Question about HP LaserJet 3380 All-In-One Printer
Scaner bulb warming up
When start to scan it showing this message .after i removed thd usb cable for shot while and put back and start agin smo times it goes more than three hours
    Problem Solver:
  • 10 Answers
Your scanner is bad. This is a hardware error. Please contact HP.
Thanks
Posted on Aug 16, 2008
Scanner is not detecting device. I guess it means my computer? I have an 3380 all in one printer...and I can't scan any documents. Is there a location I can take the printer into for service? I...
if printer is working, printing but no scanes detecting, change usb cable and usb port on pc. If you can see your scaner in control panel scaner and imaging devices, so scan with adob photoshop, import from - your scanner.
Jun 02, 2011 | HP LaserJet 3380 All-In-One Printer
Scaner can preview but not scan
I had the same experiences before.
What I always do is I unplug the scanner's usb cable and then switch usb ports till i find which port it will work.
In some cases this solution didn't work, I replace the usb cable with a new one. I always buy usb 2.0 compliant cable.
Jun 03, 2010 | Epson Stylus CX7800 All-In-One InkJet...
Computer error problem
http://www.fixya.com/PostAnswer.aspx?thid=2692939
drea_mike67 on Jul 31, 2009
a message saying windows-no dis exception processing message c0000013 parameters 75b6bf9c 4 75b6bf9c 75b6bf9c then it says cancel try agin contunue and i push one and it just keeps coming back constantly.
Friday, July 31, 2009
Hello drea_mike67,
There may be any number of storage device faults causing the no disk exception error message. For instance, a usb device may have been removed without choosing the 'safely remove hardware' option. If that's the case then reconnect the usb device and choose 'safely remove hardware' (bottom right hand corner of your PC screen), and then remove the USB device.
If the error message still comes up then try using the device manager in the windows control panel like this:
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
In the Control Panel, do the following:
•Select System
•Select the Hardware tab
•Select Device Manager
•Look for disk drives or other drives that are not used or recognized...
•Right click the device(s) and select uninstall
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jul 31, 2009 | HP Computers & Internet
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Dear sir
The "car sound" could be an indication that the scanner is locked. Check the lock switch on the bottom of the scanner. Move the switch back and forth a few times and then leave it in the locked position. Another possibility is that you are scanning heavy items such as books. If too much weight is placed on the scanner glass, then pressure could be enough to prevent the scanning element from moving as it should.
The code 201 sometimes can indicate a power issue...meaning the scanner is not getting enough power. Try connecting the usb cable to a different port on the computer (preferrably directly to the computer and not through a USB hub).
May 20, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scx-4521 imaging device driver, scaner
Try changing your usb printer cable with a different brand. I have had lost of machine not wanting to scan because of faulty usb cables, even though you can print it refuses to scan. If this still is not helpful, try downloading the latest drivers from samsungs website.
Mar 21, 2008 | Samsung SCX 4521F All-In-One Laser Printer
The scanner keeps saying that my USB is not plugged in and it is
There is a workaround without messing with drivers. I have the same problem if I use the buttons on the v40 and try to scan. I get the V40 can not connect to the PC message.
Workaround:
Go to Control Panel-->Scanners and Cameras
In there you will find: Hewlett-Packard OfficeJet V40 Scanner
Right click and select Scan. It will then start the scan wizard which will scan your document.
Jan 26, 2008 | Office Equipment & Supplies
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Scanning error - cannot scan error code 2,155,0 ???
Hi
I had the same problem, at first I thought that it was the original drivers (the ones I got with the printer) so I donwloaded the drivers from the canon website, this did not resolve the problem. What I also tried and it worked for me was connecting the printer to the computer with it's original usb cable. I bought a couple of weekes ago a usb extension cable (about 5 m long). With this extension cable I can print but I can't scan any document, it just gives me the same error. Hope this works also for you.
Bye
PS: My printer is a Canon Pixma MP190
Sep 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Scanner not working
Hi, there are a couple of things you may want to try. Some of these if not done right might make you loose access to your scanner, proceed at your own risk. 1) really lock your scanner before booting to windows, then proceed to scan, then it will tell you that is locked, follow directions, remove, unlock, plug back, proceed to scan; or 2)use a different USB port (front and back/side); or 3) download and use (preferably new) drivers @ http://alpha02u.c-wss.com/inc/ApplServlet?SV=WWUCA900 or use the CD installer that came with the product. Uninstall your scanner: right click My Computer, Properties, Hardware, Device Manager, look for your scanner, right click, uninstall. or Start, control panel, add/remove programs, remove your scanner programs. You have to reinstall them all again (better with new drivers). Hope this work for you and good luck.
Apr 16, 2007 | Canon CanoScan D1250U2F Flatbed Scanner
HP LaserJet 3380 All-In-One Printer Logo
145 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
