Question about Brother Office Equipment & Supplies
Faxes and copies print totally black....! - Brother Office Equipment & Supplies
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Open and remove cartridge, is there toner on the bottom of the machine? There is a strip of lights is it covered in toner? if not that strip is probably worn out.
Posted on Jul 21, 2008
When checking the meter reading on my canon ir c5185, there are the following codes before the totals: 101 102 108 230 321 322. Can you tell me their meanings?
Hello joe,hope you are well.Canon copiers have literally hundreds of "meters " that the device is constantly monitoring.Things like the number of 11x17 scans,reports printed,incoming faxes,outgoing faxes,prints at 600 dpi....etc.Its wild.The device is capable of displaying to the customer a total of six meters.The displayed meters may be customized for the customer by a technician as per the customers request or needs.Each meter is named by a number,for example "101".That particular meter indicates the total of how many sheets of paper(regardless of size) that have successfully exited the machine.102 meter indicates the total number of sheets that have been output using 8.5 X 11' as the basis.So a sheet of 11x17 paper would increment the 101 meter once,but the 102 meter would "click" twice.For billing purposes my company keeps an eye on the 102 meter to maximize profit,as it should be.Now how Canon determined the display of the other meters you see is a mystery.Again there is a meter named 958,which is the number of documents scanned to the MAILBOX. So, to completely answer your question: 108 is the total black and white copies made regardless of size.230 is just color and monocolor regardless of size.321 is{your gonna love this one}color prints on 11x17.322 is color prints on 8.5x11.So there ya' go! TMI city!!! Hope this helps.
Jan 07, 2011 | Canon Office Equipment & Supplies
Copies made are totally black. what do i do? i changed cartridged, put in new paper then copied. it copied fine after 20pages, copy sounded like it was jamming up, paper came out with some parts black....
Hello limay_uera
Please check your Printer setup. or options ( I am not familiar with this printer. what terms they use- I'm not sure) Ther will be options for Print in Color or Black. Make sure the radio button for COLOR is checked. This way, black and color both will print in the correct color. So leave it on color even when you want to print in Black. The black radio button is there for a different reason.
Hope this will help you.
Nov 19, 2009 | Canon FAX-L800 Plain Paper Laser
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Our canon laser fax 1060p receives faxes fine but send out a total black page (also the copy function is a total black page)
No power/failed contact image sensor. If under contract get replaced. It is poss. that a "standard white setting adj." could fix it, but doubtful with a black copy. -Carl
Jul 17, 2009 | Canon L220 Plain Paper Laser Fax
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
On the left side of the on/off switch is there a small button mark with 123 press that button and the meter reading will display.
101 TOTAL ***** -that will be the total of copies,printing,and fax receiving on A4
103 TOTAL LARGE ******-this is the total of the A3 copies,printing and fax receiving made
201 COPY(TOTAL) -this is the total A4 copies
203 COPY(TOTAL LARGE)-this is the total for A3 copies.
Apr 02, 2009 | Canon imageRUNNER 2200
Black mark on right side of paper
The scanner is not working properly, not the printer part of the unit.
The LED array is not lighting causing black scanned prints.
Resolder the contacts in the LED array...probaly a cold solder joint.
Feb 17, 2009 | Brother IntelliFAX 4100 Laser Fax
I can receive faxes but when I send them they are illegible.
make sure glass is totally clean and pad is clean, also could be an issue with your scanner bulb
Feb 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
4 sets of copy counter numbers on canon imagerunner 2200
101:Total black copies and printed pages
103:Total A3 black copies and printed pages
201:Total A4 black copies
203:Total A3 black copies
Oct 31, 2008 | Canon imageRUNNER 2200
Won't print faxes
What printer are you using?
Mar 05, 2008 | Office Equipment & Supplies
James Cagle
James Cagle
Jim Keysor
