Question about HP Computers & Internet
DESKTOP PC I recently restored my pc and ended up with 1.8 Ghz process speed out of 2.4 Ghz and also i only have 386 mb ram instead of 512mb.. any ideas?
  • Enrique Barrios May 11, 2010
    Hi.
    What do you mean by restored ?
    Problem Solver:
  • 15 Answers
What do u mean by restore? u mean to format ur hard disk/.reinstall the windows/made some hardware changes/change the proceser/motherboard.plz explain it properly than i can answer ur first problem.however let me tell u the ram never gives u the complete support.it will allways keep some less from u have.its allways give u under 480 aprox insted of 512.i can give u a example of myself.i have.1280mb of RAM but i m getting only 1120mb instesd of it.becouse our system take some less memory from we gives it.its not a problem.its a normal thing and u can see it in any p.c..u cant find more than 480 mb of ram whre a 512 ram is pluged in.
Posted on Jul 23, 2008
Why would I not be able to listen to music. starting 1 jan. i get the Pandora page but the artist does not and music
Minimum Specifications to Run Pandora
Most modern computers will play Pandora just fine, without any modification.
Minimum browser requirements:
Internet Explorer 7
Safari 4
Firefox 4
Chrome 7
Minimum hardware requirements:
PC desktop: Intel Pentium 4 2.33 Ghz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM, or
AMD Athlon 64 2800 or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
PC laptop: Intel Atom 1.6 GHz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
Mac laptop: Intel Core Duo 1.5 GHz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
Mac desktop: PowerPC G5 1.8 GHz or faster CPU, 1+ GB of RAM, 128+ MB of VRAM
Minimum internet requirements:
Consistent bandwidth of at least 150 kbps
If you upgraded to Pandora One and want to use High Quality audio, we recommend having at least 300 kbps of bandwidth.
If you're not sure of the speed of your internet connection, you can test your connection speed at any of these sites:
http://www.speedtest.net
http://www.dslreports.com/stest
Cookies Turned Off
Jan 02, 2015 | pandora.com Computers & Internet
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
What is the processor type and speed, RAM size and Hard drive capacity of packard bell R1005 laptop
It has a Celeron M processor, with 1500MHz clock speed, 512MB of RAM and a HDD capacity of 40GB and a 15.4'' screen.
Jan 29, 2011 | Computers & Internet
Memory upgrade: the factory 1mg RAM appears to be in two slots of 512MB each. If so, where can I find these huge monsters. I ordered a 1 MB chip and it's half as long as the 512 MG installed in my PC....
According to Acer's specifications for the T690, you need DDR2 RAM, which is quite commonly available. From your description of the RAM you got, I suspect you wound up with laptop RAM instead of desktop memory
You shouldn't have too much trouble finding vendors of the type RAM you need. Just look for DDR2 type, PC4200 (533 MHz) or PC5400 (667 MHz) speed, desktop RAM. Here's a link to one vendor (TigerDirect) so you can see typical memory and pricing. If you're not in the US, you should be able to find a seller in your part of the world.
Nov 22, 2010 | Acer Aspire T690 (AST690UP820A) PC...
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
Low RAM
your p.c has four slots for ram 533Mhz. if your ram is low then you can purchase extra ram to speed up your computers processing power. either 512Mb or 1Gb sticks are available for your motherboard at 533Mhz. if this is not sufficient then you will have to upgrade your board to a newer more powerfull model. changing motherboard is not replacing the whole computer. see computer repair shop or vendor.
Feb 07, 2010 | Acer Aspireā„¢ T180 PC Desktop
Desktop pc running very slowly, esp internet
First things first: You say that you only have 1 megabyte of ram. I think that you meant to say gigabyte. But if you do only have one mb, then you definitely need to get more ram. Secondly, press control+alt+delete and click the processes tab. Please say the number of processes running and the CPU Usage (they're counted and documented at the bottom left of the task manager window) in your reply. What anti-spyware checks did you run and have you checked your computer with an online scanner like kaspersky? Do you have any anti-virus (McAfee, Norton, AVG) software running? Close any unnecessary processes in the bottom right of your desktop screen on the toolbar (these icons are displayed next to your clock).
Jan 04, 2010 | Dell Dimension 9100 PC Desktop
Presario sr1130nx desktop, lost power, won't start up now
there is problem with u'r SMPS. repare it or change a new one
Nov 03, 2009 | HP Remanufactured Compaq Presario SR1130NX...
Trying to uprade
upgrade the RAM and find better processing speed of video card and using DDR3 memory
check your motherboard if capable of higher speed RAM..that will help too.
Mar 16, 2009 | E-Machines eMachines Desktop PC
Can't run a PC game, but its properly installed.
Chances are the desktop PC had a video accelerator and the laptop didnt. Laptops have integrated video cards that share the systems processor and memory to do its work. Video accelerators have their own dedicated CPU and memory and take the video work away from the system. A video accelerator with say 64 to 128 mb of video memory may have a 250 to 300 mhz CPU on the card. This means the system can dedicate the full 1.5 GHz and 512 mb of memory to the game. Integrated video cards like this one will give up about a third of its memory AND half of its processing power to run your game. In essence, the laptop is SLOWER than the desktop when playing the game. If the laptop is running Vista, then the slowdown is even greater.
Mar 01, 2009 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
