Epson C900 Aculaser Printer has an Avery label stuck onto drum - showing on each page now printed. Need advice on how to remove drum and clean up
I had this problem too, but after trying to remove the roller I decided to take it to a printer repairman and paid $80 to have it done for me.
Posted on Oct 15, 2008
Thin broken vertical line 8.15 cms from left edge of paper. Appears on both printed and blank pages
your printing drum got damaged there is a thin line on it that you may see with your eyes. you have to replace it
Aug 22, 2010 | Epson AcuLaser C900 Printer
Address label possibly stuck in printer
turn off the lights and close door in your office..use a pen light to look inside for a white reflection..let me know if that yields anything..
Oct 13, 2008 | Epson AcuLaser C900 Printer
Problem printing multiple copies of a single page document
I have a similar problem with an old HP LJ1300. They have not updated the driver correctly and don't intend to fix it. I can't find any reference to AcuLaser C900 on Epson's support page. So maybe they stopped supporting the C900.
May 06, 2010 | Epson AcuLaser C900 Printer
How do I clean print heads re Epson Aculaser c900
you can clean print head unit
first remove opc and transfer belt ,then move front cover,then rmove
the Drum Unit Slide Cover,then
Remove the Laser Lens Cover.
now you can see printhead unit .Clean it and its ok.
Jun 07, 2009 | Epson AcuLaser C1900 Printer
Error 6022
i had the same problem just today, i disaasembled the printer got out the transfer built and cleaned it, unscrewed the speed sensor and cleaned it , and its now working perfectly again,.
Oct 14, 2008 | Epson AcuLaser C900 Printer
Avery Labels STUCK to drum, can't figure out how to get them off
you can clean it with a little alcohol or water, just take a good look at the PC Drum and Transfer unit, remove them from printer first, find labels and with wet cloth carefully wipe it away. but you should know that even if you remove labels there may still some marks on TBU and PC drum what leads to quality problems.
Sep 07, 2008 | Konica Minolta magicolor 2430 DL Laser...
Black stripes ove the page
Try cleaning your ink nozzles or ink jets. It sounds like you have a plugged nozzle or two. Your printer program should have maintenance options that allow you to test for plugged nozzles and clean them.
In control panel, open the printing/fax icon, right click on your printers icon, left click properties, then on the bottom of the page the panel that opens you will see a button that says printing preferences, and that should open your print program.
Dec 15, 2007 | Epson AcuLaser C900 Printer
Epson AculaserC900
I did much the same and am looking to see if there is a solution here! Tried cleaning the glass filter, which pulls out about 250mm and is located just below the transfer unit - small grey tab, behind waste collector. It helped, but still a slight white band on the print.
Oct 22, 2007 | Epson AcuLaser C900 Printer
89 people viewed this question
jasbo
jasbo
