Question about Cameras
I wanted to put black and white in my camera (Power Shot SD 870 IS). I did the following steps: -Menu -Configurations -Format memory card -And without knowing I press OK ALL OF MY PICTURES WERE GONE!!! I really would like to know if there is a way I can get them back!
Once pressing the button, i'm afraid there is no way to gt them back.
Sorry :(
Posted on Jul 21, 2008
I reformat my sd card in the computer to remove all the photos the when im using it in my sony cybershot camera it appears "reinsert memory card" how can i fix the it to use it again in the camera
When you need to delete the photos from the SD memory card, do not use your computer to do it. Use your camera to format the SD memory card.
To fix this problem, insert the SD memory card in your camera then go to the camera's Menu and format the SD memory card.
Nov 03, 2012 | Sony Cyber-shot DSC-W80 Digital Camera
I bought a new memory card for my Canon Power Shot SD 400 Digital Elph, but it has an error message that comes up. When I scrolled through the Menu to format the card, the format selection is grey and...
Your older camera can only work with 2GB or smaller standard SD cards. It is not capable of recognizing the newer format 4GB or higher SDHC cards. Fortunately, old format 2GB SD cards are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them.
Sep 02, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
How can i switch to a memory card?
Most digital cameras use either a secure digital (SD), compact flash (CF), memory stick, multi-media cards or XDcards.
Step 1: Power the camera off and determine what type of card your camera uses. You can check the owners manual, go to the manufacturer's site, or look on the camera to find out what card you use.
This is a picture of an "SD" card in a Digital Camera.
Step 2: Insert the memory card into the camera by locating the memory card slot on the bottom or side of the camera body. Open the memory card door by using an "Eject" button or sliding the panel to the side. Insert the memory card as advised by the icon on the inside of the door. Close the door and turn the camera on.
Step 3: Format the memory card for the camera. Many digital cameras will do this for you once the memory card in inserted and the camera is powered on. On some cameras you can do this manually:
Press your camera's "Menu" button, select "Tools," and find the "Format" feature. Select "Format" and press "OK" or "Set" to format the memory card. Press the shutter button to exit "Menu" mode.
To remove the memory card, open the camera as you were able to in Step 2. Then press the end of the card in and release. The card will slide out of the camera.
Some accessories may be required to transfer media to your computer. There may already be a slot in your computer for the card, if not, an SD to usb kit can be purchased online or from a local electronics vendor for a reasonable price.
May 05, 2011 | Cameras
HOW TO FORMAT SD CARD
Put the SD card into your digital camera and then turn the power on. Press the button on your camera to bring up your recently shot photographs.
Press the "Menu" or "OK" button on the camera to bring up the photograph options. Choose the option that says either "Setup" or "Options."
Scroll over to the "Format" option and hit "OK." Choose the option to set the file format to "FAT16."
other way to format is Put the SD card in card reader and follow these steps:-
Turn on your computer and put the SD card into the card reader slot on the front of your computer or the external card reader attached to a USB port. Wait to see if your operating system automatically opens a window prompting you for information. Click on the option to "Open a folder to view files" if the window pops up.
Click on the "Start" button if your operating system does not automatically prompt you to open a folder. Choose the "My Computer" option to bring up a new window.
Right-click on the drive bay for your card reader, and then choose the option that says "format" from the pop-up menu. Click on the option to set the formatting to "FAT16" if you receive a separate pop up window asking you which file system to set the card to.
good luck
hope it helps if so do rate the solution
Nov 29, 2010 | Kodak EasyShare DX4350 Digital Camera
When I put the memory card in and turn on the camera, it keeps saying memory card error.
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 03, 2010 | Canon Power-shot S1 IS Lens Converter
Will not format memory card
How to format the memory card in my camera? NOTE this will delete all existing data on your card.
  1. Do the following:
  2. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  3. Turn on the camera.
  4. Press the Menu button, then go to the Setup Menu.
  5. Scroll up or down to the Format option, then press the OK button
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C913 Digital Camera
    New 2 GB Memory cards say cards full when installed
    The SD card may have to be reformated. You should do this in the camera you want to use the SD card with. Do not format the card with your computer.
    In you manual or on the menu of your camera there is a "Format" procedure. follow that and your camera will work again (REMEMBER) if you have images on the SD card down load them before you format the card.
    Once you down load the images from your camera you should reformat the card to clear it in order to shoot more images.
    Mar 20, 2009 | Kodak EasyShare C330 Digital Camera
    Memory card
    The camera takes a SD memory card if you have one that is not working you can try to format it with a computer that has a memory card reader and see if that fixes it or try to format it from the camera under the setup menu. Eather way some camera format process and block struckure is diffrent so a memory card needs to be formatted for each camera so work fine between each other and some don't.
    hope this helps.
    Mar 28, 2008 | Cameras
    Formatting SD Card to shoot stills
    Hello Sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Sep 22, 2007 | JVC GR-X5U DV Digital Camcorder
    Memory card cannot be used
    Follow these steps: 1. If you have a SD card reader, insert the SD card and look for it in Windows Explorer. In this case, mine was labeled F: 2. Right Click on the drive for the Card Reader (IMPORTANT) and choose FORMAT. 3. Format card with default settings. 4. Turn Camera on and go to MENU> FORMAT CARD 5. Before answering the next question, insert SD card into camera. You will hear it beep twice. 6. Choose FORMAT and the card should be formatted for use on the camera. Cheers!
    Sep 18, 2007 | Rollei Prego DP5300 Digital Camera
    Cameras Logo
    35 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
