We just bought a plasma TV to put in our new extension. We get good reception at the old end of our house and poor to none at the other end (variable). What can we do?
  • 161 Answers
Is it using a tv antenna? Cable? Or satellite?
Posted on Jul 21, 2008
Hi, ihave a plasma TV, sometime ago and it has only been since we moved houses, our TV goes pixelated and then we get No signal on 1-2 channels, and now we have no signal full stop, i have a booster...
You have antenna issues. Try raising the antenna some more or relocating to another spot where the signal strength is greater. Pixelation is a sign of a weak signal -
Jul 02, 2017 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Just bought a house and moved in. I have plug the TV into the wall antenna socket and the TV comes up with the message 'weak or no signal' what could be the problem?
Hi, congratulation on your new house!
The problem is obviously from your antenna. The TV is not recieving any reception from the antenna and that is why it is displaying 'weak or no signal'.
Cross check your antenna connection and make sure the antenna wire is intact.
Also, most antenna's come with a booster. The booster makes reception from the antenna very strong and the TV would be clear.
Lastly, is this a new antenna or were you using it in your old house?
Please give me a feed back.
Yours sincerely.
Elect_Comp.
May 12, 2011 | Televison & Video
Some channel no sound
Hello Blwas5 hi, If some channels have sound and others none, its either the TV has poor reception or, its the channel's weak signal. check them both or see if your neighbors TV acts like yours. If thy neighbor reception is good, then thy TV has poor reception, you can't do anything to fix that. get another TV with good reception qualities.
Jun 18, 2010 | Sanyo Televison & Video
Innovage wireless headphones/how to connect to TV?
I have a plasma, and found when I plugged my HDR65 to back of the plasma audio out, it worked fine. does this help?
Jan 06, 2009 | Audio Players & Recorders
Poor picture and tv blacks out
Make sure you have the TV connected correctly. If you have a cable box or satellite receiver and are connecting using an RF connection to the TV's antenna jack, you need to be on the right channel (usually 3, maybe 4 depending on the box setting). If you are connecting using A/V cables be sure you don't have a bad cable and that you're connecting to the proper jacks. If you are trying to pick up digital broadcasts off-the-air, you might need to adjust your antenna or put up an outdoor one. Signal strength is very important to digital reception.
If none of this solves your problem you may just have a defective TV. If it is really so new it will be covered by the manufacturer's warranty, and may still be in the store's return period. Call for service or exchange it.
Dec 15, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Plasma TV Reception
Bro the reception in that area of the house must be poor, as you've said. The walls in that area of the house must be too thick, or some part of the house is blocking the signal that the attena emits. You should consider getting an antenna that can be placed outside the house, like on the roof top. Make sure it isn't being blocked by anything, like trees with large branches or whatever.
Jul 21, 2008 | Televison & Video
LG CU-500 Poor Reception
please clean your motherboard with accitone
and give a little bit of heat on motherboard
hope it works
for more information
you can mail me
raj_the_great2008@yahoo.com
thanks
Mar 22, 2008 | LG CU500 Cellular Phone
Poor reception
It sounds like a problem with the tuner in the TV set. Hook up a VCR through the video inputs and hook the cable through the VCR and if the picture is still snowy, the problem is the cable. If the picture is clear, the problem is the tuner in the TV set. If you wanted, you could simply leave the VCR attached to the TV set and change cable channels through the VCR, or have the TV serviced. Good Luck
Jun 20, 2007 | Mitsubishi CS-40505 TV
Missing channels
no they are not related. ur tv seems to have a defective tuner(inspect also for possible cold solder inside the tuner). remote control can be clean using a cotton swab with a little isoprophyl on it. clean the contact on the pcb.
Jan 14, 2007 | Samsung TXN2745FP 27" TV
Poor cable connection
radio shack sells type f/rca adaptors
Jun 28, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
