Its the paper feeder,, this can be repaired by changing the small greas that grab the paper , you will need to do this by taking the prointer apart. Unfortunately chances of getting it to pull straight after repairing it is very very slim. If i were you i'd toss it out and buy a cheap printer like a canon ip 1600, which can refill ...
There are several ways to adjust your printer for thicker photo paper:
Check the paper tray: Make sure that the paper tray is adjusted for the thickness of the photo paper. Some printers have adjustable paper trays that can accommodate different paper thicknesses.
Use the manual feed: If your printer has a manual feed option, try using it to feed the thicker photo paper through the printer. This can help prevent jamming.
Adjust the printer settings: Check the printer settings to see if there are any options for adjusting the paper thickness. Some printers allow you to adjust the paper thickness in the driver settings.
Check for software updates: Make sure you have the latest software updates for your printer. Sometimes, software updates can include new settings or features that can improve the printer's ability to handle thicker paper.
Check your printer manual: consult your printer's manual for any specific instructions on printing on thicker papers.
It's also worth noting that not all printers are capable of handling thick papers, so it may be necessary to use a different printer or have it professionally printed if none of the above steps work.
If
your printer has a paper tray do not fill the tray to capacity. If
you're encountering frequent paper jams, reduce the amount of paper you
place in the tray each time it is filled.
Make
sure you or the tray feeding the paper into the printer is aligned
properly and the slider used to hold the paper in place in the tray is
snug with the paper. Many printers have sliders that allow different
types and sizes of paper to be fed into the printer. If the slider is
not properly positioned it can cause paper jams.
Use
standard office paper; folded paper, paper with labels, and specialty
paper such as hard bound paper can often cause paper jams. If you're
uncertain with what paper you should use with your printer your printer
documentation will list the paper compatible with your printer.
Do
not mix the paper you're feeding into the printer at one time. If you
need to change the paper or size of paper being used removed any other
paper currently in the printer before inserting the new paper.
If your printer uses a slot or tray for the paper make sure to not push the paper too far into the slot or tray.
Examine
the printer for any previous stuck paper in the printer. Previous paper
jams, torn paper, printing labels or other foreign objects in the
printer can cause reoccurring printer jams.
**If you need any kind of technical assistance you can contact support cell at here
If
Make
Use
Do
Examine
If your printer has a paper tray, do not fill the tray. Overfilling the paper tray is frequently causes paper jams. Many printers have sliding mechanisms that allow different types and sizes of paper to be fed into the printer. If the slider is not correctly positioned, it can cause a paper jam.
Fixing a printer paper jam When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
Turn off the printer.
Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
Remove
all paper trays and any paper that may be stuck between the tray and
the printer. If the stuck paper is visible manually remove it.*
Open
the printer door that allows you access to the printer ink cartridges
or toner and look for any stuck paper. If the stuck paper is visible
Turn the printer back on. If you continue
to receive a printer jam error try repeating the above steps again. If
issue still persist and you see no paper that is stuck in the printer
it's likely your printer is experiencing another hardware issues and we
suggest contacting the printer manufacturer for additional assistance and/or repair.
To manually remove paper pull on the paper with both hands being
careful not to tear the paper while pulling it. If you're unable to get
to an edge of the paper that allows you to pull it you may need to
manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam As
mentioned earlier it is inevitable that you will encounter at least one
paper jam during the life of your printer. However, if you're
encountering frequent paper jams following the below steps can help
prevent paper jams from occurring.
paper tray do not fill the tray to capacity. If you're encountering
frequent paper jams reduce the amount of paper you place in the tray
Make sure you or the tray feeding the
paper into the printer is aligned properly and/or the slider used to
hold the paper in place in the tray is snug with the paper. Many
printers have sliders that allow different types and sizes of paper to
be fed into the printer. If the slider is not properly positioned it can
cause paper jams.
Use standard office paper; folded paper,
paper with labels, and specialty paper such as hard bound paper can
often cause paper jams. If you're uncertain with what type of paper you
should use with your printer your printer documentation will list the
types of paper compatible with your printer.
Do not mix the
types of paper you're feeding into the printer at one time. If you need
to change the type of paper or size of paper being used removed any
other paper currently in the printer before inserting the new paper.
Examine
One of the more common problems with printers as it relates to paper jams, is that the paper stacked in the tray hasn't been fanned. What I mean is, it's like holding a paper-back book in your hand and skimming quickly through the pages with your thumb as your other hand holds it at the spine. Try this as a remedy if your printer jams often.
Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Please post your feedback and Vote if the poblem resolved as per your satisfaction.
1. Turn off the printer. 2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.* 3.
and the printer. If the stuck paper is visible manually remove it.* 4.
visible manually remove it.* 5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again.
If
it's likely your printer is experiencing another hardware issue and we
and/or repair. *
through the printer. Preventing a printer paper jam As mentioned
jams from occurring. * If your printer has a paper tray do not fill the
amount of paper you place in the tray each time it is filled. * Make
not properly positioned it can cause paper jams. *
Use
printer. * Do not mix the types of paper you're feeding into the
before inserting the new paper. * Examine the printer for any previous
printer jams. I hope this information allows you to resolve this issue.
If
I have helped you, please help me, and rate this suggestion the highest
FixYa rating. If you cannot rate this post with the highest rating,
then please comment to this post and I will try to help you further.
Answer: Fixing a printer paper jam
1.Turn off the printer. 2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.* 3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.* 4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.* 5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair. * To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
•If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled. •Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams. •Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer. •Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper. •Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
