Question about Jura Capresso Impressa E75 Espresso & Coffee Maker
E75 water is going into the tray
All of a sudden, any water or espresso is coming down directly into the tray. Nothing comes out the front anymore. This is on my, usually reliable, 5-yr old E75. I tried a cleaning cycle to no avail. What's causing this?
Thanks so much for helping!
    Problem Solver:
  • 7 Answers
You need to replace the drain valve this is located on the bottom of the brewer system
Posted on Feb 25, 2012
    Problem Solver:
  • 14 Answers
Brew unit needs repair or replacement. www.hotncold.com
Posted on Aug 03, 2008
Water leaks into pod drawer and not much espresso comes out
The brass plate shown in the box must be free to move up and down about 1/8". Here it is in the down position pressing against the pod to make a seal. If yours is stuck in the up position, the water will go over, rather than through the pod; and drip into the tray. Access is easy. Remove the top. Then take out the 2 phillips screws behind the door which hold the front panel with door and lights. Gently lift the panel up and out of the way. Run the machine to see if this is your problem. If so, free-up the plate by using a screwdriver to pry it down, and a piece of wood to push it up. Repeat this several times.
May 12, 2015 | Lavazza Espresso Point Capsule Machine
Leakage from bottom
open the back cover ,then the side covers and you''ll see from where the water coming.
Dec 02, 2013 | DeLonghi EAM3500 Espresso Machine/Coffee...
I have a Krups xp2070 that sends hot water to the overflow instead of through the espresso (when trying to brew espresso).
The unit has two pressure valves that control release to the drip tray. Once they fail the hot water will go directly to the drip tray when the pressure goes up. The fix will be to replace the pressure valves (pair in series) which only cost about $20. I replaced mine and it fixed the problem. Good luck and happy espressos.
Dec 29, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Open tap - filling system - close tap
Try using warm water in the watertank, important that the water is not too hot, it can cause leakage in the o-rings in the fluidsytem.
Repeat the procedure a few times, if nothing helps, turn off the machine and wait 1 hour and try again.
If you can`t get around this message, then the flowmeter needs to be changed.
Jul 10, 2009 | Jura Capresso Impressa E75 Espresso &...
No coffee will dispenses
I would remove the coffee spout and check the lines into it. The coffee seems to stop when it hits the spout and goes through the by pass instead. Remove the spout(be careful) then run a coffee and see if it works.
May 24, 2009 | Jura Capresso Impressa E75 Espresso &...
On Rinse nothing comes out?
Do you seem to end up with more water in the tray now then you did before this problem started? Does your coffee seem weaker then before? If so I have some ideas for you.
Mike
Apr 16, 2009 | Jura Capresso Impressa E75 Espresso &...
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
Impressa E75 leaking out bottom
kat346 There are a number of places were the leak could be occurring. I can't pinpoint it without see inside your machine. I maybe something like a broken or dried out oring or a cracked fitting or heater cartridge. We repair E75 www.hotncold.com
Feb 05, 2008 | Jura Capresso Impressa E75 Espresso &...
Jura Capresso Impressa E75 Espresso & Coffee Maker Logo
272 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
