Question about LG 1000W XM-Ready 5.1-Ch. Home Theater System with 5-Disc Upconvert DVD/CD Player
LG home 5 disc dvd changer
Changer make a humming ,swishing , clicking noise constantly while playiny a dvd. noise plays through tv speakes whick are turned off, but even when i turn the tv off the noise still comes from the dvd changer some where inside of it. ,, very annoyoing
    Problem Solver:
  • 5 Answers
Defective call customer support or bring it back to were you bought it
Posted on Dec 27, 2008
How to make region free dvd
Usually a region 1 DVD player will not be able to be a multi region because it needs to be able to convert between pal and NTSC to play on your NTSC TV. Unless the player is a European model then it would be possible!
Oct 01, 2015 | Panasonic DVD-CP72 5 Disc DVD/CD Changer
My RCA RTD 206 5 disc changer wont play DVD's. It stays on Disc 3 or just says close. I called the # in the manual foe help, but its no longer in service.
If it plays the same disc without issues, you have a mechanical(or the electronics powering the motors and such) problem. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | Audio Players & Recorders
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
When playing a DVD on my Panasonic DVD player there is a humming noise which changes pitch each time the scene changes, very anoying, any ideas what to do to stop hum?
tried with other cable connectors that you have been hooked up in the input of the tv. by the way have you been already tried to play with other dvd disc?.
Nov 02, 2012 | Panasonic DVD-S29 DVD Player
I'm having two problems with this unit , a SONY CDP-CE375 5-CD Changer, which I bought several years ago. The first problem: Occasionally, the CD doesn't seem to be seated properly when I close the platter...
Granted, they don't actually SAY you should carefully place the discs into the detents designed for them on page 7, but that is the expectation.
http://www.retrevo.com/support/Sony-CDP-CE375-CD-Players-manual/id/423ci261/t/2/
As for audio hum,
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Consider the presence of light dimmers, too. Mine induce buzz when the lights are on.
Oct 17, 2010 | Sony CDP-CE375 5-Disc CD Changer
Installing a LG Network Blu-ray Disc/DVD Home
YOU NEED TO CONNECT OPTICAL CABLE (NOT INCLUDED) TO OPTICAL1 CONNECTION ON YOUR HB405 AND OPTICAL OUT OF YOUR TV. IF YOU ALREADY HAVE DONE THAT TRY PRESSING SIMPLINK BUTTON ON YOUR TV REMOTE NAD CHANGE THE SPEAKER OUTPOUT FROM TV TO HT(HOME THEATER).
Jun 19, 2010 | LG Televison & Video
Jvc xl-f254 cd changer for home. 5 disc changer. Carousel will not slide out. makes humming noise, possibly trying to open.
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Jan 29, 2010 | JVC XL-F254BK 5-Disc CD Changer
My power won't come on and my cd are inside my 5
unplug and hard reboot should be a button in the back reset
Dec 05, 2009 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
No sound through surround
this is because the home theater receives 5.1 channel... change it it will work...
May 17, 2009 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
try to clean the dvd player it could be the lens that is having a hardtime reading the disk and it causing the noise
Jul 21, 2008 | LG LXD5230 System
LG 1000W XM-Ready 5.1-Ch. Home Theater System with 5-Disc Upconvert DVD/CD Player Logo
610 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
