Question about Apple Cinema Display 23" HD Monitor
Pink Hue Round Edges
My 23" apple monitor has finally fallen victim to the pink hue ailment.  Can this be repaired?
Thanks
  • tarnation Jan 28, 2009
    Help?
    Apple Cinema Display 23" HD has decided to turn pink around all four edges. The area of correct color is now dramatically reduced.
    Any suggestions?
  • 1752 Answers
SOURCE: pink hue around outside of monitor
It's dying. Time for a new one, they're not repairable.
Posted on Oct 23, 2009
I hit a key accidentally and now my monitor has a pink hue> can you help me get it back?
Check the color temp control on monitor. If set for warm picture, that might account for the pink tint you talk about.
Apr 03, 2016 | Computers & Internet
LG E1940S Monitor displays with a pink hue. I am using with a T40 ThinkPad and XP
A pink hue is a sign the CCFL lamp is about to fail.
The CCFL lamp is a fluro like tube approx. 2mm in diameter that is located on the bottom edge of the LCD screen that supplies the back light to the screen.
Replacement CCFL lamp is available from this WEB site.
www.lcdparts.net.
Jun 04, 2011 | LG E1940S 19" LCD Monitor
The color / hue on my sony monitor seems to be pink how do I adjust it to its normal color ?
Click on the link below and download the manual to know how to change settings of your monitor
Monitor Settings Manual
Regards,
Shawn
Feb 03, 2011 | Sony SDM-HS95 19" LCD Monitor
The color is "off" on
ladywoman197, 2 things for you to do. 1. disconnect-reconnect vga cable a few times from the DB15 vga port on the pc. If problem (pink hue) persists then try here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-blackout-solution/ Your unit may need some new capacitors installed on the power supply printed circuit board. Read fixya profiles of "budmrtn" "12fixlouie" and also visit youtube for video clips of lcd monitor repair. Do the vga cable thing first!!! Could also be vga graphics card inside pc not making good contact with monitor cable. 12fixlouie
Nov 08, 2010 | HP W2007 LCD Monitor
I added the E196fp to my older dell computer with win 98 from my newer dell with win xp.The whole thing has a pinkish hue to it and is very dark
mklotz, Try looking at the vga connector end and make certain all the brass pins are not bent or broken or recessed down into the connector body housing. If connector ok, then connect, disconnect, reconnect a few times and try to see if the PINK has changed to WHITE. If still PINK, then reseat the video card in pc. If still PINK screen, Then monitor may need to be repaired. CCFL ballast circuit repaired and/or CCFL lamps have too many hours on them and they also will need replacement. Report your findings here with additional info for me. 12fixlouie
Aug 17, 2010 | Dell E196FP 19" LCD Monitor
Pink Hue on my Princeton Moniter
If you have access to another monitor, check it with your computer. Pink or red hues are usually indicators of a failing backlight bulb or ccfl bulb that sits in the bottom of the display and lights up the lcd.
Nov 27, 2009 | Princeton Digital Computers & Internet
Pink hue around outside of monitor
Oct 23, 2009 | Apple Cinema Display 23" HD Monitor
The laptop starts up with a pink hue
Make sure the LCD is completely attached to the system board. I've had them come partially out and cause this. If this doesn't help, your LCD and/or inverter could be going bad.
Dec 30, 2008 | Dell E176FP 17" LCD Monitor
Pink-hued display
one try a degauss
second check the cable wich connect the monitor to the pc video card.
third. keep away the magnetic things like speackers from the monitor..
bye:)
Feb 03, 2008 | Compaq CV 7500 17" CRT Monitor
Apple Cinema Display 23" HD Monitor Logo
724 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
