When you first get on the computer the screen is fine after about 15 minutes to 30 minutes it magnifies and gets lines in it also some of the colors get little xxxx in them its a dell desktop and you have to shut it off to fix it
  • 84 Answers
Try to set in the control panel, display , then settings, and adjust the screen resolution applicable to your monitor.
Posted on Jul 21, 2008
Pls help me to reset my password on my new samsung notebook N150Plus, i have upgraded from windows starter to windows 7 home premium which is fine, but for the life of me i can not remember my new...
Please boot your computer with the Vista DVD and choose repair before pressing the install button.
This will take you to the windows Recovery Environment. Choose command prompt.
In the command prompt please use the following procedure to get the password disabled Type the following command and hit enter after every line
c:
cd windows
cd system32
copy magnify.exe magnify.old
copy command.exe magnify.exe
exit
Restart your computer (without the DVD) and when you are at the login screen click on the ease of access button and then click on magnify button, instead of openning the magnifier application.
in this command prompt please type the following command and hit enter at the end of the line.
net user *
Note: Replace with your actual username also remove the symbols also.
type exit and then click on the username in your login screen, you should be able to access your computer.
Dec 25, 2010 | Samsung Computers & Internet
Graphical Failure after 30 minutes
Nothing really you could do unless your good with a solder ....sounds like when if runs games it starts to over heat and the connection on the video output internally is getting loose. The system doesnt run as hard when it plays a dvd but once a game goes in it needs alot more to keep playing it ...i would take it to a computer repair shop or contact xbox them self i thing they extended there warranty's... hope this helped you out a little.
Oct 24, 2009 | Microsoft Xbox 360 Console
My screen has color lines in the middle do i have to change
Same with you i have may experience also regarding a color lines in my laptop monitor, so what i did is that i find a computer shop in my area and i let my laptop checked with their technician and ask what is the problem of my laptop then the technician explained to me what are the causes of those lines and then they fix it for me. So i just wait for 30 minutes then my laptop is back to its original condition.
So my recommendation: please find a computer shop in you place and let them check and fixed the problem.
thanks
Aug 04, 2009 | Toshiba Satellite P105-S6207 Laptop
ViewSonic VA912 half screen dead after 30 minutes
first i confirmed that the problem was in lcd.then i predicted that some display chip on the motherboard are getting heat.due to which the display was performing irregular then i switch on A/C of my room.and the temperature was cool. and the monitor was working fine.
Apr 29, 2009 | IBM E54 (Pearl, White) 15 in.CRT...
Fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Jan 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Yellowing screen after 15 minute great working!
styber,
While CRT monitors are very good with color rendition, they do have a warm up time (at least 30 minutes before to get the truest color they can give) they also lose brightness and contrast over time. Since you do Photshop work and color is important to you, you should consider a new monitor, if you want to stick with the CRT style they are still available cheaper now because of the popularity of the thinner lightweight space saving LCD's, but you can get a new LCD which will be better that the .26 dot pitch you are used to on the HP. Depending on the extent you rely on your monitor for color accuracy, you can find a reasonable replacement monitor all they way up to an outrageously priced model which has lots of adjustments. Be be advised all monitors are going to look different and all should be calibrated, either visually with software based adjustment or with a hardware / software monitor calibration. That's a whole different solution - ask if you want to know more. I personally went from a 21" Sony CRT, huge and heavy to a 20" widescreen LCD, no regrets, the images are clear the display is stable. So go and look at them at your local computer store. The cost to have the CRT repaired combined with shipping (the weight is a factor) was just under the cost of a new LCD. There are very few user serviceable parts for monitors and repairing is not as economical or practical as it was back in the days of "TV Repair" shops.
randy320sgi
Jan 12, 2008 | HP 91 (White) 19" CRT Monitor
Samsung hlp 4663w picture is all horizontal lines
Bad color wheel...have it checked by a quaified tech.....
Must have lamp code number to get color wheel #.............T.
Dec 08, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Right third image filled vertical lines when hot
The Philips service folks in India told me its a panel issue and panel needs replacement . They advised me to go for a new TV instead.
If you guys learn anything new ... do let me know ... Viva
Oct 29, 2007 | Philips 26PF9946 26 in. LCD Television
Image distortion
Might be a loose connection to your screen and motherboard.
I have the somewhat same issue with my Dell Inspiron 15, It's a touch-screen laptop and whenever you jerk the screen it'll either Freeze in like colored bars, or it will change colors. Both of which are annoying.
If anything, it may be a loose connection.
Sep 04, 2017 | Acer AL1914B (Black) 19 in. Flat Panel LCD...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
