Question about Dell Latitude D600 Notebook
Touch pad How do I disenable the touch pad? I may be clumsy but my cuffs seem to brush it and as I use a mouse anyway I'd like to disenable the touchpad so that I don't keep jumping all over the place accidentally.
    Guru:
  • 859 Answers
Hi, easy to fix this.
I have a Dell 610 myself and have the same problem, in spite of the software updates, the pressure sensitivity doesn't work real well.
To disable the glide pad, boot into the setup screens, F2, use Alt+P to scroll through the pages for mouse vs. keypad. Select Serial Mouse. Doesn't make sense when you have a USB mouse, but the PC will keep your USB mouse enabled and this disables the Glide Pad.
If you're confused or I mistyped this, ask me via the comment box below and I'll make it more clear. Its pretty late here on the West Coast, but this will fix your problem.
Thanks for rating this solution fixed once we have you settled and finished if it takes another response from me to reboot myself and be more accurate as to what page its on.
Regards,
Worldvet
Posted on Jul 21, 2008
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
While I'm typing, the cursor moves to another place in the sentence or on the screen. This is a huge problem, because when I'm tying, the cursor goes back anywhere it wants to in the sentence, which mixes...
Try an external mouse. I have seen this happen many times, and it is usually the users hand brushing the integrated laptop mouse pad.
If the external mouse works and the problem is not there, then try again with the internal pad, and watch to see if your hands or fingers brush against it.
If it still happens even with the external mouse and you are sure you are not touching the pad accidentally, then you may want to contact manufacturer of computer, check for updated USB drivers as well.
Your internal mouse runs off USB, and there is a possibility there may be a glitch there that could be resolved with an update.
Nov 10, 2010 | Computers & Internet
How do you turn off the touch pad
Some notebook users find the touch pad annoying because at times, while typing fast, their thumbs accidentally brush up against the touchpad. This is frustrating because the mouse cursor jumps to a random location on the screen and can cause undesirable things.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Oct 24, 2010 | HP Pavilion dv4000 Notebook
While I type, often the cursor moves to the poit where the mouse icon is locatde, as if the touchpad has been pressed.
yeah you have touch sensitivity set to high in the touch pad and your wrist is hitting the touch pad. go your touch pad settings in the control panel and turn it down til when your wrist brushes it, it doesn't move the mouse.
Mar 23, 2010 | Dell F3534 Touchpad
My touchpad mouse won't work. it does not respond
If you are using XP, check your mouse settings under Control Panel. Make sure that your Touch Pad is enabled. If it is but it still won't work, have a mouse plugged into a USB port that will work correctly. Then download the latest driver from the Acer site for your touchpad. Uninstall the driver that is currently being used by your system. Then install the updated driver that you downloaded. This should allow you to use your Touch Pad. If not, you may have to take your laptop in for servicing.
Jul 15, 2009 | Acer Aspire One PC Notebook
My touchpad is not wrking at all. Then I reinstal
You should send the laptop back for replacement if it's under warranty. Bad touchpads seem to be pretty common nowadays, on my HP DV5 which is 3 weeks old it has failed on the 4th day. It does not bother me though, as i have bought a mini USB mouse for $5 and it is much better than the touchpad anyway.
If you'd ask me, i'd say just buy an USB mouse, it's much more practical.
Jul 02, 2009 | Compaq (153515-001) Touch Pad
Mouse moves on its own
Your palm might be brushing on the touch pad while you are typing that is probably why the cursor jumps to a different location. as for disabling the touch pad I think that it is not possible unless you install a synaptics driver for your laptops touch pad.
Apr 01, 2009 | Gateway Laptop Keyboard for MX6930,...
My Dell M140 has no touch pad settings/tab
there is no setting for the touchpad. it is set at the factory with hardware components under the touchpad.
Nov 13, 2008 | Dell F3534 Touchpad
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
Dell Latitude D600 Notebook Logo
209 people viewed this question
Alun Cox
