How to remove platter on Optimus Lab-1100 Turntable
My mum bought a turntable the other day, and I lost the belt inside itwhen trying to set it up. So basically I want to know how to take theplatter off it so that I can put the belt on it properly.
  • purnin Jul 24, 2008
    Are you sure? It seems to be on pretty tight...
On the shaft in the center where the hole of the record goes there is a locking washer on it . you can carefully remove this with a thin knife of something similar . you may need to use a little force , it is on there pretty tight however it can be removed .good luck
Posted on Oct 26, 2008
  • 515 Answers
The platter just lifts right off. No special tricks or anything. Just lift the platter up!
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Posted on Jul 23, 2008
  • TERMiNAL OPTiC
    TERMiNAL OPTiC Jul 24, 2008
    No, I am not sure, however 99% of all turntables allow for easy platter removal for drive belt replacement. This is a Radio Shack brand unit, so it might just be this is the 1% that does not come off easily. However, I did manage to locate the operation manual for you:
    http://support.radioshack.com/support_au...
    See if that helps.
HOW TO INSTALL A BELT ON A OPTIMUS LAB-1100 FULLY AUTOMATIC TURNTABLE
See:
http://www.youtube.com/watch?v=FTJd_WbEhEs
If you have difficulty lifting the platter off, raise it as far as you can and gently tap the spindle with a sift-faced hammer.
Sep 23, 2014 | Audio Players & Recorders
HOW TO INSTALL A BELT ON OPTIMUS 1100 TURNTABLE
Take a look at:
https://archive.org/details/Turntable_Belt_Installation
If you have difficulty lifting off the platter as shown, lift it up af far as you can, and while holding it in place, gently tap the spindle with a soft-faced hammer,
Sep 22, 2014 | Audio Players & Recorders
Connect optimus lab 1100 to macbook
The type of computer is not relevant. This turntable provides output at nominal "line level" and can be connected to your MacBook with a properly shielded audio cable through the audio input.
For best results, you might want to disable automatic-gain-control (AGC) in the "Sound" preferences pane in the "System Preferences" panel, and set the level manually such that the input does not overload.
As I mentioned above, the signal level is nominally "line level", and that can mean very different things depending on context. You might find that using a passive volume control (potentiometer) between the turntable and the computer's analog-to-digital converter can greatly improve the quality of sound.
Jun 20, 2014 | Apple MacBook Pro Laptop Computer with...
My turntable speed is too slow. I have the optimus lab 1000 and there are speed adjustments on the bottom side of the unit but turning these either for 45 or 33 rpm did not change results. I have already...
Look under the platter or on the bottom of the turntable. There should be two adjustment holes for 45 and 33. You will need a small screwdriver for adjusting these. If this does not work clean the control pots with spray cleaner.
Dec 01, 2010 | Radio Shack Audio Players & Recorders
How do I remove the turntable to replace the belt underneath - I have just purchased the turntable and the belt is loose.
Good day. I assume that you have lifted the platter off the table. On the inside of the platter you will notice a second ring, or rim. the belt should be put on the outside of the second rim while the platter is still in your hands. Next, slide back the platter and look for the spindle running the platter through one of the big holes in the platter. Slip the belt onto the spindle and turn with your hand to make sure it runs freely. Hope this helpsmicmor100.jpg
Oct 10, 2010 | Aiwa PX-E860 Turntable
Ion turntable
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
May 09, 2009 | Technics SL-1200MK2 Turntable
Optimus lab 1100 truntable will not operate.
this is a belt driven platter. the belt is old and fell off. http://www.archive.org/details/Turntable_Belt_Installation
this link shows how to replace a belt, once you see where the belt goes thread a piece of string through the mechanism where the belt should go and measure it and contact them with the length. or measure total length of the old belt if still in one piece. figure about $14 for most belts.
Jan 24, 2009 | Audio Players & Recorders
Optimus 1000 belt drive automatic turntable
Usually, for most turntables, the belt goes on the bottom of the platter first. Then you put the platter back on the turntable. From here you should see an opening on the platter where you can 'grab' the belt. Pinch the belt, and then wrap it around the rotating motor's shaft. This is usually at the top left side - around the 10 o'clock position.
- OPTiC
Turntable Technician
www.1200s.com
Aug 17, 2008 | Audio Players & Recorders
BELT FALLS OFF
7) That's it.
- OPTiC
MasterTech
Jul 06, 2008 | Philco (R) Classic Turntable CD Shelf...
How do I replace the belt on a mt-6410 turntable
Just lift the platter off the turntable, and you'll see where the belt goes. You'll see a metal spindle/motor - this is where the belt wraps around. Then you will have to wrap around your turntable platter. This is a little tricky, but you should be able to figure it out.
- DJ PRO LAB
www.DJPROLAB.com
Apr 22, 2008 | Technics SL-1200MK2 Turntable
1,376 people viewed this question
 Grubhead
Grubhead
