Question about Toshiba Satellite Pro 4600 Notebook
Cd rom drive/floppy disc driveD
D:\ IS NOT ACCESSIBLE
THE DRIVE IS NOT READY.
A:\ IS NOT ACCESSIBLE
    Genius:
  • 2,785 Answers
Plz check for viruses, if the problem is not solved then follow the following steps
try by changing the data cable of both.
if the problem still persits just check with another rom and floppy drive. if the problem is solved then your both the drives needs replacement.
Posted on Jul 21, 2008
I got a message that reads Non-System disc or disc error replace and strike any key when ready. What do I do?
Here the reason why youre getting the error message
Remove the non-system disk from your boot device. For example, remove the non-system disk from the floppy drive or the CD-ROM drive.
Change your computer's boot sequence in you Bios. Make sure that you select a device that has boot files (or operating system files) installed.
If you start your computer from a hard disk drive, install a bootable operating system (such as Windows XP, Vista or Windows 7) on the drive.
Thanks for using Fixya
Jan 24, 2011 | Compaq Evo N620c Notebook
Hi i cant get my recovery cd to work but i have used it befor. i have changed the boot bios like it says on cd sleeve to 1 cd rom. 2 hard drive. 3 floppy although it hasnt got a floppy drive, i put...
if u want to get recover ur system with the help of recovery cd then first of all if u have done first boot device cdrom on bios setup then restart ur system . while booting the system u have to continue press the 'enter' to boot from cd rome then ur system will boot with cd rom then u can get recovery.
Jan 15, 2011 | Computers & Internet
I have a gateway kav60,it does'nt have a cd rom or a floppy drive, how can fix a problem take's a disc. it say's it has a bad file or missing some files.
You will have to get an external CD ROM or floppy drive to plug into your USB port. Most electronic stores will have the CD ROM drive and Best Buy can order the external floppy if they don't have one in stock.
Sep 12, 2010 | Computers & Internet
CD drive refuses to open or run even when I press the button
Select a cd rom device,then add another boot up disc,then see if it opens.Will it take a cd rom better than a floppy? If so use the boot up disc,rather than an older and possibley more damaging floppy.
Feb 16, 2010 | E-Machines eOne 433 PC Desktop
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Where is the insert for the floppy disc
The floppy disk may or may not be installed in section 5. They started eliminating floppy drives some years ago, when USB flash started to become popular.
5
FlexBay drive panel
Can contain an optional floppy drive or optional Media Card Reader. For information on using the Media Card Reader, see Using a Media Card Reader (Optional).
If your question was more basic than this, and you have a floppy drive, then you just insert the floppy into the slot. It doesn't open. Look for the arrow on the floppy disk, if it doesn't go in one way, turn it over.
Sep 13, 2009 | Dell Inspiron 531s Desktop Computer
IBM THINKPAD
What was the other threads name ?
What was my link?
Most drivers now only comes on CD. Without a wcd-Rom, you would have to split the drivers files into multiple floppy drive then rejoin it on the laptop.
May 13, 2008 | IBM ThinkPad 760 EL Notebook
PRINTER INSTALLATION PROBLEMS
Please check If your CD drive is detected on BIOS, if yes then Put a Windows XP bootale CD (checkout for the Service Pack) and choose boot from CD in the BIOS and go for "repair option" after the Agreement "I Agree-press F8" session. complete the installation then try installing the printer.
Oct 09, 2007 | Computers & Internet
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
Jun 05, 2007 | Acer Aspire 3610 Notebook
Compaq Presario 5360 Cd rom is Full
A CD-ROM drive is a read-only drive. It will always says there is 0 usable space, since you cannot write to it. You need to have a CD-Writer in order to add content to either a CD-R or CD-RW disc. You would get the "not accessible" error message if there is no media in the drive. If you place a disc in the drive, that message should go away.
Oct 20, 2006 | Compaq Presario 5360 (117744-004) PC...
Toshiba Satellite Pro 4600 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
