Question about Pioneer DV-270-S DVD Player
No Disc I have a problem my DVD player sometimes in 15-20 attempts plays a DVD corectly but almost every time it gives an error saying NO DISC whereas I have inserted the DVD/CD correctly please suggest me what to do?
    Brigadier General:
  • 6,966 Answers
Initially, try cleaning the lens using a CD ROM disc cleaner similar to those used in PC's CD ROM drives. They are normally and readily available from most computer shoppes. If the cleaning would not be corrective, pls try to manually clean by opening and use cotton buds to clean the laser/optics. it may also be worth your while to spray the insides with a can of compressed air to remove dust. Re-application of lubricant to the mechanical portion would also help.
If none of the above solves the problem, then chances are that the laser wiould require replacment. Considering the cost of repair and downtime, it might be more economical to purchase a new unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 21, 2008
All my DVDs say "invalid" when I try and play. This just started all of a sudden. Was working just fine before.
Always first unplug for a minute and make sure the discs are VERY CLEAN. Sometimes my player/recorders give an error message 2-3 times but eventually are able to load the disc.
Mar 29, 2014 | Toshiba UNTESTED, AS IS BDX2150KU Blu-Ray...
Dvd player will not play dvd disc keeps saying cannot execute command
Some DVD players may display a Check Disc error.
Use a soft cloth to clean the disc; the disc may have fingerprints or smudges.
Examine the disc for any cracks or scratches that might be interfering with playback.
If attempting to play a DVD-R, DVD-RW or other recordable DVD format, make sure the disc format is compatible with the DVD player. For more details
Professional Quality Bulk DVD Replication Services Scotland UK...
Jan 12, 2014 | Element Electronics EDBCO11 Blu-Ray Player
DVD player wont eject dicks or play just say's disc error
You need to insert dicks into the DVD player, also, once it ejects the dicks, you should wait 20 minutes or so before attempting to eject more dicks.
Jun 26, 2012 | Televison & Video
My lg bd50 is able to play any normal dvds however it is unable to play any bluyray dvds!!! when a blueray is loaded into the machine you cannot even eject the disc for sometime. i downloaded updates to...
hi,
blue ray players takes one to two minute to read the content. it will not read as fater as dvd. give some time and then find out what the player says. error or no disc. also check ur BD's region and the region of the disc u inserted. BD's comes with only one region.
ok
Dec 17, 2010 | LG BD350 Blu-Ray Player
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
DVV Player won't play disc
Check to make sure your player can play other disks. If so then use the disk doctor to remove the scratches on your favorite disk. The area that all DVD players scan before playing a disk is probably smudged or scratched.
Nov 21, 2008 | Philips DVP3345V/17 DVD Player/VCR
LG dvd player DP281B shows disc error
if you have USB PORT. JUST remove the disc from dvd unit and plug in a usb pen drive with usb port.
if you haven"t.USB PORT JUST BUY IT FROM LOCAL ELECTRONICS SHOPS AND FIT WITH YOUR DVD player.
Oct 22, 2008 | Electronics - Others
When trying to play DVDs the words unknown disc title appears. Even after several attempts with various DVDs we havent had any success.
have u tried cleaning the hea of ur dvd player?after using a dvd player or cd player for long times of continous play say 6 months or if u play too many scratched discs and u dont clean the head of the player it starts skipping the disc or many a times dosnt recognise the disc so it'll give u errors like "Unknown Disc", "Disk Error" etc so i would really recommend u to clean its head using a dvd head cleaner cd.. its easily available in the video stores or malls.. u can purchase any dvd head cleaner cuz there are number of manufatcures for this. im sure this would solve ur issue.
PLEASE DO RATE ME,WOULD REALLY APPRECIATE IT
THANX
Oct 06, 2008 | Philips Televison & Video
Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
Dec 03, 2007 | Insignia LCDTV26 26 in. Television
Pioneer DV-270-S DVD Player Logo
203 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
