Honda Accord Euro In dash CD changer is jammed, won't eject & won't play with error message on screen. Would like to un-jam it but how do I get the unit out?
  • 105 Answers
SOURCE: Pioneer PD F506 changer jammed
It is quite possible that one of the drive belts has come off its pulley.
Posted on Mar 16, 2008
VOTIT
  • 2071 Answers
SOURCE: The CD disc magazine tray
It is the chrome rails bars grease that's hardened already causing to jump the disc. Due to accumulated dust and dirt to the grease.Just take out the old grease with an alcohol and change it with a type-A grease,only put a little amount...
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
hope this may help;
DON'T FORGET TO RATE;
Regards,
VOTIT
Posted on Jul 28, 2008
SOURCE: I have a 1999 Lexus
I feel your pain......and did extensive research on the internet.....Google "LX470, CD, err3" or "Nakamichi, CD, err3".
Take a look at this excellent explanation of how to dismantle and remove the head unit and retreive the jammed discs. I have used it and fished out three discs, but the CD Player still shows ERR3. An hour of work, so be prepared.
http://www.celiamania.com/wordpress/?p=135
This is a site that provides repair services once you get the head unit out. http://www.carstereohelp.com/lexus.htm
"Six CD changer, Err message in display, will not play CD's, will not eject or accept CD's. Before repair, disconnect one of the car battery terminals for several minutes. This acts as a reset and may bring the changer back to working conditions. Otherwise, repair rate $385."
The Lexus dealer wants $750 to replace with a refurbished unit. Don't go down that route. Read these nightmare stories.
http://us.lexusownersclub.com/forums/index.php?showtopic=2346
http://us.lexusownersclub.com/forums/index.php?showtopic=38123
http://www.clublexus.com/forums/showthread.php?t=28371
http://www.clublexus.com/forums/showthread.php?t=50142
Don't buy a stray unit off of ebay, it is probably jammed or broken with the ERR3 meesage too!
If the home repair method doesn't work, then it will be better to just upgrade to a new head unit. I am buying a Jensen VM9215HD to get a multimedia system with all the trimmings and full iPod control for $460. Available on ebay or online stores. I'll install the unit myself, but you can get the unit and the job done at a local auto sound store for under $1000.
Good luck,
Arthur
1999 LX470 97,500 miles, ERR3 CD player
Posted on Sep 17, 2008
killer_clown
  • 86 Answers
SOURCE: I have a Bose Wave
there should be 4 screws on the side, 3 or 4 on the back, take those of an the cover should come off if it dont then theres a screw some were holding it down, when you get the cover off the cd should be plain as day
Posted on Oct 21, 2008
SOURCE: 6 cd changer
try to reset the cars computer. i had the same problem and it fixed it. all you need to do is unplug the battery for about 10 minutes and it may work. Good luck!
Posted on Jun 15, 2009
Jammed cd player
one response I read for this was to use a pencil in the slot and pushed something inside the cd player and it unjammed and the unit started to work again
Mar 20, 2014 | 2002 Honda Accord
Kenwood 10 Disc Cartridge won't eject
From your description it is likely that a CD is jammed in the player, preventing the magazine from being removed. Even though your Kenwood is hard to get to, it will have to be removed and disassembled to correct the problem
Feb 01, 2013 | Car Audio & Video
6 disc cd changer jammed in 2004 mercury mountaineer, says error when i try to eject or play jammed discs.
personally I used another not so valuable CD to push the jammed CD back, it appears the ejected CD may bump the open exit gate and get stalled. It has happened several times. Good luck
Mar 15, 2011 | 2004 Mercury Mountaineer
'03 Honda Accord 6 disk changer won't load/eject
i had the very same problem with a six stacker in my ford, the stacker inside has come of its tracks even by one or two teeth so when the cd tries to eject it jams on the side walls because of this alignment, only way to fix is to take it out and realign. may need to get a mechanic or your dealer to do it like i did as the computer system was attached to my cd player. not sure about the accord but this is a familiar problem with all sorts of 6 and 10 stacker cd players
Jun 23, 2010 | Car Audio & Video
How do you remove cd's from a six in dash changer...it will not play or eject the cd's
hi,
It sounds like the CD rack or cartridge inside the head unit has jammed. The only way of getting them out is to remove the 2 Din head unit from the dash/console,due to each CD being lifted up into the eject position and ejected separately.
If you got the tools you can dismantle and remove them from the head unit yourself. Hope this helps, let me know ow you get on.
Apr 04, 2010 | 2004 Honda Accord
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
Jammed cd player - 2002 Honda Accord
I have a 2002 honda accord with the 6 disc cd changer. I beleve the cd changer has jamed and have lost power to the CD player. When I press the CD button it wont recognise the player. Any suggestions
Oct 23, 2009 | 2002 Honda Accord
2001 honda accord cd disc changer wont work
2001 honda accord with three cds stuck inside. Wont play or eject just a whooring sound and error on display. Any ideas before going to the dealer?
Jul 09, 2009 | 2004 Honda Accord
Have a Blaupunkt AM FM Radio/In-Dash Ch Cgnager (6 stacker) in a 2003 Holden Commodore. After ejecting the 6th one of the CD's succesfully, get "CD Error mech" message and it will not eject the...
We eventually tried loading another CD to fill the one vacant spot we knew was in the changer even though we'd tried that before without success. This time it seems that we fluked it just as it was trying to eject CD 1 again and - somehow - the CD we were tryng to insert must have lifted the rim of the one that was stuck and it suddenly ejected. The remaining 4 CD's that were inside the changer but not even recognised, then started re-loading so it appears that they were all jammed up together. Once they'd reloaded we were able to eject them all successfully then reload.
We're not sure but think that it may have happened when the eject button was originally pressed once to eject CD 6 then, in error, held down for a 'eject all' procedure and the changer has become confused with both instructions.
Jun 01, 2008 | Blaupunkt Car Audio & Video
127 people viewed this question
 Grubhead
Grubhead
