D865GVHZ Motherboard
Power present, will not load...
hello
  • If your system boots properly and freezes when the window appears then the "sys" file of the operating system is deleted or got corrupt.
  • if the system freezes before you could see the window screen then your OS is not loading properly.Which could be due to following
  1. check the hard disk type in the BIOS and look for SATA and ATA type. Correct if it is changed.
  2. OS got corrupt.
  3. RAM not functioning.
  4. check the boot order in bios too.
  5. hard disk gone.
hope through this you will be able to figure out your problem.
Thank you
Aug 16, 2009 | Sony VAIO VGN-NR120E/S Notebook
Presario 6350CA won't boot
I don't know that I'm going to be a great deal of help, but here is the link to the support site for you Presario:
http://h10025.www1.hp.com/ewfrf/wc/product?product=390426&lc=en&cc=us&dlc=en&lang=en&cc=us
Here's a link to another page on the Compaq site that specifically talks about power supply problems:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=390426&lang=en#N514
They discuss a flashing power led on this site, but I believe they are referring to an led on the power supply itself. Perhaps the led on the keyboard and the led on the power supply are both flashing...
Good luck. I hope this helps.
Dec 22, 2007 | Compaq Presario S6300NX PC Desktop
Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard Logo
213 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
