Question about Toshiba Satellite A45-S250 Notebook
Toshiba Satellite M55-S1001 Laptop
Probem is it automatically shut off. Then I brought it to a repair shop and it becomes bad to worst. Original program was totally erased. A friend of mine told me that from the website I can retrived the original program by relaying the serial from the sticker at the bottom of the laptop. I do not know if my laptop is obsolete or old model. No way I can use the loptop. Is it still repairable or disposable?
  • custodio Jul 23, 2008
    I received the reply of Mr. Benimur with appreciation. He talked sense. I will show your reply to a technician so he can use it as a tool in helping him analyze the problem.
    Thank you very much
    LP Custodio
    Brigadier General:
  • 6,966 Answers
Your initial concern (auto shutting down) with some Toshiba could be caused by excessive power drain by some of the attached devices such as the WiFi, LAN among others. On the other hand, it could also indicate that the battery is already weak and constantly requires charging and at times eats up most of the power from the adapter leaving nothing for the motherboard to use. In some repairs I have done, switching off / or removing entirely unneeded devices correct the problem. In some instances, auto shut down is caused by dirty/clogged airducts/heatsink of the processor, failing blower/fan and/or poor ventilation.
You can have the Operating System re-installed using any Windows (I am assuming XP) OEM installer CD and to use the key printed in the sticker underneath your laptop to make it legitimate. The next challenge would be getting appropriate drivers to make all the devices in and with the laptop work as expected.
As long as it powers, POSTs and boots or look for an Operating System, then it is repairable and then of course would be usable.
There would be a number of qualified techs who could work on your laptop, ask around those who have experienced similar problems and have received good services.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 21, 2008
I need an instuction guide to replace a toshiba satellite m55-s135 hard drive
Here is the Link where you can see how to replace your hard drive in your laptop.
http://www.ifixit.com/Guide/Repairing-Toshiba-Satellite-M45-Hard-Drive/2769/1
But remember to remove your laptop battery before doing anything to your laptop.
and here is anothine link for user menual
http://tim.id.au/laptops/toshiba/portege%20t130%20satellite%20t130%20pro%20t130.pdf
Jul 26, 2012 | Toshiba Satellite M55-S135 Notebook
How to reset toshiba satellite m55 s1001 without disc
You need the recovery disks one for Windows and one for the device drivers.
This WEB site can provide the recovery disks.
http://recovery-disks.com/toshiba/toshiba-satellite-m55-s1001.html
Aug 26, 2011 | Toshiba Computers & Internet
How can chang my vga card for m55-s135
Unfortunately your video card on the M55 is part of the motherboard itself...it is an integrated chip. You would have to take it to a repair shop that has the machine capable of desoldering all the connections and resoldering a new graphics chip to the board. Buying a new motherboard may end up cheaper in the long run, but I have seen repair adds on EBay from companies that specialize in these types of repairs. Give it a look and see what you think.
Jul 01, 2010 | Toshiba Satellite M55-S135 Notebook
How do i store a satellite m55- s1001 to factory settings without disk
to restore to the factory settings press F10 or F11 on startup and then follow the screen prompts you will get two options for recovery destructive and non destructive select the one according to your need destructive will delete your data.
Mar 20, 2010 | Toshiba Satellite M55-S139 Notebook
Toshiba Satellite M55-S325 PC Notebook outsde case
You definitely need to bring your laptop to the Toshiba shop near you. There they can facilitate the replacement of your laptop's body (casing). It is a critical task to do and I think a Toshiba authorized shop can help you with this. Thanks.
Feb 03, 2010 | Toshiba Satellite M55-S325 Notebook
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Apr 22, 2009 | Toshiba Satellite M35X-S149 Notebook
Replace phone plug for Toshiba Satellite M55-S141
Go to ask.com type laptop repair and look for laptop101.com and they have a diaigram for toshiba laptop dis assemble
Mar 20, 2009 | Computers & Internet
Toshiba M55-S1001
4 Beeps means there is a fault with the CPU.
It could be that the fan is faulty and needs replacing, or it coul be that the CPU is dead.
Unless you are technically mined enough to take the machine apart yourself, then your only course of action is to take it to a dealer for repair.
Aug 13, 2008 | Toshiba Satellite A45-S250 Notebook
Cmos setup screen
If you're trying to get to the bios set up, when the initial Toshiba screen comes up it will tell you what to press for the set up towards the bottom of the screen.
Jul 24, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite A45-S250 Notebook Logo
731 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
