Toner drum chip reset for xerox docucolor 250
Sir,
I am Ekambaram from India. Pls. help me to sort out the chip problem in Xerox Docucolor 250. Both the chips (drum and toner) work with infra red protocol.
  • 2 more comments
  • ekambaram_v Jul 21, 2008
    Anybody who has solution to this, pls. contact me
  • ekambaram_v Sep 24, 2008
    Still trying
  • armandopro_1 Nov 13, 2008
    Plis help me with the chip of docucolr 250
  • H Thagunna Apr 19, 2018
    Please let me know working Xerox DocuColor 250 chip resetter? If it is possible give me seller's contacts.
Dc250 crum reset solution done yes B Patel mumbai 09029222006
Posted on Sep 23, 2009
  • alexey-shakh Apr 06, 2011
    Please let know have you ready and good working Xerox DocuColor 250 chip resetter?
    Thank you.
    e-mail: alexey-shakhov@mail.ru
  • Sriram Murthy
    Sriram Murthy Jan 18, 2013
    Please let know have you ready and good working Xerox DocuColor 250 chip resetter? If it is possible give me seller's contacts.
Pls Anyone know where I can buy CHIP RESETTER for Xerox 013R00602 Drum Cartridge - Blake and 013R00603 Drum Cartridge - CMY. Vladimir
Posted on Feb 28, 2011
I am also having the same problem I am located in Mumbai
Please Contact me on 09867289866
I know you, but i dont have your number
regards
Pragnesh
Posted on Sep 22, 2008
  • 4 Answers
You can purchase in an infinite drum reset kit for about $75.00 for the Xerox printers and that printer model at: http://www.evaluboard.com http://www.evaluboard.com The list of supported printers for the drum re-setter at: http://www.evaluboard.com/printerindex.htm http://www.evaluboard.com/printerindex.htm
Posted on Jan 09, 2012
Where are you located? Send your contact details on enerhyinpeace@gmail.com.
Posted on Aug 02, 2008
Can Xerox DocuColor 3535 toner ink be used in Xerox WorkCentre 7228?
From experience, I wouldn't do it...
The different series usually have slightly different toner composition, so you may find that your copier will be majorly over-toned or under-toned. by doing that.
I personally wouldn't risk it, and I have been in the industry 24 years...
Oct 26, 2014 | Xerox Office Equipment & Supplies
Can you reset toner level in Xerox DocuColor 260?
Usualy what i did i use toner chip (100%) fix it to toner cartridge then insert to machine, check the amount if 100% then pull out the toner cartridge and replace old chip insert back to the machine, check it will be 75%.
Sep 05, 2014 | Xerox DocuColor 242-252-260 PS
Xerox docucolor 1632 fault code: 004-341 the printer doesn't print at all
Try reseating the waste toner then all 4 drums, see if the chips are mating.
Most likely either the machine software is corrupted and needs to be reloaded, or the MCU board has failed, could also be a bad laser, called the ROS.
Jan 02, 2010 | Xerox DocuColor 1632 Laser Printer
Toner cartridge error
Please try to use your USA based chip placed on the toner cartrage and replace the same with the europe cartrage. It will work
Mar 05, 2009 | Xerox DocuColor 240 All-In-One Laser...
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
How do I reset the indictor on a Dell printer cartridge after refilling it? xerox docucolor 12 printer
If this is a monochrome laser toner cartride you may need to purchase a CRUM chip to replace the one on the toner cartridge. If you had your cartridge refurbished by a company who specializes in this and they did not reset the CRUM you do not need to use them in the future. There may be a way to cancel the add toner message in the service mode so I will keep checking and post an updated solution should I find any available information. Could you confirm that it is a Xerox Docucolor 12 printer made for Dell?
Jun 03, 2008 | Xerox DocuColor 12 Printer
No Magenta Color Printing, Xerox Docucolor 1632
Are the properties set correctly in the print driver.
You can turn certain colors up or down.
Does is copy magenta?
If so I would suspect the driver or the settings within the driver.
If it does not copy magenta, then I suspect a developer housing issue.
Printing only then suspect a driver issue.
Oct 22, 2007 | Xerox DocuColor 1632 Laser Printer
2,145 people viewed this question
k24674
jasbo
jasbo
