Question about Sharp LL-151MU 15 in. LCD Television
Picture flip is there any way to search for LCD that have the picture flip feature, like many of the Sharp LCD's. and are there any other manufacturers who build TV's with picture flip?
4 Suggested Answers
SOURCE: Sharp LCD 42" picture to dark
No, just go into your setup, and adjust the darkness. Should work for you.
Posted on Mar 03, 2009
  • 5 Answers
SOURCE: New Sharp LCD tv LC42SB45UT just hooked up and
Try tuning it manually instead of Autostore...(check system if compatible)
Posted on Dec 08, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a 42in sharp LCD tv. I'm getting sound but
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on May 20, 2011
Sharp Aquos Smart tv flipped screen
Hello Danny,
Have you tried resetting the TV to factory settings?
I would suggest to try that and see if it works..
Good Luck
Jun 10, 2017 | Sharp Televison & Video
What is the cost to replace picture tube on Sharp LC-60LE452U
Picture Tube ? You mean LCD panel ?
LCD panels can be expensive especially if they are large like 60"
Moreover the LCD panel do not fail so often except when there a physical damage compared to other parts like TCON.
So you normally cannot find a spare.
https://www.partstore.com/SearchResults.aspx?q=NQP705600L7F08%E2%80%8B&ctf=Parts&sa=1&sp=1&sm=1&rsp=PMN&x=0&y=0
I urge you to verify
Moreover it is not easy to find an equivalent panel as many features depend on the panel properties
Google for Led panelPart #: NQP705600L7F08
try
Search results for LC 60LE452U
May 29, 2016 | Sharp Televison & Video
What is opc light on my sharp aquos tv
This can be called Optical picture control and it adjust to suit the room light.
Please read the text below"
Dynamic Backlight Control - One of the nice features of the Sharp AQUOS LC-32D6U is what Sharp calls OPC, a name they use for their dynamic backlight control. You might also see this feature referred to as a dynamic iris on other LCD HDTVs or disguised under some proprietary name, but fundamentally the principle is the same. Its primary function is to try and maintain a high Full On/Off contrast measures the ratio of the light output of an all white image (full on) and the light output of an all black (full off) image. 2) ANSI contrast is measured with a pattern of 16 alternating black and white rectangles. The average light output from the white rectangles is divided by the average light output of the black rectangles to determine the ANSI contrast ratio. When comparing the contrast ratio of video devices make sure you are comparing the same type of contrast. Full On/Off contrast will always be a larger number than ANSI contrast for the same video device.">contrast ratio under any lighting condition. So when room lights come on or off or the sun enters the room, with OPC enabled, the backlight in the LCD will dim or brighten depending on the amount of light in the room. This is managed by a light sensor located on the front of the unit. When OPC is enabled there can be a slight reduction in the dynamic range of the display as the display attempts to maintain contrast and color saturation as room light changes. We had a chance to compare this feature with another LCD HDTV that was of comparable size but without dynamic backlight control, and the Sharp AQUOS LC-32D6U with OPC enabled was the clear preference.
Jan 24, 2011 | Sharp Televison & Video
LCD PICTURE UPSIDE DOWN
This is a feature not a bug...The LCD is designed to flip the picture when you rotate the screen. This is so that you can see what you filming or be in the picture and see yourself filmed. I can't remember if it flips automatically or not. But, I would first try inverting and reverting the LCD screen to see if you can get it to detect orientation, then check and see if there is a setting to manually set the orientation of the LCD instead under the menu options.
May 05, 2010 | Sharp Viewcam VL-Z3U Mini DV Digital...
Can't Find the Operation Manual for Sharp LCD TV Model LC-32D47U
Try to download the manual from this link if your LCD is the LC-32SB23U.
Sep 19, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Sharp Aquous will not turn on.
I would check the System Cable that is linking the box to the TV. Then, press the small button called CLEAR in the front of the box. The button should be behind the flip cover on the front right below the PC input ports.
Let me know if this solution works.
Jun 01, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
No picture controls
Check your owners manual look for the section that tells you how to adjust the televisions features using the on screen menu.You probably Have it set on auto adjust. You must turn this feature off, to use the manual controls. If this does not help go to the Sharp website and search the frequently asked questions and troubleshooting sections. Search for your problem and similar one that may have answers. If all this fails you, call technical service and ask them for help with your problem.Hope this helps you with your problem.
May 12, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Changing settings
Hi cajun51man
If you go into the User Menu of the Projector look for a subfolder that reads either Flip Image or Mirror.
Scroll down to it and scroll left or right - this will switch between the image features.
May 26, 2008 | Sharp Notevision XG-C50X Multimedia...
Screen has faint "water mark" looking images on both sides of picture
Then the only possibilitiy at this point is the LCD panel having some kind of defect in it. Since you flipped the picture and no change it is a permanent mark or failure. Check to see if you have any warranty left as this will be an expensive part if needed. They do list a diffusion sheet part number PSHEP0288CEZZ that will probably be the first layer of the screen assembly.
May 09, 2007 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Sharp LL-151MU 15 in. LCD Television Logo
91 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
