Question about Dual XDVD8181 Car Video Player
How do i bypass the e-brake wire on this cd player
    Brigadier General:
  • 6,966 Answers
The principle is to ground the yellow/blue wire of the Dual XDVD8181 but with certain sequence and a few other actions. It is better explained with illustrations here while a pdf "how to" is available fro download here. User discretion with a consideration for safety pls.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 21, 2008
I have a dual XDVD 8180 and I am having the same problem but when I put in a DVD it says ERR-DISC but the DVd is brand new with no scratches......Is this because the parking brake is not hooked up?
Posted on Sep 16, 2008
SOURCE: jensen vm9311
bypass code for playing dvd while drive
Posted on May 29, 2008
  • 109 Answers
SOURCE: bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
Posted on Jun 06, 2008
SOURCE: how do i bypass the emergency brake wire on a dual xdvd700
Guys, the solution is staring you straight in the face.
Take the ebrake wire coming from the stereo, and attach it to the screw off nut on the rear of the stereo case to earth it.
Thats it.
Job done.
Cant believe no one tried that - took me 2 minutes to figure out.
Hope this helps :-)
Posted on Aug 27, 2008
SOURCE: bypassing car dvd parking brake
just hook the pink wire up to anything metal job done , its illegal to watch moves whiledriving its not illegal to have it hooked up like thta though
Posted on Sep 21, 2008
dancandoit
  • 436 Answers
SOURCE: how do i bypass emergency brake wire on my clarion to play movies
connect the wire to a ground/negative point, please note this is a saftey feature.
Posted on Nov 15, 2009
What does pink/brake wire on dvd hook up to?! Ex: -LF- spkr or red power?! what?! I have a "Farenheit TID 580" car cd/dvd player. I have all the wires hooked up except the pink/brake. Is there a wire on my...
Hi all car dvd players have a emergency brake safety feature. The pink wire is to be spliced into your emergency brake wire, or there is a code you can purchase to bypass this feature.
Thank you for using fixya.com
Feb 09, 2010 | Eclipse (AVN7000) Car DVD Player
How do i bypass emergency brake wire on my clarion to play movies
Nov 15, 2009 | Clarion Car Audio & Video
Bypass brake
What kind of vehicle? If you can find where the wire to the emergency brake switch (usually there is a switch at the top of the emer/brake pedal) was tapped into. Take a a test light (Bought at auto supply store) and find out if your switch is grounded or has 12vdc when emerg/brake is depressed. If it is grounded then find the wire from th dvd player and attach it to a frame ground. If it is 12vdc find some other source of 12vdc in the fuse box and put the wire to that source. If I knew what type of vehicle I can possible walk you through it.
Feb 02, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
How do i bypass the parking brake switch in order for my video to play
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
May 15, 2008 | Car Audio & Video
I got a ?
Normally, the emergency/parking brake has to be activated/engaged for the video player to operate.
By bypassing, you are simulating this condition even if in reality, the emergency/parking brake is not activated/engaged.
Solution > ground the video player's brake sensor wire rather than connect it to its intended connection point.
In some brands/model/versions of the video player, this would be light green (Pioneer, Clarion, JVC), green (Kenwood),
In some other rands/model/versions of the video player, there would be a bypass switch underneath a sticker, others would need a special adapter, still others have bypass option/feature in the menu/setup and some would require a toggle switch that would connect the dvd brake wire from positive to ground.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information. A reminder pls, in some regions bypassing is not allowed.
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Bypass brake for a jensen vm9311
the wire is pink and say parking on the wire.
Nov 24, 2007 | Panasonic CQ-C3300U CD Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Dual XDVD8181 Car Video Player Logo
242 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
