Linksys Wireless-G Broadband Router Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I find the correct address fro my router because my printer does not recognize it?
Anonymous
Level 3:
  • Master 442 Answers
  • Posted on Feb 03, 2011
Anonymous
Master
Level 3:
Answers
442
Questions
0
Helped
117276
Points
1405
If your computer / computers are connected to the router and if it works fine, please use the below procedure to find the IP address of the router.
Click on Start (from one of the connected computers)
Click on Run (if XP)
Type cmd and hit enter
in the command prompt window type ipconfig and hit enter
the number in the format 192.x.x.x against the default gateway is the IP address or your router.
Anonymous
Level 1:
New Friend:
  • Contributor 24 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
24
Questions
0
Helped
6122
Points
88
Are you trying to connect the printer to the wireless network????
tip
Set up a Wireless printer on your Router for use with a wired PC
First install the Wireless printer driver using the Wizard by connecting either the Ethernet cable to the router during the install process when asked this will set up your wireless laptop with the correct printer port based on the Wireless Node Name it will also use the printers inbuilt MAC address. This is standard install and will work for all your Wireless PC's however if you have a Wired (ethernet) PC connected to your Router this process will not work a wireless port will not work with a wired computer.
Follow my 3 steps below to set up standard IP ports for Wired PC's also connected to your Router.
STEP 1: Find your MAC address for the wireless printer (all types of Network Cards will have one so this is no different) this will either be found under the LCD control panel or may even be printer on the bottom of the printer or Print server if it is seperate set this MAC address with an IP address as a reservation in your admin panel of your router 192.168.0.10 in this example.
You can normally enter your Router this using 192.168.0.1 typed in your browser (not the search engine) as all routers are different check here for your make and model http://www.routerpasswords.com if you can't find the MAC address try using ipconfig /all from them command prompt it will be the physical address aka the MAC address
STEP 2:
Install the Printer as a USB printer port by connecting the USB cable to the PC you want the wired printer driver installed on when finished go to the printer driver properties for the driver you have just added, click the port tab and click add standard IP port as shown below, then disconnect the USB lead this is only required to make sure the correct inf file is used on the driver install and connect your Ethernet cable from you computers NIC to a spare RJ45 socket on the Router.
STEP 3: To check that the Printer has the correct IP address then test using the tracert OR ping command for the IP address that you have reserved on your router, this is a necessary step otherwise when the lease expires it may take another IP address and your Printer driver will not work unless your printer has the reserved address, it will throw a printer error.
c:ping 192.168.0.10
(this example shows a Standard TCP/IP Port for a Brother DCP-340CW)
Also check in your routers admin panel to see if the Wireless Printer is set up with the correct IP and MAC address, if you still can't find it eliminate your known MAC addresses from all your network cards the one left will be your Printer Server NIC in your Wireless Printer.
If you have setup the incorrect IP and or MAC address you will get this window when you try to add the TCP/IP port
That's it try a test print and you will see it burst into life.... Happy Printing
I bought a HP wireless printer having difficulties with the computer recognizing it - is the router number to use 192.168.0.118 ? and I'm not sureof the username and password - I think I am using the...
The router number is assign by your router, as long as it is within the IP address number block it will work. I think you need to reload software at your PC.
How do i get the 3650 to recognize a different router? it was connected to the previous router, but we replaced the router
Did you configure the printer with a "static" IP-address?
Reconfigure the printer to use 'DHCP' (Dynamic Host Configuration Protocol),
to automatically obtain a correct and valid IP-address from the new router.
I have a wireless printer and it won't connect. I tried text sopport for the printer and was told that the router needs to be insinck to the mac address . I would like to know if you could tell me how to...
Setting up wireless printers can be such a hassle!
The quickest solution is to let the router sync the mac address itself, don't worry about the details of it all. Easiest way is to start wired, before you go wireless.
When setting up the printer to work with that wireless router, hook your printer up directly to the router/computer the router is connected to. This will allow for the printer/router to recognize each other and establish a connection. Then, when you use a wireless connection (wireless on laptop/ on printer also), they will recognize each other and you'll be able to connect.
This is much less of a hassle than trying to set up wirelessly.
Best of luck!
I want to connect a HP P4014n Laserjet Printer up to another computer but I do not have this installation disc, how can I get this printer working on another computer?
download the driver / software from hp website.
if your system is connected to the network / router, your system should recognize your laptop or another system (same workgroup).
add new printer see if the system recognizes else. add the printer by providing the printer ip address. (test print from your printer and will provide the ip address)
Cannon 560 printer is not connecting to the router.
It shows your router is not configured properly. Reset your router and reconfigure as per the instructions. Dont forget to name your network (ssid). After this ascan for the available network and then connect
Piggybacking a linksys wrt160n with a westell 327w
Did you put the correct WEP key in the router you are trying to add?
2helpful
Revised IP address for Ricoh 2020d
Go to user tools counter. Go to settings. Go to interface. You should see the IP address settings window. Some Ricohs have auto DHCP. Usually I turn that on to get it to recognize your router. Make sure your gateway address is inserted as well.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
