Question about Nikon Super Coolscan 5000 ED Film Scanner
Problems with batch scans and with filing using a non-Nikon code system
If I scan a batch (trip of slides) with my Coolscan 5000 ED (using a Macintosh) the first slide is scanned according to the settings I chose, but the following scans are scanned differently. I notice this by checking the scans: for the first scan the Digital ICE has worked, but not on the subsequent slides.
Another issue I encounter is that the machine asks me if I want to safe using a non-Nikon code system: in the settings I indicated that I want to use the Adobe Photoshop system, but when I start the scan, the scanner doesn't ask me where I want to save the scan, and the scan shows in the Nikon software, asks me where I want to put it and when I put it in my photo files, I can not open it with Adobe Photoshop.
Who has answers? Thank you in advance for your help.
Rob Overtoom, Cambodia
  • Anonymous Feb 24, 2009
    i need the code you use to pick up the channels on my new scanner.
  • adamwelz Apr 11, 2009
    I have exactly the same issue -- when batch-scanning using the SA-30 rollfilm adaptor it applies digital ICE to the first fram and then not to the subsequent frames.
    Have you had any joy with a solution?
    Adam Welz, Cape Town
Did you try saving your choice of settings as user settings ? That way, they will serve as defaults for all subsequent scans.
Posted on Aug 15, 2008
Will not recognize 5th image on negative strip because 4 and 5 overlap (slight double exposure). How do I scan 5th image?
I inserted my negative holder in backwards on my Nikon 5000 35 mm scanner. Then I could get the last (5th) slide scanned. But I can not get the scanner to work on my new IMac because of no working driver. Silver Fast has no drivers for the Nikon 5000
Jun 16, 2011 | Nikon Super Coolscan 5000 ED Film Scanner
Nikon Coolscan 5000 ED not scanning
Have you tried resetting the scanner itself?
Jul 09, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
The scanner is only 24mm wide and 36 mm long, so rotate you slide by 90 degs.
May 03, 2010 | Nikon Super Coolscan 5000 ED Film Scanner
Trying to install Nikon Super Coolscan 5000 ED, for some reason the installation disc doesn't have the LS-5000 ED driver software...? I am running Win Vista. Any ideas?
I do not believe Nikon made drivers specifically for Vista, but you can use the solution here to make your own driver "inf" file and install some that will work anyway. Please read this and carefully follow the directions. If you are using 32 bit, use the 32 bit drivers. If 64 bit, then 64 bit drivers, when creating the new inf.
Bryan Clark
DVD Your Memories
Slide Scanning Specialists
Nov 16, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Need driver for Nikon super coolscan LS 5000 ED
Go to Nikon's official website, then search for support. You'll be able to download all the drivers and Nikon Scan software. Hope this helps.
Jan 15, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Launch Nikon Coolscan, but browser/scanner window doesn't open
I think the scanner may have got confused and be expecting another adaptor to be connected. If you slot in the single slide adaptor, wait until all the scan functions become active on-screen, then remove that and insert the SF-210, you might find it works OK.
Jeff Underwood
Nov 16, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
Wrong alignment in batch scan
Try scanning these strips with the FH-3 accessory. It may be the negatives aren't being sensed correctly at the frame boundary. This unit overcomes this problem and can often be found at a reasonable price on eBay.
Jeff Underwood
Jul 21, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
Saved files appear as small dark line
For unexplainable reasons, the Software seems to set it self to a crop of 17x1 pixels. Therefore, the files are small and the pictures essentially a small line. A reset of settings to factory defaults corrects this.
Mar 13, 2008 | Nikon Super Coolscan 5000 ED Film Scanner
Scanning monochrome negatives on Coolscan 5000ED
Your killing yourself how big are you going to print this!!! Are you using Vuescan or silverfast for scanning or Nikons util? Stay away from Nikons utility! 2x sample is plenty and turn off ICE for monochrome (it makes a mess of things) but 16 bit yes until you print then go down to 8 after you resize for final print.
Mar 05, 2008 | Nikon Super Coolscan 5000 ED Film Scanner
Coolscan 5000 with SF210
I'm sure all is well but if you have not tried VUescan or Silverfast as opposed to Nikons Util you should.
Feb 15, 2008 | Nikon Super Coolscan 5000 ED Film Scanner
Open Questions:
See all Nikon Super Coolscan 5000 ED Film Scanner Questions
Nikon Super Coolscan 5000 ED Film Scanner Logo
279 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
