Question about Acer Computers & Internet
I have an ACER FERRARI laptop. When power plugged in battery light shows, and light also indicates full charge therefore I assume ac lead and battery ok. When pressing start button nothing happens, apart from light next to power/battery light comes on for about 1 second. I assume motherboard damaged?
  • seant0210 Jul 21, 2008
    Laptop does not work. when pressing start button nothing happens.
  • 84 Answers
The charger might have the problem, and the light that you are seeing apart from the light next to power/battery is the hard disk led, this is showing that HDD is active, your motherboard is not damaged. you might want to check if you need to defrag the Hard disk by right clicking my computer then selecting manage, there you may analyze whether it needs to defrag. now you may check the charger if its chrging by clicking in the taskbar.
Posted on Jul 21, 2008
Acer Ferrari ONE 200 wont power up
you have to check that your battery is charging or not in your laptop by another laptop or battery,if problem is not solved,then check battery port
Dec 02, 2013 | Acer Ferrari ONE 200-1799 Notebook
AC adapter 4750z
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
If you need to buy a new laptop charger, the following to adapters are for your reference:
Replacement Acer Aspire 4750 AC Adapter 65Watt 19V 3.42A
Replacement Acer Aspire 4750 AC Adapter 90Watt 19V 4.74A
Nov 15, 2012 | Acer Pwr Ac Adapter For Travelmate 4750...
Acer aspire 5750 charging problem
If you are sure that your laptop charger is dead and you are in the market for a new one, try the following one:
Replacement Acer Aspire 5750 AC Adapter 90Watt 19V 4.74A
Oct 30, 2012 | Computers & Internet
When i charge my acer aspire the power button flashes
The DC jack in the laptop is showing early signs of intermittent issues, the jack is solded to the motherboard which sometimes breaks free over time, this is something that will eventually need to be addressed.
Mar 25, 2012 | Acer Aspire 5336-2283 Notebook
I have a Acer Ferrari 4006wlmi, which I'm trying to figure out what's wrong with it. It does turn on but HD indicator just stays lit (no flickering as to say it's accessing), it was undergoing...
Please remove the laptop battery and disconnect the Ac power. Then press POWER ON button and hold for 1-2 minutes. Then power on with the AC adapter only. Then start the laptop. It will powered on. After that shutdown laptop and reinsert the laptopbattery.
Even it wont work, remove the battery, hard disk and ram. Just insert the RAM and try to check the display. then insert hard disk and check the working nature of laptop on AC power only..
Further any clues please provide the feedback..
Jun 29, 2011 | Acer Ferrari 4006WLMi Laptop Notebook
Laptop not working on battery, i have changed the battery
There are several simple indicator to determine the source of the problem. There are 4 major components involved, the laptop circuitry, contact terminal, AC adapter and battery. Every laptop has a LED light indicating if it is in the charging mode (without powering up the laptop). Start out with your laptop shutdown. Pull out the battery, then plug in the AC Adapter. See any LED light go on? Try again, the same procedure now with the battery plug in first, then plug in the AC adapter. See any additional LED lights go on? If there is no different, than the laptop can not detect your battery. If the AC adapter can power up your laptop, you can eliminate the battery (assumed brand new battery) & AC adapter. This only leaves you with the laptop circuitry & contact terminal. If your laptop can charge up your old battery or any battery, then it might be still the battery & contact. So, you try these procedure to reduce down to the "problem" component.
Oct 13, 2009 | Acer Aspire 5315 Notebook
Travelmate only powers up with battery inserted. But AC still charges battery. Orange light goes on and of
Sorry to tell you this but you may have a problem with the charging system. That will require you to return it to Acer or an Acer service center. You can also try this. I got this from Acers' travelmate support website:
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
You can aslo google your specific model of Travelmate to see if others are having this issue.
Les
Jun 27, 2009 | Acer Computers & Internet
No response
First follow procedure to try to reset the power.
May 23, 2009 | Acer Computers & Internet
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
