Question about Technics Audio Players & Recorders
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to adjust the screw on top of the tone arm.
  • Anonymous Mar 31, 2014
    The adjustment is now poorly adjusted, only one channel of stereo music can be heard. I simple steps, using no techno speak, please tell me how to adjust it. The manual is not readable.
  • 4,234 Answers
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Posted on Jul 21, 2008
Need to know how to adjust tone arm and anti-skate
Get one of those little mini-digital scales that should sell for about $30 or less. Make sure it reads in 0.1 or 0.01 increments. Unplug the turntable (so the platter doesn't spin) and place the scale in the tonearm path. Most tonearm and headshell combos should work well in the 1.0 to 1.5 g range. Weigh the tonearm balancing on the scale about midway through the path (where it would be in the center of the record)
I used a flat plastic credit size card to protect the stylus on the surface. Don't forget to tare the scale to 0. Attempt to calibrate your weight scale adjustment on the tonearm to match the scale while you are at this. Once you have found a setting that works for you, match that marking on the weight scale adjustment on the anti-skate wheel.
You should have a turntable that sounds nice and is also gentle on your records!
Feb 18, 2013 | Audio Players & Recorders
I have a Crosley CR49 turntable and the tonearm seems to be misaligned. I lift the cue lever and place the tonearm where I want it to land on the record, but when I lower the cue lever the tonearm moves...
that situation is possible that it is bent a little. make sure your table is level when using it and check the weight in the back to see if its too far out leaving the tone are to bounce of drift easily. you can manually put the needle down in the meantime.
Sep 22, 2012 | Audio Players & Recorders
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Apr 14, 2011 | Denon DP-47F Turntable
Need to know what settings the anti-skate and the counterwieght on the back of the tone arm should be set to. Also when pressing start tonearm will not move at all. Can still cue it manually...
The counterwieght should be set the tracking force for the cartridge/stylus fitted. These are expressed in grams. Typical about 2 to 3 grams. If the weight has numbers on it these will match the grams. There's no right setting for the skate. Should the stylus start to skate accross the record increase the force. Start low!
On the arm movement, has the arm moved before after pushing start taking it to a record? As many turntables just don't.
Jan 01, 2011 | Technics SL-1200MK2 Turntable
Needle keeps jumping back 4 bars on records
CHECK ANTI SKATING SETTING SHOULD BE SAME AS STYLUS FORCE ABOUT 3.ADJUST TONEARM HEIGHT SO IT IS PARALLEL TO RECORD WHEN PLAYING.HAS THE DECK HAD NEW PHONO CABLE FITTED RECENTLY IF SO THIS WILL BE THE CAUSE GET IT DONE PROPERLY.
May 03, 2010 | Technics SL-1200MK2 Turntable
Technics 1210 tonearm skates when cueing vinyl backwards
I've seen this on technics turntables before. Try tightening the screw on the arm.
May 20, 2009 | Technics SL-1210 Turntable
45 and 33 sound slow
Here's a procedure for setting the tonearm...
Unplug the power to the turntable and place it on a perfectly level surface.
Set the Tracking Force and AntiSkating to 0.
Manually rotate the platter Clockwise a few turns to disengage any cueing mechanisms.
If you don't have a Stylus Tracking Force Gauge. Dial in the prescribed tracking force and a corresponding anti-skate reading. Play records.
May 04, 2009 | Audio Players & Recorders
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
Jan 01, 2009 | Kenwood KD-291RC Turntable
Techniques SL-D1 Turntable anti skid...
Actually, this sounds like the needle is damaged. Make sure there is a tip on there. Just because it's new, does not mean it is not damaged. Sometimes end-users improperly handle the stylus/needle when installing.
If you are 100% certain that the stylus is ok, then the anti-skate needs to be set correctly. Generally, leaving it on 0 (zero) is ok to start. Then try and balance your tonearm according to THESE INSTRUCTIONS. These instructions apply to most turntables. The fundamentals are the same for all turntables in that you need to balance (float) your tonearm for optimal use.
Hope this helps some.
- Davis.
Digital Analog Therapy
Electronic Repairs
www.repairny.com
Nov 01, 2008 | Audio Players & Recorders
Well on my technics MK2 1210's, the little anti sketch settings and all the others probably arent set to what they are supposed to be, because my needle arm keeps jumping :P could someone tell me what all...
There are two main things that will influence the anti skate settings.
1) The Headshell Weight and Balance
Firstly, check the data sheet for the cartridge and stylus you are using. It should tell you the correct weight setting which will vary from one cartridge and stylus to another. If the stylus is set too light, it can skate across the disc. This can damage the disc and the stylus. The sound will also be thin and it is likely to distort on high frequencies. If the weight is too heavy, it will not jump but will definitely damage the disc.
If you are a serious vinyl user, get yourself a tone arm balance. This is a device that you place on the turntable and you rest the stylus on a plate which is marked in micrograms. You place the stylus exactly at the correct weight marking and then make adjustments to the turntable settings until the tone arm is balanced. It's easier than it sounds!
If you don't have the data sheet for your cartridge and stylus and cannot find it online, use an old disc that you don't mind damaging, set the weight on the light side and gradually increase the weight until it stops skating.
2) Platter Levelling
Secondly, you need to make sure your turntable us on a level surface. If you are a purist, use a spirit level. to do this.
There are other things that can cause skating and jumping, especially if you use the turntable as a DJ. For example, vibration (caused hopefully by dozens rocking to your music). DJs will often increase the headshell weight very slightly to overcome this and I have sometimes placed the turntables on a thick rubber sheet such as carpet underlay to improve shock absorption.
Mar 26, 2008 | Technics SL-1200MK2 Turntable
362 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
