Question about Magellan GPS
When I turned it on it shows a blinking screen reading Venus2 UT R10. and then 0=WINCE upgrade 1=GPS Tools 2=BT Tools etc. and none of the normal functions come up.
This happens when both the power and reset button are depressed. In my case the menu came up and the selection between items would loop. Pressing buttons did nothing. It wouldn't even allow me to select anything.
Solved the problem. It appears that the reset switch malfunctioned. I opened it up (hint: use a guitar pick to pry the edges apart) and removed the reset switch. If you don't like to solder you can gently pull the top off the micro switch and that will do it. Cleaned it with compressed air. .... Now all I need is new reset switch.
Posted on Sep 06, 2008
I turn on my device and it only loads up the start page and then hangs there .......
First try a reset... then try turning off the little power switch next to the reset, then turn it back on. If none of this works, your firmware is likely corrupted... then: You either need to return it to Mitac or locate (Google) & flash the firmware file into the unit as follows:
Connect the mio p550 to PC
1.put the Button of the PDA in ON position
2. hold the joystick downward and press the reset button
3.choose "Image Upgrade tools"
4.choose "0=Image by USB"
5.intall the usb driver (PC require the drivers). The driver in the
folder "USB driver" that comes with the firmware file.
6.open the software "dnw5.0e" (also comes with the firmware package).
7.(if you want to make a test of connection USB, click the "USB
port/Status". If all is ok go to step 8
8. click "USB port/transmitted" and to show the way of the file
"MioP550 - Osc260A R05_P09.nb0"
9.press the reset button to restart the mio p550.
Jul 09, 2010 | Mitac Mio P550 GPS Receiver
How do I set the time on this watch?
Hi, function SOswitchMenu() {var el = document.getElementById('bodyDiv');if ( el.style.display != "none" ) { el.style.display = 'none';}else { el.style.display = '';}var el2 = document.getElementById('h2');if ( el2.className == "calHeader goog-zippy-expanded normalText" ) { el2.className = "calHeader goog-zippy-collapsed normalText";return;}if ( el2.className == "calHeader goog-zippy-collapsed normalText" ) { el2.className = "calHeader goog-zippy-expanded normalText";return;}} function SOframeReload() {var f = document.getElementById('soFrame');f.src = f.src;}
I had a watch similar, and it's actually very easy to adjust as soon as you have the solution, so:
You need a very thin stick (maybe a toothstick or a think pencil). 1) Stick it into the upper pinhole (on the right side on the watch). Then it starts to blink. 2) Adjust by pressing the lowest pinhole 3) Confirm with the upper pinhole 4) Now you'll go through each step (hour, minute, date, 24/12h, etc.) 5) Finally you will se the time on the watch (not blinking), If you press the lowest pinhole you can choose between: - static screen showing time - static screen showing date - shifting screen showing both time and date
Br. M
Dec 14, 2009 | DKNY NY1304 Watch for Men
Black screen and no sound on TV
what is the brand, model? try to be specific if you want be helped!!!
Sep 11, 2009 | Televison & Video
Magellan 3100 frozen on blue screen with black progress bar
where are you getting that error message, on the pc or the 3100
Aug 05, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Thinks the GPS is always located at home
Follow these steps to set your current location as home location.
1. Power on GPS
2. Touch "Tools" on screen.
3. Touch "My Data" on screen
4. Touch "Set Home Location"
5. Touch 2nd option "Use My Current Location"
Thats it !
--Sandy.
May 29, 2009 | Garmin nuvi 350 GPS Receiver
Processor used at Gps NVM-4370
Samsung S2443 400MHz / ~61MB RAM / WinCE 5.0 Core
Communication Settings:
COM1 - S2443 GPS COM1
Baud: 38400
COM3 - TMC COM3
Baud: 38400
COM5: S2443 BT COM5
Baud: 38400
COM9: S2443 DVBT COM9
Baud: 38400
Mar 16, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
I NEED HELP!!!
you have to manually reload firmware, if you get the dvd I sell on ebay you should be able to run the update file to reload, this is if wince has not been damaged... search ebay for finedrive dvd.
Aug 04, 2008 | Fine Digital FineDrive 400 GPS Receiver
Can't hear incoming calls (they can hear me) after using GPS/bluetooth navigation
Since I don't have a GPS, I haven't had this problem myself, but one thought does come to mind.
Does your Bluetooth Manager correctly identify your GPS? If it is misidentified as a hands-free connection, for example, the SX-66 may be sending incoming audio to your GPS. Try checking your Bluetooth Manager next time you connect your GPS, and/or deleting the existing GPS profile and setting up a new connection for it.
Nov 08, 2007 | Siemens SX66
Problems with e800BT and com ports
I use an e830 with a Holux GR230 without having any problems. The e830 uses already the latest stack from Toshiba so no need to upgrade. For the e800, hm depends on what kind of BT SD card you use, meanwhile Toshiba sells the BT SD3 card. Anyway, I would recommend to use the latest BT stack from Toshiba for your Toshiba BT SD card.
Sep 08, 2005 | Toshiba e800 Pocket PC
GPS Logo
118 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
