Question about Apple iPod nano
Set a code
How do i set a code for my ipod to make it secure?
    Guru:
  • 158 Answers
When your on the main menu, go to Extras. Then go to Screen Lock. Enter a combonation. Press lock. DON'T FORGET YOUR COMBONATION.
I hope this helps. Please rate this solution.
Posted on Nov 30, 2008
  • 38 Answers
Go Menu> extras >screen lock > change combination  then turn screen lock on
Posted on Jul 21, 2008
What is the four digit factory reset code for ipod?
Only the person who set the security code on your iPod will know that!
Sep 16, 2015 | Audio Players & Recorders
Remove security code
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 20, 2007 | Apple iPod nano
Got locked out i pod touch
How to Unlock a 16GB iPod Touch
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
Dec 05, 2011 | Apple iPod nano
I have a Ipod nano 4gb and someone set the volume limit and i don't know the code is there a way I can reset it.
Hi, Sorry to say that there is no such options so that you can reset the password...untill and unless to restore the ipod....( Due to security reasons ther is no such option)
Jan 21, 2009 | Apple iPod nano
I forgot my code for my 2GB ipod nano
If you forgot the security code you will have to open up ITunes and hook up your Ipod to your computer. In the Ipod settings under Itunes select restore your Ipod to factory settings. This will erase the code feature. You will have to reload your songs and activate a new key code on your Ipod if needed,
Nov 30, 2008 | Apple iPod MP3 Player
Ipod touch
verify wireless settings in your router. Check if the security enabled in your router is already supported by your IPod touch. Otherwise, set the wireless security of the router to a mode that is supported by your IPod touch.
Sep 14, 2008 | NetGear WGR614 Wireless Router
Forgot my security code
hold down the menu and the center button
Sep 05, 2008 | Apple iPod MA446LL/A MP3 Player
Security code
You have to restore the software to factory settings in Itunes to get it to work properly and to reset the code.
Jul 23, 2008 | Apple iPod nano
Connecting ipod touch
Press pairing 1 button on the back of the livebox and then type in security code make sure that you type in each character in capital letters as the code it is case sensitive (don't set caps lock) for each character use the shift key - You will now be connected to the livebox.
Jan 15, 2008 | Audio Players & Recorders
Apple iPod nano Logo
63 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
