Question about Acer TravelMate 4100 Notebook
Acer travelmate 4100 lcd problem
I have problem with my laptop when i switch laptop on the screen u can that is booting up but the LCD screen is just black...Can u pls tell me what is wrong with it and where can i get a LCD screen in the cape town area in South Africa
  • 476 Answers
I have seen many dead lcd screens pass across my desk for repair,
no easy fix for this at all,
Its normally the inverrter or the screen itself.
I'm not sure who would be able to fix this is south africa but the www.Acer.com may be able to suggest the agents local to you.
But I beleive there pricing for screens is crazy,(My opinion)
Its easier to buy a dead machine and transpose the screen a ditch the body or keep it for spare parts for you machine,
If you pick up a second hand unit cheap then get the lid changed over even if you can't do it yourself then it would still work out cheaper to have someone do it for you,
You could search the correct screen from your make and model or take the original info from the back of the screen,
(means you will have to dismantle the beast yourself).
They are a little fiddly but do-able,
only other thing how much are you prepared to pay....
Screen spares and Post n packaging or shipping and/or Labour.
I have screens shipped from the one side of our country to the other,
Geographically in the southern hemisphere,(by Australia)
North Island to the South Island (New Zealand)
www.newzealand.co.nz
Absolutely no issues at all,no busted screens in transport,
Just make sure they're packaged well and they should travel well.
Use a reliable courier service and track n trace is easy to follow up.
Go the All Blacks,
Go Kiwi Go.
Thanks
Posted on Jul 21, 2008
Price of LCD screen and keypad of acer TravelMate 290 series.
Go to www.ebay.com Type: make and model of laptop, refine search to screen and keyboard.
Apr 27, 2012 | Acer TravelMate 290 Notebook
I am having a ACER TravelMate 5730 laptop. For the past three or four months whenever I boot my laptop it gives a blank white screen. If I reboot one or two times it will be ok and works fine. Sometimes...
2 Solutions Possible.
The connection between the LCD Screen to the motherboard is not connected well and is causing the issues you are having.
OR.
The screen itself needs to be replaced because it defective.
Mar 16, 2011 | Acer TRAVELMATE 5730-6984 LAPTOP LCD...
My acer travelmate 4100 has crashed. I've tried to go into safe mode to fix it, but the screen turns blue again and nothing else seems to work. This has happened before, bit it was fixed without any...
If you have windows CD or DVD
Boot from CD (you have to go to the BIOS to change the boot order: F2, F10 or delete key)
Then Run the Repair Console
When you are in the Repair Console Screen
Type 1
Then Type your Admin password
Then: chkdsk -r
Hope that this help
Nov 15, 2010 | Acer TravelMate 4100 Notebook
My acer travelmate 4100 will not power up when I switch on. The green power button is lit but the screen is blank and and there is none of the normal "booting up" noises it's just silence :-( I have tried...
hi michelle, first check to see if you can even get to your BIOS. if that is not posible then you might have either a power supply or motherboard issue. for either one of those you will need to send for repair.
Aug 11, 2010 | Acer TravelMate 4100 Notebook
Blank screen on my acer laptop, it boots up, and i have put it on an external monitor, and it brings the screen up on the laptop,also tried changing the screen from 1 to 2 so the lcd is not broken, tried...
If an external monitor works fine then maybe you're having issues with the LCD's backlight. It happened to my laptop and I had to replace the whole LCD itself.
May 11, 2010 | Acer TravelMate 7120T (91.42A01.605) PC...
Acer travelmate 4100 works fine with no battery
Try to use another OS, like Ubuntu Live, and see if the mouse and KB will freeze. If they wont freeze, It is better to reinstall the OS.
If they will freeze again with Ubuntu, then I am sorry to tell you that the battery life has finished.
The only thing to do is to replace it for another one new.
Thanks for rating!!
Apr 21, 2010 | Acer TravelMate 4100 Notebook
White screen on Acer Travelmate 7720
most likely you have a faulty LCD screen, the only option u have is to replaced it or u can use a external LCD screen to act as screen for your laptop. you'll be needing a VGA cable to connect your laptop to any LCD screen available.
Dec 16, 2009 | Acer Aspire 7720 Notebook
LCD is on...seems like backlight is not functional; when external monitor connected, boot-up and bios screen visible. After boot-up, screen goes to "power save" mode and will not return
Use the 'FN' key (blue coloured?) and one of the other blue-coloured keys to "toggle" the video:
1. LCD only
2. external monitor only
3. both LCD & external
After boot-up, Windows defaults to "LCD only", and so the external monitor goes to "sleep".
Dec 11, 2009 | Acer TravelMate 4010 Notebook
When i switch on my laptop it does not display anything on the screen but it is on? why
does it sound like it boots up? if yes problem with the LCD screen. does the LCD lit up? if no problem with the inverter or lamp.
Jul 07, 2009 | Acer TravelMate 240 Notebook
ACER 4100 TRAVELMATE
If this happened suddenly, the backlight power supply (inverter)  has probably failed. It could be the backlight itself but they normally will dim or flicker before they die.
Try shining a light at an angle on the display with the computer turned on and look at it from an angle too. You may be able to see video very faintly; if you do, then it is as described above; a backlight problem, not the LCD display itself.
Jan 22, 2009 | Acer TravelMate 4100 Notebook
Acer TravelMate 4100 Notebook Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
